Question about HP OfficeJet D135 All-In-One InkJet Printer
Hp officejet d135 series printer
My printer panel lights are blinking like a flashing Chirtmas tree and the printer ask me to turn on and off and on and off. I've tried unplugging each adapter in the back and tried plugging the eletrical outlet to an outlet all by itself.  I've moved the printer to a new area and unplugged and plugged it in and turne it on and off and it continues to read the same thing.  What other options do I have or what can I do?
  • 3 more comments
  • Anonymous Nov 03, 2007
    I am having the exact same problem on a d135 printer/scanner/fax... if there is a solution to this. please mail it to me at davidanthonyrich@yahoo.com
  • Anonymous Jan 18, 2008
    error: power failure. this is with fax function only.
    did reset, checked all connections several times. odd thing is that faxes are going through despite error reading - and printer and copier work fine.
    called repair place today. i said i use machine as needed, it's not on all day.
    suggested i may be draining internal fax battery and to keep it on over the weekend and call with result.
  • Anonymous Mar 24, 2008
    I have the same problem when I try to print color.
  • titlemaven Apr 05, 2008
    I have identically the same problem with a d135. When turning off the printer, it re-starts, I get the blinking lights and message to turn of and on. . . . It doesn't work. On another hint from a different source, I unplugged the power, held the "3" & "#" keys for a re-set. This gave me a "partial reset" message and a frozen printer.
    Does anyone have a clue?
  • jimmyhinkley Mar 26, 2009
    I have an HP J6480 All-in-one and it keeps doing the same thing; all lights flashing, etc. After I power off and on, works fine. It's so irritating because this happens between every use.
I had the same problem . . . the power supply was failing and could not maintain full voltage to the printer. Unplug the power supply and test the voltage at the plug. It should be 31.5v. If it's not, replace the power supply.
Posted on Feb 02, 2009
Hey, cleaning the printer carriage seemed to work for me.
Posted on Mar 11, 2008
Could be the printer carriage is binding, oil the rail and try again.
Posted on Nov 28, 2007
Hp d135 all in one printer error message says "turn off and on" and all lights blinking fast
it's almost the (data cable) connected the carriage- it maybe damaged or not connected well.
Nov 29, 2012 | HP OfficeJet D135 All-In-One InkJet...
I have an hp officejet d135. It has knew ink jets and is hooked up. When I try to print the ink won't come out and the window says it's empty. Do I have a toner and if so where is it?
Your printer has a print head under the ink cartridges. You can try a cleaning, and if this does not fix the issue, you may need to replace the print head .
Clean Printheads function
To activate the Clean Printheads function from the front panel:
  1. From the front panel, press MENU.
  2. Press the RIGHT or LEFT ARROW until Status and Maintenance displays.
  3. Press ENTER
  4. Press the RIGHT or LEFT ARROW until Clean Printheads displays.
  5. Press ENTER
After a few minutes the HP Officejet D series will automatically complete the printhead cleaning operation.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 24, 2011 | HP OfficeJet D135 All-In-One InkJet...
Scanner failure
Scannerfejl. Kan ikke tilslutte til PC
Aug 05, 2009 | HP OfficeJet D135 All-In-One InkJet...
Hp d135 copy function makes copy in green instead of black
ur tri color cartridge may have run out. change it and try again. if it doesn't work try calibrating ur scanner.
May 03, 2009 | HP OfficeJet D135 All-In-One InkJet...
Where can get power cord for hp officejet d135?
you can call
Contact HP or call 866-625-1176 to order power cord.
Mark
Mar 28, 2009 | HP OfficeJet D135 All-In-One InkJet...
SCANNING FAILURE ON HP OFFICEJET D135
Bad SCANNER UNIT. Uneconomical to repair. Sorry
Jan 30, 2009 | HP OfficeJet D135 All-In-One InkJet...
HP OfficeJet D135 All-In-One InkJet Printer Logo
169 people viewed this question
Clive
Clive
