After copying about 20 pages, prints come out with a broad gray area from top to bottom. How can I cure this?
    Sergeant:
    Champion:
  • 219 Answers
Hi, I have faced the similar problem and afterr much inspection I came up with two small clues:  1) Only black appeared on the streaks, and  2) the "silver bar" under the developer roller of the black cartridge had a slight buildup of toner on the ends - in about the same proportions as the streaks (more on the left end). So I disassembed the toner cartridge and swapped the HV board and the developer roller with the previous empty cartridge - that fixed it
u should also try it but before it u should try to clean ur printer.
Thanks
Sandy
Posted on May 08, 2009
When printing with the hp color laserjet 2600n printer, continue to get a double gray images for words and pictures. I have follow all online hp directions to fix this problem with no success.
1. Make sure that the control-panel display reads Ready.
2. Press and hold the LEFT arrow (<).
3. Press the CANCEL (X) button and release both.
4. Press the CHECK button, 2ndary Service will be displayed. Press CHECK again to access.
5. Use the < or > button to navigate the secondary service menu.
6. To remove the secondary service menu from the menu tree, power-cycle the product.
- access 2ndary service menu
- run "clean ETB" to cleanup the belt
- set paper to heavy or cardstock, print 10 blank pages to celan up the fuser
- try printing something
- if issue perists, send something to be printed and before it comes out, open up the front cover to stop the printing process, take out the page from the cartdridge area
- if the issue is noticeable on the top of the page but not on the bottom, the problem is with the fusing assembly
- if the issue is noticeable on the top of the page and on the bottom, the problem is with the transfer belt or one of the toner cartdridges
Jul 24, 2010 | HP Color LaserJet 2600n Printer
Copies come out with gray streaks all the way through the entire page
if you are copying through the feeder check the small glass under the lid has not got any typex or ink stuck to it you check by placing a copy on the glass under the lid and do a copy here.. if no streaks apear then check the glass area.. also if you are printing to it and no streaks appear this area is the cause.. if it happens on teh print side too then you have a drum /dev wear issue and it may need replacing.
Jul 12, 2010 | Toshiba 2060 Copier
Broad dark line on right edge of copied papers
If you have the black line on copies and scans but printing from P.C is fine, then your scanner is broken.
Contact your printer manufacturer for a replacement or repair.
May 12, 2010 | Office Equipment & Supplies
Savin 2545 document feeder gives a gray band on the copies
Yes - surprisingly - we had the same problem, the gray stripe along the side of the page only showed up when the original was fed through the document feeder on top. Cleaned the small area of glass under the feeder repeatedly with no change to the resulting stripe, but then while cleaning the upper roller, above the area of glass where the scan lamp illuminates during the copying from the ADF, we found a small piece of paper adhering to the top roller in the paper path, cleaned it off, and no more band. We didn't see the bit of paper on the upper roller until we rolled it while cleaning. Still can't figure how that made a stripe....but hope this helps you.
Feb 22, 2010 | Savin 2545DP Black and White Copier
Gray Lines print onto copies
more than likely its your drum unit could be upper fuser film but prob the drum
Oct 02, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Top to Bottom gray line on left side of Copied Page
hello
does the grey line appear if you scan true the "upper" scanner.(set paper on top of printer and sscan it that way)? you should also clean the smal slim glass that is at the side of the big scanner glass.
also try to remove all cartridges and tilt them side to side several times. then put them back and test your printer.
Jul 02, 2009 | HP LaserJet 2840 Printer
Gray continuous streaks on lower half of copy using Canon IR 1600
I assume you had the issue before you changed the toner, If so the problem is either the fuser or the Laser.
Do this:
start a print job and after you hear the paper feed into the machine open the top cover to stop the machine. You want to stop the page before it gets to the fuser. May take a couple tries.
remove the toner cart.
the page should be under the cart with the image on it.
If the line is on the page the problem is image development(toner or laser).
If no lines the problem is likely the fusing assm.
May 28, 2009 | HP LaserJet 8100N Printer - Refurbished
All ink cartridges leak onto to copies
I think you need to change the tranfer belt assm.
If all the colors are smearing .
Or all of your toners are bad and leaking,
Hope this helps
Mar 28, 2009 | HP LaserJet 4650 Color Printer
Gray line down middle of faxes/copies on panafax uf880
yes change a toner and clean the glass area under nearth the toner.
Oct 24, 2008 | Panasonic Panafax UF-880 Plain Paper Laser...
jasbo
jasbo
