Question about Maytag Washing Machines
Not reading coins
Everything works, But when i put money it does not read and start, stays stuck
2 Suggested Answers
ElDopa
  • 295 Answers
SOURCE: my coin operated speed queen washer is stuck on spin cycle.
Tried unplugging the powerchord for a few minutes before plugging it in ?
Posted on Jun 29, 2014
I have Been playing this game for a while and for the Past couple of weeks i have Lost so many coins and have to but more to finished the game! If you Cant replenish my coins i Will not play
fixya cannot / will not replenish your coins as we have nothing to do with any games, money, coins.
If you bother to read the page you will see that it is an answer questions site and not a game site
Dec 11, 2015 | Video Game Consoles & Games
Wii wont take disc completely in the unit help
try taking it to your local game store or take it apart or maybe the led reader is broken
Sep 01, 2012 | Nintendo Wii Console
Hi, I have a Ps3 60 gig console.my child put couple coins inside the console,so I shook the machine and I can now play my discks cos it was stuck in the drive.before it got loose none of my discs including...
probebly not a good idea to use without removing the coins. it maybe ok now but if they move it could jam the drive or even short something causing a much bigger problem
Nov 19, 2011 | Sony Video Game Consoles & Games
Have a 1995 Oldsmobile Aurora and the "service engine soon" light came on at exactly 110,000 miles on the money, we were on our way up north so my husband pulled over and checked everything,...
there is a tool that you can use to short the connection to put the computer in read mode.and you have to count blinks like one blink then pause five blinks.that would be a code 15 then you have to look up what code would be.it ends with a 59 or 34 if my memory serves .
Jan 09, 2011 | Oldsmobile Aurora Cars & Trucks
92 Accord Battery, Alternator, Battery Cables and fuses changed out. Battery is being drained dont know what else it could be...Help me please!
sounds like you have done more work than needed I wouldn't have changed your alternator, waste of money
1st check your battery with a multimeter (go digital if you can) theses are very cheap to buy, and you will use it a lot, set it to volts DC as per instructions start car and connect multimeter probes or clips to appropriate battery termianals, read display it shoud be 13.8 volts,, you now know battery cables and alternator are fine,, disconnect battery and do the same with multimeter on the battery again, leave sitting and watch reading if it goes below 12 volts over an hour your battery needs replacing.. If all good check when the battery terminals are back on tight and clean put the multimeter probes on termianls and ignition off and watch to see if reading starts to drop, if nothing turn ignition to accessories with everything turned off and again watch meter,, its a long process If you find it is still draining then pull a fuse at a time and check meter each time, if still dropping put the fuse back in and pull another one out.... repeat process till found........ before you start check glove box light isnt staying on, boot/trunk light is going off, ( put someone in there if you cant see) ,, If you have put in an aftermarket stero it may draw to much and you may have to upgrade your system, start with checking your battery
Jun 21, 2010 | 1992 Honda Accord
Coin completely jammed in vertical coin drop mechanism
unplug the machine,open the top of the coin op i use a stubby 5/16 nut driver,you have to remove the rod and it's a 5/16 inch rod,turn it counter clockwise to remove,this rod holds the unit in place,when you have the rod out then you can grab the front where you put the money in and lift it up and out,it sits in a couple of slotted holes
Nov 11, 2017 | Maytag MAT12CS Top Load Washer
My 2 year old stuffed a couple of coins intoPS3
open it and try to get the disc port open on then just take out the coins and put it back together (and try to keep coins away from your 2 year old)
Nov 19, 2009 | Sony Playstation 3 (PS3) Console
My battery and everything works just fine, the only problem is that it won't start. i'm afraid that i might need to change the alternator
If everything works, it might be your starter. The alternator usually fails gradually, and will give weaker and weaker charges. Give your starter a healthy tap and see if it frees up. If so, you will need to replace it. If the ignition engages (you hear a sound like it's trying to start) but it does not start, trace the system from the plugs back
Sep 07, 2009 | 1997 Pontiac Bonneville
Grinding Noise when Washer Attempts to Spin
It is probably the same problem because it is trying to drain during the spin cycle. My machine sounded as though a chain wis clanking, the solution was removing a coin caught in the drain pump. Access the pump from the bottom of the machine. 4 screws hold the mounting bracket on undo those, the electrical connection and two hose to the pump. Undo three screws holding impeller to motor and coin can fall out. Examine for damage if it is not too tore up, put back together. Keep in mind that when you unclamp the hoses that water will come out.
Feb 02, 2009 | Maytag MAH2400A Front Load Washer
Washing Machines Logo
14 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
