Forgot password 192.168.1.1:80 router wifi - Computers & Internet
    Problem Solver:
  • 5 Answers
Try admin for the user name and no password, or no user name and admin for the password. also, try a hard reset by holding reset button on back for 30 seconds w/ router disconnected. This will wipe any settings you had saved. But it will set everything back to default. You could also download the manual for that model of router to find out the default username/password. Good Luck.
Posted on Nov 25, 2013
  • 1214 Answers
SOURCE: how to recover my password
You'll have to do a hard reset, and reconfigure all the settings.Small recess in the back of the router. Press and hold for 20 seconds.
Posted on Feb 01, 2009
Geekman
  • 32281 Answers
SOURCE: HOW TO ACCESS DLINK WIFI ROUTER BECAUSE OF FORGOTEN PASSWORD
You reset the D-Link back to the factory default by - Press the RESET button at the back of the wireless router when it is powered up. Holt the RESET button foe at least 5 secs until the LEDs flash and then release the RESET button.
You can then configure the D-Link as follows ;-
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Posted on Nov 19, 2009
not you
  • 158 Answers
SOURCE: How can I unlock my router? I forgot the password
Ok I found two support links for you.The first one will give you a phone number and the other is for email support,they are for your router support.You will be able to gain access after giving them some required answers.(its not hard or time consuming)
Here is the phone number 1-877-466-8646 note not a free number! hope this has helped
http://broadband.motorola.com/consumers/support/phoneSupport.asp?productID=sbg900
http://broadband.custhelp.com/app/answers/list
Posted on Jun 15, 2010
davidj5684
  • 104 Answers
SOURCE: i forgot the password of
Can you not get on the wifi itself or you can't login to the router? If you can't get onto the wireless, then you need to get into the router config page. Plug in an ethernet cable from the router to your laptop and that will allow you to connect to the network so you can login. Open a browser and type in the address bar "192.168.1.1" (this is the default address for the router unless you changed it). Then you need to login.....
Most D-Link routers have a default username of "admin" and a default password of either "admin" or simply blank (no password). Try those and see if you can get in.
If you can't login with those credentials you can reset it. There should be a reset button on the back of it. You would most likely need a paperclip or pencil tip (something small) to stick in there to press it. Hold down the reset button for about 30 seconds and that will reset all the setting back to factory defaults as though you had just bought it. Then the above passwords should work. (note- this would wipe out ALL settings so you would need to setup your wifi and everything else again).
If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
Posted on Mar 04, 2011
SOURCE: I forgot my password for my wireless router, and can not sign my wifes new phone up on our wifi
When your phone asks for the password, out in the Encryption key. If you didn't print this out when you installed the router, insert the CD and install the Easylink Advisor, which wil then show up down in your taskbar in the bottom right corner of your screen. Open it, click on the Support tab, and it will show all your settings. For the password requested on your smartphone, enter the encryption key from your settings in EasyLink Advisor. That did it for me. Good luck!
Posted on Oct 30, 2011
Netgear wifi range extender wont take my password for my iternet
Hard resetting a netgear router will reset/erase all the configuration settings saved in the router. If you forgot, this will reset the admin and password login to the router and WiFi password. Use a paper clip to press and hold the small (restore factory settings) button for about 7-10 seconds
Nov 30, 2016 | NetGear Computers & Internet
Forgot pass word
Press the little recessed Reset button in the rear. You press it with the tip of a pen. Have you checked for a label under the unit?
Once resetting, you will have to set it up again.
Dec 16, 2015 | Belkin Computers & Internet
Why cant i find my password for wifi connection on my ipad?
If you check your own wifi password than go to wifi setting and click Show characters check box but if you are using router and forgot your wifi router than try to reset your router wifi password. If you need any technical guidance than follow Mac Technical Support .
Jul 06, 2014 | Apple iPhone Smartphone
Forgot my wifi password
Many routers have a sticker on their belly with the default password.
Newer routers often have a reset switch to restore default settings.
(needs to be held down for 10-15 seconds). Most router makers host support websites; look up by model#. Good luck!
Mar 13, 2014 | Computers & Internet
I forgot my password on my EnGenius ESR900 wifi router
Almost all routers have a reset button, with the router on, push the button for 20 sec, this should set it to default. user name is always Admin, password most of the time is password, or admin again, good luck
Jan 19, 2014 | EnGenius ESR900 Xtra Range Dual Band N900...
Wifi password
If you are using a router ( and of course have physical access to your router) reinitialize (reset it to factory default) and reconfigure your network. If password was provided by some Internet provider, contact your provider.
Nov 06, 2013 | D-Link Computers & Internet
Forgot password for wifi
You can always use the reset in the back, but that will clear all custom settings. Hold it in till it cycles. Defaults to web admin can be looked up at Port Forward dot com.
Feb 05, 2013 | NetGear WGR614 Wireless Router
I want to connect to my home wifi but do not know the password to connect
the wifi password is usually on the bottom of the router, often the serial number. If not and your router was supplied by your internet provider then you will need to contact them for the password.
Apr 15, 2011 | Computers & Internet
Forgot password to WiFi How do I find out what it
To find the password/passphrase on the Linksys router, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router. On older models the username is left blank and the password is “admin”. On newer models, both the username and password is “admin”.
Once you get in to the router management tool, look for the security portion. There you will find the password or passphrase you are using for your WEP or WPA security encryption.
Dec 01, 2009 | Linksys WRT160N Wireless Router
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
