Question about Delta Home
Have a Duo Flush System from FluidMaster. It continuest to ghost flush. Have adjusted the float valve several times but is still ghost flushes. How can I stop this?
    Top Expert:
  • 12,223 Answers
Follow this steps and fix it. God bless you
f the toilet bowl overflows, use a plunger or auger to eliminate clogs. If the toilet does not flush, tighten or replace the defective handle , adjust or replace the lift chain , or replace the flush mechanism. Jiggling the handle forces the lift chain or rod to re-seat the flush mechanism, telling you that something is awry.
If the bowl drains sluggishly, remove the clog with a plunger or auger, or raise the water level in the tank .
If water runs continuously through the toilet, lower the water level in the tank , adjust or replace a lift chain or wire , repair or replace a worn flush valve , clean or replace the valve seat assembly .
If water appears under the tank, tighten the tank hold-down bolts , lower the water level in the tank, replace the float valve , replace a malfunctioning ball , or tighten nuts on the water supply line, replace leaking supply line . As a last resort, re-seat the toilet .
If the seat is cracked or unsightly, replace it .
If the bowl or tank is cracked or otherwise unacceptable, replace the entire toilet .
Have a Duo Flush  System from FluidMaster.  It con - 0b0822b4-413c-4b81-ac65-828f91b578be.jpg
Posted on Nov 26, 2013
  • 374 Answers
SOURCE: how to replace a commercial flush valve
These used to very simple but have become more complex as technogy evolves. I will give you the standard answer though.
First shut the water supply off to the aplliance (there is a little decorative cover on the valve that is attached to the water line coming out of the wall. It looks like a nut. Pop this cover off and screw the screw in remember right is closed and left is opened.)
Now it is only a matter of unscrewing the couple of nuts that attach the actual valve.
Most valves come with step by step instructions but even without them it is usually a 30 minute job or less. You will need a flat head screw driver, spud wrench, tubing cutters- to cut the chrome trim tube to size, and some pipe thread compound or teflon tape.
Thanks for using Fix Ya and if I can be of further assistance let me know.
Jim
Posted on Nov 10, 2008
frcs68
  • 1605 Answers
SOURCE: toto seems to flush,but suction not working and waste not emtying
check the discharge hole, meaning you have to take down the toilet.
and make sure the water in the tank is at a proper high. you need the volume to create the wirlpool and push the waste.
Posted on May 20, 2009
snap101
  • 117 Answers
SOURCE: PEGASUS TOILET DOES NOT FLUSH COMPLETELY EVERY TIME
sometimes if you change the flapper and add more water to the tank by adjusting the fill valve they will flush with more power
Posted on Aug 08, 2009
  • 102 Answers
SOURCE: villeroy & boch flush mechenism needs to be replaced
V&B US phone number is or used to be 877-505-5350 they should be able to help.
Posted on May 26, 2010
deeric27894
  • 167 Answers
SOURCE: We installed a dual
yes , You can adjust it ...
Posted on Nov 18, 2010
I have a fluid master duo flushkit i have to hold down the handle to flush toilet is there an adjustment
Make the chain as short as possible for the flapper. It has nothing to do with the fluidmaster
Nov 24, 2013 | Fluidmaster Duo Flush Toilet Kit
Fluidmaster duo flush doesn't flush on setting
What setting.get are you speaking of? If its the water level you can adjust that by the screw on the side of fill valve.
Nov 26, 2012 | Fluidmaster Plumbing
The toilet flushes but it won't fill. I can turn the water supply off and then back on, then it fills normally.When the tank is full, I can push the float down and no new water enters. when I flush,...
Hi!please kindly check your fill valve if it is working correctly.I thought the problem is in your fill valve.Kindly adjust the floater of your fill valve.
Aug 24, 2011 | Kohler Home
Toilet running and won't stop.....it keeps running into the little overflow tube
When water goes over into overflow tube then that means 2 things.
The rubber flapper at tank bottom is good and does not need replacement at this point.
That leaves 2 possible problems.
1) The flush valve needs to be adjusted so water turns off sooner.
Flush valve lets water into the tank.
For example if you have a float ball on end of brass rod, just bend the brass rod so the float sits lower in the water.
If you have the 'fluidmaster' then a float rides up and down with water level. There is a metal rod with a metal clip. Squeeze the metal clip and move it downward on the metal rod.
2) If water will not turn off after adjusting flush valve, then replace flush valve.
Local hardware store sells the part and can help with instructions.
You need a crescent wrench or large adjustable pliers.
Plumber can also install the flush valve.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on plunbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 17, 2011 | Kohler Persuade Two-Piece Elongated Toilet...
Glacier bay toilet :water is overflowing into the overflow pipe. Flapper seals properly.
It's hard to tell you what to do without knowing what kind of flush valve and/or float you have. You may need to adjust fill screw on flush valve or seal. Or you may need to adjust float setting to get water to shut off.
If you want to make it pretty easy then replace existing valve with a new one. I like the 400A Fluidmaster.It is easy to install ,adjust,and cheap to repair.They only cost about ten dollars and by following the instructions on the inside of the box you can do it yourself. Tgank you.
Feb 21, 2011 | Plumbing
When flush my toilet, water keep running until i put my hand inside the middle and pull the float , then stop. toilet make is rapid sl
the ball **** fill valve is a poorly designed valve. replace it with a fluidmaster fill valve and a fluidmaster flapper. flappers do go bad after a year or ten depending on your water quality and choice of flapper but the fluidmaster fill valve will last a long time also. you can also get the water saver fill valve by fluidmaster and there is also a conversion set to change your toilet to a dual flush. all this is at lowes and there is a plumbing pro there to explain further. feel free to give me a positive rating. thanks!
Feb 15, 2011 | Home
I replaced my fluid master and now it will not stop filling in the tank.
Try lifting the float part of the valve. If the water stops filling, reset the float level lower.
If water does not stop when lifting the float, flush out the valve according to the instructions - steps 12 - 15.
12. IMPORTANT: Always clear sand and rust from system. Make sure
water supply is shut off. Remove valve TOP by lifting arm and rotating
top and arm 1/8 turn counterclockwise, pressing down slightly on cap.
13. While holding a container over the uncapped VALVE to prevent
splashing, turn water supply on and off a few times. Leave water
supply off.
14. Replace TOP by engaging lugs and rotating 1/8 turn clockwise. MAKE
CERTAIN TOP IS TURNED TO THE LOCKED POSITION. VALVE MAY
NOT TURN ON IF TOP IS NOT FULLY TO THE LOCKED POSITION.
15. Turn on water supply. Adjust water to desired level by squeezing water
level adjustment clip and moving FLOAT CUP up or down along stainless
steel link. Check for leaks, then check for proper flush.
If valve continues to run:
IF FILL VALVE WON'T TURN OFF,
• There may be debris at seal - repeat Steps 12-15.
• The seal inside the valve top may be damaged -replace with genuine
Fluidmaster 242 seal.
Nov 29, 2010 | Fluidmaster INC #B1F09 9" Faucet Connector
I have a toto toilet that doesn't start to refill until a couple of minutes after I flush. Any ideas. Thanks.
Several ideas. Start to fill? Have you looked inside the tank to see what's going on? If it just filling very slowly, then you most likely have some calcuim build up inside your flush valve blocking some flow, if this is the case you will have to clean the flush valve. If your flush valve is staying up and the toilet is "running" unitil the float drops. The float (either the arm ballcock style, or newer fluidmaster) is rubbing on either the flush lever or side of the tank, and taking longer to drop to let the water start flowing. I
Jun 23, 2010 | Toto Toilets ST784S 12 Sedona Beige...
Not getting enough water in the tank to flush properly.
adjust the float level,it's a rod attached to lever next to float . i believe it will take a screw driver, look closely there is a+/- indicator
Apr 15, 2010 | Fluidmaster & Fits-All Faucet Connector
Home Logo
233 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
