Question about Dishwashers
GE 3-Outlet 15-Amp Outdoor Remote Control System Item #: 357409 Model #: 58030LO
1Guru
  • 61 Answers
SOURCE: codes for daewoo tv, ge remote model 24912
Codes for Daewoo are: 0451, or 0092
If this doesn't work with your new remote there is always the way that I have done it in the past and that is to use the find the code function on your new remote. It is a pain but can be done and is quite effective. Each remote is slightly different, but for the most part you would hit the set up botton and hold it in until it starts flashing then hit the T.V. Button and then hit the first code it tells you to hit and then hit the power switch if it doesn't turn off your T.V. then you hit the increment button up, (this is different for each remote so it is important to follow the instruction manual on this part) You bassically keep hitting the incriment button until your code comes up and then it will turn off your t.v.! Then your done. Note: It may take up to 400 pushes of the increment button, but it will work.
Posted on Dec 14, 2008
  • 33 Answers
SOURCE: codes for Daewoo TV & DVD on Ge UN Remote #
go on their website there is always a list of codes
Posted on Aug 25, 2009
protek480
  • 1723 Answers
SOURCE: 15 AMP versus 20 AMP outlet plug
The circuit is protected by the 15 amp breaker. That's what matters, the wire size and the breaker feeding it. It's OK to have a 20 amp recepticle fed by a 15 amp breaker.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 11, 2009
Testimonial: "Concise answer"
jyackle5
  • 8197 Answers
SOURCE: I have a Woods 13568
Sorry you can not just buy the remote you need to buy the whole kit. You can try to ask woods on the link below.
http://www.colemancable.com/contactus.aspx
Posted on Dec 20, 2010
  • 324 Answers
SOURCE: Cooks Microwave fuse 15 amp
www.digi-key.com or www.newark.com stocks those fuses.
Posted on Jun 10, 2011
How to find fuse boxs
FUSE PANEL LOCATION
The fuse panel is located in the engine compartment. A label on the inside of the cover lists the fuse amperage and circuits protected.
volvo 850 fuses fuse panel layout service repair manual
FUSE PANEL IDENTIFICATION
Fig. 1: Fuse Panel Identification
Courtesy of Volvo Cars of North America.
WARNING: Always disconnect battery ground cable before servicing "high-current fuses. It is recommended that "high-current" fuses be replaced by a qualified technician.
* 1 - 15 Amp
Fuel Injection, Distributor Ignition, Automatic Gearbox
* 2 - 15 Amp
Fuel Pump, Alarm System
* 3 - 10 Amp
Courtesy Lights, Oil Level Sensor
* 4 - Not Used (1993-95)
* 4 - 10 Amp (1996)
Electronic Start Inhibitor (Immobilizer)
* 5 - 30 Amp
ECC Blower (Speed 4)
* 6 - 25 Amp
Central Locking System, Alarm
* 7 - 15 Amp
Audio System (Amplifier)
* 8 - 25 Amp (1993-95)
Power Antenna, Trailer Connector
* 8 - 40 Amp (1996)
* 9 - 30 Amp
ABS, Traction Control System
* 10 - Not Used (1993-95)
* 10 - 15 Amp (1996)
Heated Rear Seat (If Equipped)
* 11 - 30 Amp
Heated Rear Window & Side Mirrors
* 12 - 10 Amp
Brake Lights
* 13 - 15 Amp
Hazard Flashers, Headlight Flashers, Alarm
* 14 - 30 Amp
* 15 - 10 Amp (1993-95)
Audio System, Courtesy Lights, Door Open Light, Trunk Light, Glove Box Light, Remote Control Central Locking System,
Oil Level Sensor, Seat Belt Reminder
* 15 - 10 Amp (1996)
Oil Level Sensor, Seat Belt Reminder, Data Link Connector
* 16 - 30 Amp (1993-95) Accessories
* 16 - 30 Amp (1996)
Power Antenna, Trailer Connector, Accessories
* 17 - 10 Amp
Key Reminder
* 18 - 25 Amp (1993-95)
Heated Front Seats, Power Mirrors
* 18 - 15 Amp (1996) Front Fog Lamps
* 19 - 15 Amp
Left High Beam Headlight
* 20 - 15 Amp
Right High Beam Headlight, High Beam Indicator
* 21 - 15 Amp
Left Low Beam Headlight
* 22 - 15 Amp
Right Low Beam Headlight
* 23 - 10 Amp
Left Parking Light, License Light
* 24 - 10 Amp
Right Parking Light, Bulb Failure Warning Sensor
* 25 - 10 Amp
Rear Fog Lamps, Fog Lamp Indicator
* 26 - Not Used (1993-95)
* 26 - 25 Amp (1996)
* 27 - 15 Amp
Back-Up Lights, Turn Signals
* 28 - 10 Amp
Cruise Control, Heated Rear Window, Seat Belt Reminder Light, Shiftlock, Bulb Failure Warning Sensor, Heated Rear Seat
* 29 - 15 Amp
* 30 - 10 Amp
Cigarette Lighter
* 31 - 25 Amp
ECC, ECC Blower (Speeds 1-3)
* 32 - 10 Amp
Audio System, Remote Controlled Central Locking System
* 33 - 15 Amp (1993-95)
Power Seats, OBD Test Socket, Tailgate Washer/Wipe (Wagon)
* 33 - 15 Amp (1996)
Power Seats, Tailgate Washer/Wipe (Wagon)
* 34 - 25 Amp
Windshield Wiper/Washer, Horn, Headlight Washer/Wiper
* 35 - 10 Amp
Instrument Lights, Sun Roof, Traction Control System
* 36 - Not Used
* 37 - Circuit Breaker
Power Windows, Power Sun Roof
* 38 - Not Used
* 39 - Circuit Breaker
Drivers Power Seat
* 40 - Circuit Breaker
Passengers Power Seat
RELAY PANEL LOCATION
The relay panel is located at the left corner of the instrument panel.
i copied this off a volvo site Hope this helps
Oct 10, 2016 | Volvo 850 Cars & Trucks
On sa 210, when timer off (either from program or manually switched off) correct "bulb off" status is displayed on the indicator, but the power doesn't go off from the outlets. this problem...
Most digital timers can be restored by resetting timer and then reprogramming.
http://waterheatertimer.org/Sylvania-timers-and-manuals.html
http://waterheatertimer.org/pdf/Sylvania-SA-210-Manual.pdf
Sylvania tech support: 888-548-4484
www.hardwareinnovations.com
Sylvania timer has 1 year limited warranty.
Sylvania timer can be used for 1000W incandescent Loads and Motor loads up to 1/4Hp
All outdoor timers are susceptible to power surge from nearby lightning.
Timers are also affected by line noise and incorrect outlet polarity.
Test outlet with circuit analyzer. Use timer to control different Load on different outlet.
If more than one timer has same problem, then suspect can be line noise and outlet polarity.
Heavier-duty Intermatic HB8800RCL timer has limited lifetime warranty, and controls 1800 watts and 1/3 HP.
http://www.amazon.com/Intermatic-HB800RCL-Seven-Outdoor-Digital/dp/B001KBZUNK/ref=pd_cp_hi_2
Aug 05, 2011 | Sylvania SA210 15 Amp Zip-Set Digital...
How to set a GE outdoor timer product ID 51587 ?
GE 51587 has same instructions as Tork 601A single-outlet outdoor 24-hour mechanical timer.
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or pen to set timer on-off functions.
With GE timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
Set multiple ON/OFFs each day.
Timer repeats every 24-hours.
Manual ON/TIMER switch located on inner dial.
Set override to timer for program to operate.
To override time and turn on Load, move override to ON position.
Dec 06, 2010 | GE 51587 MultiEvent Timer
I have a holiday living 6 outlet yard timer and i lost my directions....Model # lx28006
Woods brands sells timers that are packaged and sold under various names and numbers.
For example GE sells same yard stake under their brand.
Woods 6-outlet yard stake manual:
Add a comment and say if this is your timer manual.
http://waterheatertimer.org/pdf/GE-15107-outdoor-timer-manual.pdf
Dec 05, 2010 | Hardware & Accessories
On-site breaker panel routing
white and ground are grounds there should be a ground rial in the fuse box, stove is 220 black and red go to 2 seperate breakers, 25 amps, and 15 amp is for 110 regular outlet
Oct 08, 2009 | GE Cooktops
Not able to find the fuse in my 2007 Volkswagen Jetta for the cigarette lighter can you tell me which one of these is it?
well here is mine but is 2003 and i dont think they have changed to much ...
Fuse identities for A4.....
-----------------[ S8 ][S 12][S 16][S 20]
-----------[ S5 ][ S9 ][S 13][S 17][S 21]
[ S1 ][ S3 ][ S6 ][S 10][S 14][S 18][S 22]
[ S2 ][ S4 ][ S7 ][S 11][S 15][S 19][S 23]
[ S 24 ] [ S 31 ] [ S 38 ] -- -- --
[ S 25 ] [ S 32 ] [ S 39 ] R R R
[ S 26 ] [ S 33 ] [ S 40 ] S S S
[ S 27 ] [ S 34 ] [ S 41 ] -- -- --
[ S 28 ] [ S 35 ] [ S 42 ] R R
[ S 29 ] [ S 36 ] [ S 43 ] S S
[ S 30 ] [ S 37 ] [ S 44 ] -- --
S1=10 AMP=Heated washer nozzles, glove compartment light, memory seat...
S2=10 AMP=Turn Signal System
S3=5 AMP=Fog Light Relay, Instrument Panel Dimmer Switch
S4=5 AMP=License Plate Lamps
S5=7.5 AMP=Comfort System, Cruise Control, Climatronic, A/C, Heated Seat Control Modules, Day/Night Dimming Mirror, Control Module and Control Unit for Multifunction Steering Wheel.
S6=5 AMP=Central Locking System
S7=10 AMP=Back-up Lights, Speedometer Vehicle Speed Sensor.
S8=OPEN
S9=5 AMP=Anti-Lock Brakes.
S10=10 AMP for GAS/5 AMPS for Diesel=ECM
S11=5 AMP=Instrument Cluster
S12=7.5 AMP=B+ (battery positive for data-link connector) (DLC).
S13=10 AMP=Brake Lights
S14=10 AMP=Interior Lights, Central Locking System
S15=5 AMP=Instrument Cluster, Automatic Transmission Control Module (TCM).
S16=10 AMP=A/C Clutch, After Run Coolant Pump.
S17=Open
S18=10 AMP=High Beam Right
S19=10 AMP=High Beam Left
S20=15 AMP=Low Beam Right
S21=15 AMP=Low Beam Left
S22=5 AMP=Parking and Side Marker Lights, Right
S23=5 AMP=Parking and Side Marker Lights, Left
S24=20 AMP=Front Wiper Motor, Washer Pump
S25=25 AMP=Fresh Air Blower, Climatronic, A/C
S26=25 AMP=Rear Window Defogger
S27=15 AMP=Rear Wiper Motor
S28=15 AMP=Fuel Pump, Gas Engine Only
S29=15 AMP Gas/10 AMPS Diesel=ECM
S30=20 AMP=Sunroof Control Module
S31=20 AMP=Automatic Transmission Control Module
S32=10 AMP Gas for Fuel Injectors/15 AMP Diesel for ECM
S33=20 AMP=Headlight Washer System
S34=10 AMP=Engine Control Elements
S35=30 AMP=12 VDC Outlet in Trunk
S36=15 AMP=Fog Lights
S37=10 AMP=Radio Terminal 86S, Instrument Cluster
S38=15 AMP=Central Locking System (w/ Power Windows), Luggage Compartment Light, Remote Fuel Tank Door, Rear Lid Unlock.
S39=15 AMP=Emergency Flashers
S40=20 AMP=Dual Tone Horn
S41=15 AMP=Cigarette Lighter
S42=25 AMP=Radio System
S43=10 AMP=Engine Control Elements
S44=15 AMP=Heated Seats
Jun 15, 2009 | 2007 Volkswagen Jetta 2.5 Sedan
Code problem
turn on item you want programmed.press set up.press button for item on remote.press power button up to 300 times slowly until tv ect... turns off.hit enter this should work
Jan 30, 2009 | Directed 434MHZ Remote Control
How to program model # 15-2135 to a GE tv
We have a 15-2135 not a 42. Just tell us steps to do to get code into it for a GE  TV
Jan 17, 2009 | Radio Shack 15-2142 Remote Control
Air Conditioner unit won't switch on outdoors
can you give us some model numbers and a make? Get both the inside and outdoor unit numbers please. Thanks.
Oct 10, 2007 | GE AJCH10ACB Built-In Room Air Cool Unit
Dishwashers Logo
76 people viewed this question
Top Dishwashers Experts
