Question about HP PhotoSmart Office Equipment & Supplies
Google My HP Photosmart 4180 ALL-IN-ONE printer will print, but doesn't offer an option to send scan to my computer with Windows 7 software. It has sent scans to same computer for 2 years, now only offers to scan and reprint or send to memory card. I can't find a way to send to my computer. Thank You
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 29 Answers
Since it seemed to be working before, try unplugging the printer and replugging usb cord to allow the computer to "re-find" the printer. If that doesn't seem to correct it, try reinstalling the software for the printer. Here's a link to HP if you don't have the disk. Obviously pick the correct operating software: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=2093&lc=en&cc=us&dlc=en&sw_lang=&product=3177566#N191 Good luck with it.
Posted on Nov 25, 2013
SOURCE: my new hp photosmart c6250
I reinstalled the program and will control the printer from my computer. The scan menu still does not say, 'scan to computer', as the basic guide book says that it should.
Posted on Jul 19, 2008
mrbench87
  • 40 Answers
SOURCE: scanning a document
i would like to know if you did completely install the printer software of this printer.if you did kindly locate the icon HP SOLUTION center,go to settings>>scan setting>>san to set-up>>restore to defaults.kindly check now if the front panel destination list has generated the options then click apply and OKAY.try to press now the scan button of the printer is the scan options are generated...
send feedback for further troubleshooting solution..
Posted on Aug 31, 2008
rakeshpramod
  • 234 Answers
SOURCE: MY HP PHOTOSMART DOES NOT GIVE OPTION TO SCAN TO PC
First make sure that the software is sucessfully installed in you computer and then try the steps metioned bellow.
Go To My computer>C:\Drive\windows>system32
Copy hpzipm12
minimize this window
Right click on Start button on the computer>Explore>Programs>Startup>edit>paste
minimize this window.
Go back to My computer>C:\Drive\windows>system32
Copy hpzinw12
Now you will see two new files in Startup
Now go to My Computer>C:\Drive\Program Files>HP>Digital Imaging>bin>
Copy hpqtra08
close this window
Restart the computer
Open Hp Solution Center> Settings>Scan settings and preferences> Scan to button>
check destination list> if available applications are not in the destination list then add them in the front panel destination
Tried to scan.
Posted on Dec 21, 2008
anujbhatt
  • 66 Answers
SOURCE: How to scan a document to my computer
if it is XP, then click on start , then run , in run type wiaacmgr.exe and hit enter, try to scan.
In vista and windows 7 , replace run with start search box.
Posted on Apr 10, 2010
SOURCE: why can't I scan to my computer from my hp
Only one scan come's through, the same one I put In days ago.
Posted on Mar 19, 2011
Hp photosmart C7250 hangs while printing
Hi Georgette,
You have tried your best with possible troubleshooting to fix the issue. There are few possible workaround solution for this issue.
First, If the USB Cable is more than 3-5 ft long, it could be the reason. Also, if the USB Cable is worn out or is broken in-between.
2nd, The printer does not seems to accept command from PC ( win 7 ) using the HP Software. So Uninstall the Software. Restart the PC.
Do not install Printer Software. Connect the Printer USB to PC and Windows 7 will display new hardware detected message.
Continue with the New Hardware Found Wizard and install the drivers it will list by Default.
Try to print and it should work.
If this works, You will be able to print without any problems however if you want to scan a document, you need to use Applications like MS-Paint, Microsoft Word etc, or Use the Scanners and Camera option in Control panel.
You can then install the software disk of printer or the downloaded software from Hp website to install Printer software for SCanning.
If you do so, you will find 2 printer icons in Printers Folder. First one will be with WSD text ( this icon is created when you connect the printer using USB without installing the printer software ) and 2nd icon will be HP Photosmart C7200 All in One ( this will be the Software installed ) and this will be default icon with check mark.
Whenever you want to print from any application, You need to click on File - Print - choose the WSD icon to print.
Regards,
Sean S
Sep 19, 2012 | HP Photosmart C7250 All-In-One Thermal...
Installed my Hp Photosmart printer c309a to a Toshiba (Windows 7) I am able to print wirelessly. But when i try to scan -"to computer" the screen on the printer reads !! Scan Problem-try...
Please install and run the below mentioned software to automatically diagnose and fix scanning issue:
HP Scan Diagnostic Utility
After installing this utility,
  1. Press the Power button to turn on the product, if it is not already on.
  2. From the Scanner column in the Scan Diagnostic Utility, select your HP product.
  3. Click Diagnose . The Scan Diagnostic Utility diagnoses various scanning problems, and then displays a list of results. The results display either when the tool detects an error, or when the tool completes the diagnosis and there are no errors.
    If this utility doesn't solve your issue, please revert back.
Sep 02, 2011 | HP Photosmart Premium C309A All-In-One...
Upgraded to windows 7 and my hp photosmart c6180 is not printing
one option you have is to go to hp/support type in your product c6180 you'll have software download options for windows 7. These downloads should enable your printer to print again. Although from using windows 7 the os has been very good at recognizing printers when plugged in. Could try unplugging and replugging the printer in from the usb. Windows 7 might recognize and automatically download the correct drivers. If not download the software from hp.
Jan 09, 2010 | HP Photosmart C6100 All-In-One Printer
Hp 4180 will scan but won't print, error cannot find printer, tried disconnecting/connecting, remove/reinstall, no fix
I have an old computer/printer hp pavilion mx 70/hp psc 750. I cannot print documents from computer to printer. I have unplugged everything but still no luck. Have removed all printers and reset my printer as default. Any ideas?
Dec 10, 2009 | HP Photosmart 4180 All-in-One Printer
HP F4180 will not scan!
HP does not support Vista operating system, no software or drivers for it are offered at all. If Vista, you also cannot use either the scan button on the "All-in-One" or the usual method of HP Solution Center. HP has discontinued the F4180 and supports it only minimally.
You can scan via Windows Photo Gallery, or though Paint, or through Windows Fax and Scan. File - Import from camera or scan, or File - scan, are paths.
I have loved this printer/scanner but plan myself to avoid anything HP makes in the future because of this "support".
Feb 14, 2009 | HP Photosmart 4180 All-in-One Printer
HP Photsmart 4180 will print but not scan.
Your CD's drivers probably aren't approved for Vista. Below is a link to the HP support site's Vista driver download page for your all in one.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&lang=en&product=1141647
Feb 12, 2009 | HP Photosmart 4180 All-in-One Printer
27 people viewed this question
Seeker5211
Seeker5211
