Question about Sanyo VPCS885 Digital Camera
Sanyo VPC-S885 How do you change the ISO on the Sanyo VPC-S885? It's not letting me change it and I didn't know if some options were wrong..? (i hope this makes sense)
    Top Expert:
  • Sanyo Master
  • 6,702 Answers
Iso only can be set in other than automatic mode. Goto the image capture menu (it is the camera loge on the top bar)
then second line is ISO settings. Goto that line and click to right to cycle trough the settings.
Posted on Nov 25, 2013
2 Suggested Answers
BillB-SA
  • 2761 Answers
SOURCE: I have a Sanyo VPC-s885 digital camera. I have
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries, place them back in the camera and give them a good charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Posted on Dec 07, 2009
Does anyone know what usb cord the sanyo VcP-S885 uses
If you mean the Sanyo VPC-S885 digital camera, that is a USB 2.0 A to USB mini-B 5 pin cable. Amazon has several replacement cables; one of which is here: https://www.amazon.com/Antoble-VPC-S885-VPC-S885p-VPC-CA200-Camera/dp/B01EV5KN7E .
I hope this helps.
Sep 15, 2016 | Sanyo Cameras
Card locked I HAVE A SANYO VPC-S885 TRYING TO THE PICTURES THE CARD SAYS CARD LOCKED. HOW DO I UNLOCK THE CARD.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 16, 2014 | Cameras
I need Sanyo Xacti VPC HD1000 LCD
http://www.fixya.com/support/t1813324-lcd_video_camera_not_working
Apparently you can take the LCD apart, look at the part number and order it online somewhere.
Try shopwiki.com
Feb 11, 2013 | Sanyo Xacti VPC-HD1000 Flash Media...
I am not able tu bring foto from my digital camera VPC S880 Sanyo to my pc. Would you be so kind to explain me ? Thanks
Hi sog_eudonna,
All you need to do is follow the below steps :-
Make sure that the camera is switched on ,
Install the sanyo software or driver which comes along with the camera ,
If you don't have the drivers , then , connect your camera to your computer in mass storage mode.
Mass storage mode can be selected from your camera as soon as you plug in your camera to you computer's USB port , but make sure that you have the camera switched on.
When you connect via the MASS STORAGE mode , you would be able to see a removable drive in your my computer option and hence you can open it and then find all your images inside.
Then select the images you want to copy and paste them either on your desktop or any other folder on your hard disk.
Hope this helps ..:) Let me know in case you have any queries.
Jun 19, 2011 | Sanyo VPC-S880 Digital Camera
My cemara works properly bun can not take picturs Sanyo Xacti DSC-S3 / VPC-S3 Digital Camera scince 2 months yes
chek the memory
if reqiuired...delete all the pics and then re-try
else change the memory card
do let me know...if u r getting any error msg
Feb 02, 2011 | Sanyo Xacti DSC-S3 / VPC-S3 Digital Camera
How do I set the date and time? Is there an operators manual on line to learn to use this camera?
Manual for your camera can be downloaded from official web page http://sanyoservice.com/pdf/images/VPC-S885%2520English.pdf
Jun 02, 2010 | Sanyo VPCS885 Digital Camera
I have a Sanyo VPC-s885 digital camera. I have reciently put new batteries in it. When I press the button to take a picture it tells me low-batteries and turns off..........any suggestions?
Dec 07, 2009 | Sanyo VPC-S880 Digital Camera
Sanyo VPC-T1060 Digital Camera takes like 10 sec. to take a pic!!! help plz!!
try changing the ISO ( ASA ) rating to 100 or put it on auto. I would think you have it set on a slow exposure . When it does take a picture what is the quality Overexposed or dark?
Jul 31, 2009 | Sanyo VPC-T1060 Digital Camera
Adjusting shutter speed
Hi - There is no direct way to set the shutter speed. This camera relies on the selection of a "scene" mode to automatically set the speed and aperture. All you can do is select the scene mode closest to your lighting conditions or the type of picture you are taking. Something to guide you are the speed & aperture numbers in the bottom of the LCD screen as per 11 and 12 in the picture below from page 7 of the manual:
The other thing you can change is the ISO speed see page 21 in the manual.
Experiment & let us know how it works out!
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 05, 2008 | Sanyo VPC-S7 Digital Camera
Instruction booklet
Hi - You can download the manual from the link underlined in blue below:
XCTI VPC-S60
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 22, 2008 | Sanyo Xacti VPC-S60 Digital Camera
Sanyo VPCS885 Digital Camera Logo
43 people viewed this question
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
