Question about DeLonghi Prima Donna Avante ESAM6700 Automatic Coffee Coffee Maker
General Alarm MY machine shows the General alarm message which is supposed to happen if the machine is dirty. But I have cleaned the inside and the diffuser regularly. Also sometimes the door opens on its own. Both these problems only occurred recently. My machine is 2 years old.
Fire alarm keeps going off randomly and there is no fire or smoke
What type of smokes detectors are you using. Is the Zone programmed correctly. Loose connection. Missising resister
Mar 09, 2014 | Honeywell Ademco Alarm 6150rf Keypad Lk
Cannot get the alarm to work
you may have turned the volume down for the profile you were using on the phone, try activating the alarm an whilst its supposed to go off turn volume up.
hope that works for you if it doesnt i dont know what else to suggest other than take it back to the shop where purchased and see if they can help
Apr 02, 2013 | Cell Phones
Viper 550esp
you must open the rem.con and clean the keypad switch, for dirty, dust, oxide, open contacts, CLOSED CONTACTS, or bad contacts.
test and clean with contacts cleaner. REMEMBER they send infrared signal to the SYSCON microcontroller from the receiver in this case ALARM.
If the problem persist, you must call to the company to the Alarm, since the Alarm has Syscon Microcontroller two options can be happen a) power supply defective b) Syscon Microcontroller y/o peripherical circuit faulty.
God bless you
Jul 29, 2012 | Televison & Video
Screen Alert: General Alarm What does this mean
General alarm means the machine has detected a serious fault. There is a section in the instruction manual that may help. If not, read on.
Persistent "General Alarm"
This means many things. If the transmission is not stuck, check the main boiler has not burnt out (open circuit). This happens when the thermoblock labyrinth runs dry and overheats, a common problem caused by leaks, limescale, milk blockages or water filter contamination. Replacing the boiler is the only fix, a difficult and expensive process, experienced fixers (or nothing to lose) only.
Transmission
If the transmission is getting stuck there may be obstructions, the lead screw may be worn or the limit switches could be faulty. If cleaning and grease on the screw/bearings don't help then replacement is a tricky job only for confident hands. Approach with caution.
Aug 25, 2011 | DeLonghi Magnifica 3300 Espresso Machine
My acura 3.5 RL 99 will not start properly. I even change the gaz pump. After starting, it dies after 2 seconds. No gas goes through I noticed before some problem with the alarm system. When the alarm...
there are many things that can cause stalling a dirty iac (idle air controller) is just 1 of them, clogged fuel filter is another, water in the fuel, clogged air filter, and don't even get me started on alarm systems, especially after market alarms can all cause issues, it could also be a bad mass air flow sensor.i would go least expensive to most expensive, start with cleaning things before replacing them
Apr 15, 2017 | 1999 Acura 3.5RL
There is a General Alarm alert and after cleaning, the message still stay.
sounds like pcb assy fault... or check u have all parts in correctly ie tray ,bucket ect. bsc appliances 07779933829 postal service too .
Jan 31, 2011 | DeLonghi EAM3400 Espresso Machine
Eam3500 delonghi coffe machine
From page 21 of the owner's manual: Message: general alarm. Meaning: The inside of the appliance is very dirty. What to do: Clean the inside of the appliance thoroughly, as described in section 15. If the message is still displayed after cleaning, contact a service center.
Hope that all your machine needs is a thorough cleaning; it's not that difficult.
May 29, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
My Delinghi eam3500 has come up with general alarm, I have cleaned the unit like it says but it is still not working, when it turns on it says warming up, but it tries to warm up for ages but nothing...
The general alarm message after the machine taking too long to heat up -in deed shows a problem to reach the correct temperature.
So there are a number of possible causes:
the 2 heaters (water/steam) the NTCs(temperature control sensors)
the tempearature overheat-fuses. In my case it was the (water-)heater itself. Be sure to unplug the machine from power supply befor opening!!!
First test then-do the heaters warm up??.....carefull if they do-they are hot!!! If one of them doesn´t warm up- Unplug again!...and then measure the resistance of this heater-If the heater is ok,it should show around 50-58 ohms. If it shows indefinite resistance the heater is broken and you have to exchange it.
In case of both the heaters showing the~50ohms you will have to check the thermal resistors/fuse/NTC.
For me the two forums below wer of great help for me...of course they are in german...but didn´t you wish to learn a foreuage anyway???
Good luck and best regards
Wolfgang
Ref,:http://www.kaffeevollautomaten.org/forums
http://www.kaffee-welt.net
Dec 01, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Fujitsu M4097D error about Front side optical alarm
HI,
I work on the fujitsu scanner hotline. This message means that the optical unit needs to be replaced, there will be very little you can do to fix this problem.
Apr 06, 2008 | Fujitsu M4097D IPC Path-Through Flatbed...
DeLonghi Prima Donna Avante ESAM6700 Automatic Coffee Coffee Maker Logo
20 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
