Question about Boating
Push button to turn plow to right plow turns left
  • 104 Answers
SOURCE: snow plow wont turn right
To turn Left you need two cylenders. I think you only have one. Any one cylender will have three wires and a ground. The ground is always connected to the vehicle ground. The other two to the Single pole double throw switch. TOne wire and a ground runs the pump one way, the other wire and the ground runs the pump the opposit direction. For left and right you must have a similar pump, motor and wiring.
Posted on Feb 07, 2009
  • 114 Answers
SOURCE: I have a meyer e47 snow plow and when i touch the
I would check the hand control box it sounds to me like an electrical problem, if you know a dealer, plug in a new control box, this should narrow it down.
Posted on Jan 13, 2010
  • 109 Answers
SOURCE: left turn signal not working proper
Turn signals flashing is the confirmation of alarm system being on.I thought both sides flashed but if alarm is faulty guess that's messed up too. Try starting from stratch with alarm,disarm it[disconnect neg wire at battery]then reconnect wire and when that sets off alarm turn it off in normal way.That should get things back on track.Plus,try replacing the flasher unit,don't know why this works but I've heard of it.
Posted on Mar 28, 2010
  • 198 Answers
SOURCE: i put my hazard fuse in a my right turn signal
Unfortunately you need a new bcm, the car will have to go to the dealer. Replacement bcm and reprogram your immobilizer and remotes
Posted on Jul 31, 2010
  • 45036 Answers
SOURCE: I have a 8ft Fisher storm guard plow on my dodge
Duplicate
Posted on Nov 29, 2012
Western plow will not go left
There is a hydraulic block/valve. Replace it.
Jan 03, 2017 | Cars & Trucks
I have a fisher minuteman plow it will go up, left and right but will not go down what is wrong with my plow
If you have a Minit Mount two it's probably the valve sticking. It's electronically controlled so if it clicks, then the solenoid is working and the shuttle in the valve is stuck. Can be disassembled and cleaned. New ones are best but pricey.
Jan 24, 2015 | Cars & Trucks
Fisher plow lock up when training right or left.
Have a 2004 hmm and plow went up and down but jerked left to right but did not turn , found it to be wire harness going thru fire wall , sheet metal wore thru wires shorting them out , pulled harness thru and shrink rapped and hooked back up been working fine.
Nov 14, 2014 | Cars & Trucks
When i try to lift or angle my plow all i get is a clicking sound when i push the lift button and when i let up on the button the moter on the hydrolic unit will click but will not move the plow. minute...
Not familiar with model, but valves click at the same time motor is suppose to run. Check power and ground to motor (or try running it with jumper cables, but don't be where plow can angle and squish you. If good power but won't spin, clean brushes/commutator/check bearings in motor.
Aug 15, 2014 | Cars & Trucks
When plow is turned all the way to the left it will not turn to the right . if i center it by pushing a pile it will turn right or back to the left it has no problem turning to the right from center and...
Smeenker,
My head is spinning after reading this.
Can you please simplify your question, and include manufacturer, model number, and any other useful information so that we may assist further.
Thanks!
Feb 13, 2018 | Garden
I have a 2003 f-250 with a curtis sno-pro 3000 hitch n run plow system. when i go to lift plow or go left or right it kills the truck. the light shut off and every thing else as soon as i hit any of the...
I think you have a problem with the plow motor grounding out. when you raise or turn plow in either direction you have to run the plow motor which is grounded out. ( as in hooking the ground and positive together directly ) the plow is on a gravity drop when you let it down by the weight itself and does not require the motor for the plow to operate. It's your plow motor or the positive feed to selonoids.
Feb 05, 2011 | 2003 Ford F250 Super Duty Crew Cab
Snow plow wont turn right
Jan 06, 2009 | Plumbing
Boating Logo
71 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
