Question about Vacuums
Vacuum Manuals how to change the bag in goblin rio 1100
2 Suggested Answers
  • 5370 Answers
SOURCE: cannot find a way to
Rotate the cardboard neck of the dust bag counterclockwise while pulling it toward you. Continue doing this until the dust bag comes free of the socket inside the vacuum cleaner. Dispose of the dust bag in the trash.
------ You will see the dust bag housed within the vacuum, connected by a square cardboard collar on the bag to a connector tube on the machine. Pull the collar away from the connector tube and remove the dust bag from the vacuum. --------------- Replacing the dust-bag :---1) Press and release catch for the dust compartment lid and raise the lid until it clicks into place.The dust-bag has a collar which closes automatically when the dust-bag is removed to prevent any dust escaping. ---2) Holding the bag by the collar , lift it away from the suction socket and then pull it out of its holder. The dust-bag can be disposed of with the normal household waste as long as it has only been used for vacuuming up normal household dust and not hazardous materials. Do not unfold the bag when you take it out of the packet. Keeping it folded will prevent it from getting trapped when the dust compartment lid is closed. ----3) Slide the collar of the new dust-bag into the empty holder until it is secured in position. ------4) Close the dust compartment lid firmly. When the lid is closed the holder automatically draws the bag collar over the inlet stub. ---------- This will help.Thanks.Helpmech.
Posted on Aug 20, 2011
Bag was full, changed it, the unit now turns off
Try dialing the control valve to the mid way position. If the unit still shuts down with the bag full light on you have a damaged control valve under the dial on the top of the vac.
This valve failure is common in this model and can only be repaired by someone with original AERUS Electrolux repair parts, generally at an AERUS repair shop.
Oct 29, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Bag change indicater staying on and vacuum smells hot when using
I suspect there is a blockage somewhere along the pipes leading to the dust bag.
The bag full or bag change indicator measures how strong a vacuum is present at or near to the point where the bag is connected to the pipes. Under normal conditions an empty bag poses little resistance to the air passing through and therefore causes only a slight vacuum. A full bag poses a lot of resistance and therefore causes a strong vacuum which in turn makes the indicator show time to change.
If, however, there is a blockage somewhere, regardless of the state of the bag, a strong vacuum develops which causes the indicator to show as if the bag is full.
The hot smell is proably a result of the motor having to work hard trying to overcome the blockage.
Try to look into all the pipes - you may need to do a bit of dismantling and/or strech out flexible pipes to do so - to see if there's anything stuck. Also try some (careful and gentle !) poking through the pipes with something like an un-ravelled wire coat hanger, but take great care when poking through the flexible pipes as these can be ripped and then you'll have a differnt problem !
Sep 16, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Bypass on/off switch
Cut the wires, strip them about 1/4 inch on ends and twist them together if you are just going to plug in and turn on
Jul 20, 2009 | Vacuums
How do I find the opening to change the bag on the Riccar RC 1100
Just above the hole where the hose goes there's a squarish part to where your hand should go. It should just pull upwards.
User manual download (FREE and in pdf form:)
http://www.riccar.com/ftp/whitepapers/1100_OwnersManual.pdf
Jun 17, 2009 | Riccar RC1100 Compact Vacuum
Need instruction manual for goblin 1400 2in1
I have a hoover steam cleaner (f5835)didnt get instruction-I tried to use it with water(hot) and cleaner- >>when I finished nothing in the bottom- I did use water and cleaner??what I did do wrong? Could I get manual- I thought I had it in the box- but it instruction how to put it together Betty Smith- BJ_SMITH@ATT.Net
Dec 02, 2008 | Vacuums
Electrolux Renaissance canister
there are a couple situations to this issue. one is the bag that was replaced is a incorrect one and it is not meeting the switch for the bag pop circuit. some over the counter bags cause this issue. another problem could be the switch itself. or the bag door not being tight enoug to make contact with the bag.
Aug 07, 2008 | Electrolux Lux 5500 Canister Vacuum
My Miele vacuum full bag indicator
Check the suction at the vac, without the hose, if it is strong, then you hose is clogged. If it is weak, filters could be the problem, one is the back where the bag sits, the other is on the top, you can see it when you raise the lid.
Dec 07, 2007 | Vacuums
Vacuums Logo
82 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
