Question about Amana AMV5206 Microwave Oven
Amana AMV5206AAQ light on the bottom of the microwave out
How do you replace the bulb under the bottom of the microwave.
It has a cover and you can unscrew the plate covering the bulb and then what. The bulb does not just pull out. It looks like it is a complete unit.
Thanks in advance for any assistance.
Carl
I received an email telling me to pull the bulb straight out of the socket. Sometimes they can be hard
to pull out. It worked, I appreciate it.
Thanks, Carl
Posted on May 08, 2009
  • 32 Answers
This is the replacement: Lamp, halogen
It pulls straight out of the lamp socket and the new can be pushed in.
Go here for more
RepairClinic.com
appliance parts, help & more
How to replace light bulb in microwave model MMV5208WW-1
The support page with free manuals is here.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MMV5208WW1&siteCd=WHRCOM&userType=Consumer
The owner's manual says:
Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove two screws on the vent
grille, tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws.
Cooktop light: The cooktop light bulb is located on the
underside of the microwave oven, and is replaceable. Remove
bulb cover screw, and open the bulb cover. Replace bulb,
close bulb cover, and secure with screw.
To remove the grille, see my video at microwavecontrol.com.
Sep 28, 2016 | In Microwave Ovens
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
How do you change the light bulb under the microwave?
put the bulb of microwave down . and then install a new bulb on it .before do these .you should turn off the switch .
home light bulbs
May 02, 2012 | GE JVM1650 1000 Watts Microwave Oven
Light won't go on; Model MMV1153WB-O
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Enter it as MMV1153WB0 (no dash, zero on the end, not "oh")
Or just get it here, to be more exact.
On page 4, it says:
"Installing/Replacing Filters and Light Bulbs
■ Grease filter: Grease filter is on the underside of microwave
oven. Clean monthly. Slide the filter away from the tab area,
and drop out the filter. To reinstall, place end of the filter into
the opening opposite the tab area, swing up the other end,
and slide it toward the tab area.
■ Charcoal filter: The charcoal filter is behind the vent grille at the
top front of the microwave oven. The charcoal filter cannot be
cleaned, and should be replaced about every 6 months.
Remove 2 screws on the vent grille, tilt the grille forward, lift it
out, and remove filter. To reinstall, place the filter into its slotted
area – wire mesh side up, replace vent grille, and secure with
screws.
■ Cooktop light(s): The cooktop light bulb(s) is(are) located on
■ Cavity light: The cavity light bulb is located behind the vent
with screws."
HINT: Unplug the oven before removing or installing the bulbs, or you may need this service.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. Hope this covers it.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
May 06, 2010 | Maytag Over-the-Range Microwave
Replace microwave light bulb
See page 24 of the owner's manual here:
Feb 06, 2009 | Amana AMV5206 Microwave Oven
Trying to replace a light bulb on an amana microwave
The lamp on this model is an assembly - bulb and socket mated together.
It is mounted in an air duct on the right side of the oven near the magnetron.
You'll have to remove the outer cover to get to it.
You can find helpful exploded view diagrams and order the bulb by entering your full model number here.
Dec 09, 2008 | Amana ACM1580AS Microwave Oven
How do I change the light bulb in an Amana microwave model# ACM1580AS?
The whole metal cover should be removed, 2 special tamper proof screws are at the bottom back end use a small screw driver to pry or break the center post and then use torx screw driver to take it out, the bulb is a specialty bulb available in partselect.com for almost 30 bucks. good luck!
Jun 20, 2008 | Amana Microwave Ovens
Amana AMV5206 Microwave Oven Logo
155 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
