Question about Dryers
Designers choice ceiling fan remote
I find I am unable to press the button to turn on the light. If I press hard and wiggle it sometimes it will light, then I have a hard time turning it off, do you have a solution?
    Genius:
  • 1,617 Answers
Make sure the antenna wire is visible from the receiver.
Cheap fan = cheap parts
Posted on Nov 26, 2013
SOURCE: Ceiling fan and lights with remote control
I got a new reciver installed in ceiling fixture,works fine:Boytin
Posted on Mar 25, 2008
johnny5846
  • 379 Answers
SOURCE: ceiling fan remote will not turn on light
common problem , i went to home depot and bought a new remote for my hunter fan , and it worked again , salesman was very knowledgeable and helpful . thanks. explain the problem to him , he can help .
Posted on Dec 30, 2008
KMusselmann
  • 247 Answers
SOURCE: Hunter ceiling fan type 3 not responding to remote
Sounds like the black wire from the fan is not properly connect(lose)
Here is an example wiring diagram
Posted on Mar 17, 2009
jmgldsmth
  • 1889 Answers
SOURCE: remote controlled ceiling fan
unplug the fan then remove the batteries from the remote then plug the fan back in and, reinstall the batteries; this resets the fan control
Posted on Apr 22, 2009
  • 323 Answers
SOURCE: remote not controling fan
You either have a bad receiver or the receiver isn't wired correctly,
On the receiver house wire side are black, white, and green.
On the receiver fan side are white, black, blue, and green. The black is hot for the fan, the blue is hot for the light. They can be wired together from receiver to fan.
At the bottom are a blue and a white wire to go to the lights.
Sometimes when installed the receiver is placed so that a part of the wiring box obstructs the signal from the remote and it doesn't work properly, or misses some commands.
I recommend buying a new remote and receiver and wiring the receiver in so that it rests on the sheetrock beside the wire in box.
Posted on May 26, 2009
How do you work the remote for designer's choice m8crl103. I recently purchased a home with the fan and remote but the prev. owners' dog damaged the remote's display so I can't see the screen. I got the...
If the light has a pull chain, pull it once and then push the light button on the remote. I think this is an add on remote so you can buy a new one if that doesn't work. Or, you can buy another fan as this is a low-end Hunter fan.
Oct 05, 2013 | Hunter Designer's Choice 5-Switchblades Lg...
Designers Choice Ceiling Fan Manual
All Hunter fan model numbers are 5 digit and start with a 2. Are you having a problem with the fan?
May 16, 2013 | Hunter Designer's Choice 5-Switchblades Lg...
Hunter Ceiling Fan Remote Works Sporadically
The part that receives the signal from the remote control is the receiver which is located in the motor housing.
Apr 29, 2017 | Hunter 27148 Remote Control
My Hampton Bay Brookedale ceiling fan worked fine for a while. Went to turn it on the other day and won't work. Ceiling fan remote seems to work (light goes on when buttons pressed) but fan or l
The light on the remote is a battery light. First mistake was buying a store brand fan which are mostly low-end parts. Try adding a different remote w/receiver.
Mar 02, 2013 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
How to use remote on ceiling fan id m8crl 103
Press the light button and bottom green button at the same time the lights dimming feature will work!
Mar 09, 2012 | Hunter Designer's Choice 5-Switchblades Lg...
The batteries ran out on our designers choice ceiling fan...now wont work. how do i make it work?
replace batteries. While holding the light button, turn the wall switch go and off one or two times. You should hear a slight beep and the remote reacquaints itself to that receiver.
Jul 22, 2011 | Hunter Designer's Choice 5-Switchblades Lg...
I have a Designer's Choice remote ceiling fan. I removed it from my mom's house and reinstalled in my house. However, the remote no longer controls the fan and lights. How do I reset the remote? My mom...
With mine, I turn off the full power and back on and it starts beeping and and press any button on the remote and it finds it and does a couple confirmation beeps.
Aug 31, 2009 | Hunter 52" Ceiling Fan With Light And...
Ceiling fan remotes
If you know where the remote receiver is located on the fan (probably in the canopy or the compartment where a light kit would attach), you may want to see if you can find the wire antenna that is hanging off of it. If possible, run that wire outside the canopy so it is exposed, this might give you a better response.
Dec 23, 2008 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan w/ remote won't work
You need to change the receiver inside the fan. It is located in the top canopy of the fan. you don't have to buy a new remote just the receiver to save money and match the dip switches to the remote.
Nov 13, 2007 | Dryers
Dryers Logo
65 people viewed this question
Top Dryers Experts
