Question about Cross Measuring Tools & Sensors
Gibson furnace error codes - Cross Measuring Tools & Sensors
Have Gibson furnace runs cycle but seems don't get hot enough out of vents check all 115 degrees at vents use to lot hotter old furnace you couldn't stand on vents now you can easily
Is this a gas furnace ? Newer high eff. gas furnaces do have cooler outlet temperatures. The installer should have checked the temperature rise and gas pressure. By adjusting the gas pressure and blower speed you can obtain a higher outlet temp, but you don't want the gas pressure to be higher than the manufacture specs and you don't want the furnace to run outside of the manufactures temp rise specs.
Mar 02, 2017 | Gibson Heating & Cooling
My 2005 Gibson furnace overheats in a really cold night, stops and has to be restarted manually. A 1-square foot hole was cut out to feed more air but the problem persists. What is wrong?
There are over temp and roll out sensors on the unit. They may be weak, or you may have a problem with flame adjustment, etc. Where did you cut that hole? The air flow has to be balanced in the room where the furnace is, if you have the furnace drawing in air from the room and not through the cold air return you run the risk of CARBON MONOXIDE being drawn out of the flue into the air feed and this can poison anyone in the structure.
Jan 22, 2017 | Gibson Heating & Cooling
Amp fuse keeps blowing
The component being protected by the fuse is drawing excessive current - has to be a board or something because the motor always draws more than three amps. Check the units schematic for locating the possible offending board. Must be relatively new since you indicate it is multispeed. Still under warranty?
Feb 23, 2014 | Gibson KG7SA045C23A 45,000 BTU 80% Gas...
My gibson furnace geves the error L1 neutral polarity
This means the hot ( L1 ) and the neutral connections are reversed.check the 120 volt power to the furnace for the correct polarity also make sure there is a good ground connection. Hope this helps.
Dec 07, 2013 | Heating & Cooling
Gibson LP furnace flashes 2 flashes
should be a chart on unit that will tell you what this is then you can test the part to see if that is the problem, but most of the trouble codes are roll out switch or main lemited switch on two blinks.
Oct 31, 2012 | Rinnai RHFE-431FAIII 16,700 BTU Direct...
My gibson furnace is about 8yrs old and it was working fine heat was on yesterday morning but last night it stopped. Changed batteries in thermostat which in new(thermostat) but no heat. Checked the vents...
Look on the back of the bottom cover... it should tell you what the blinking means...
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Feb 03, 2011 | Gibson Heating & Cooling
My Gibson Furnace clicks on but no heat comes out.
After four years I do not thing you have an effective warranty even if the company still in business. you need to open it first and clean it from any builod up dust and check the switch to see if it is working (thermostate)
Nov 08, 2009 | Heating & Cooling
Measuring Tools & Sensors Logo
Top Cross Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Cross Measuring Tool and Sensor Expert? Answer questions, earn points and help others
