Have ideal c28 combi boiler no hot water when turn on hot tap have to turn boiler on at programmer for heating then turn on hot tap to get boiler to fire up for hot water and heating also temprature gauge needle has fell back to zero and does not register when boiler is running.
SOURCE: ideal response 120 seems to fire up but burner
If this an older style boiler remove thermostatwires
at boiler terminal board and put jumper between R and W, if boiler starts you have bad thermostat.
If it does not come on then it appers that you have
a problem with the spark ignition or glow coil is
bad
SOURCE: boiler making clicking noise
contact baxi and ask ther service people there was aproblem with this but i cannot recall it now ,hopethis helps
SOURCE: ravenheat he85aaa combi boiler running fault
sounds like low water pressure, check pressure guage, get unit serviced
SOURCE: hi, my ideal combi boiler model mini HE C28 goes
Hi check the flame senser is in postion and clean
