My printer says it is offline and will not print
My printer is offline
  • Sandra Craig
    Sandra Craig May 08, 2009
    yes but did not work for me
  • 413 Answers
Check the settings for printer in control pannel and set it to default and edit the status as online
Posted on May 08, 2009
HOW TO FIX...PRINTER IS OFFLINE BUT IT IS ON...WE ARE UNABLE TO PRINT.
If you are getting a status message as the printer is offline on your pc,and afterward you can't ready to print the reports.
Steps to Resolve the Printer Offline Issue:
Step 1:
At first, you need to check your network through the HP Scan Doctor which encourages you to discover and fix the printing issues.
Steps To Run the HP Scan Doctor
    •Open the HP Scan Doctor tool by double tapping the symbol.
    •Start- - >Select your printer- - > Fix Printing
    •Then the list of issues displayed on the screen as result.
    •If the tool shows the white checkmarks at that point there is no issue.
    •If the tool shows the white wrench then the issues are found and repaired
    •If the tool shows the yellow shout point then the issues are found however that can't be solved or skipped.
    •If the device shows the red stamp then you have to take after the on-screen guidelines to determine the issues.
    Step 2:
      Set Your Printer as Default Printer
      •Search your gadget on your PC and select your printer and uncheck the Pause Printing and Use Printer Offline
    •If you can capable print implies your printer is online.
    Officejet 4650 keeps going offline then proceeds with following step Step 3:
    Check Whether You Connect With Correct Port
      •Go to printer- - > Printer Properties - >Port
      •For USB association utilize USB or DOT4
      •For Network Connection use WSD, organize, Standard TCP/IP Port Step 4:
      •Update the printer firmware which may resolve your issues
      Step 5:
      •Manually connect the wired or wireless connection
      Step 6:
        •For network connection just you have to add the second printer to your Windows.
        •Select your printer - > Properties - >Add Port - > Standard TCP/IP Port - > Next port
        •Now you can ready to print implies stop the troubleshooting. Still get the same issue mean you need to connect the printer customer support via +1-800-836-3987
Jan 08, 2016 | Office Equipment & Supplies
Will not print. it says printer is offline
Have you tested the Cable ( maybe test with a replacement)
under your devices and printers is the checkbox on use offline, printer - see whats printing - printer - uncheck use offline
Apr 05, 2014 | HP Officejet Pro 8600
Printer offline
try to go in and mark the printer as online and the printer should come up as in ready state
Mar 16, 2014 | Epson NX625 AllInOne InkJet Printer
Trying to print 'offline'. Computer recognises it is offline but will not print. Error message says 'Printer is offline' which is as it should be. Printer is HP photosmart C4580.
So, if you want to print, the printer must be online. Offline method doesn't work to print. When the computer sayst that the printer is offline, it means ypur printer is turned off or you don't connected the printer to PC.
As in conclusion, if you want to print set the printer online.
Oct 05, 2009 | HP Photosmart C4580 All-in-One InkJet...
Printer status says offline, and we can not print on laptop
Hi!
If you're offline with the printer, you definitely won't be able to print.
I'm assuming you're using Windows XP here. Most Windows products will be similar...
On the laptop, click on the Start button, then Settings, then Printers and Faxes. Find your printer in the list, right-click on it and click "Use Online" or uncheck the "Offline" box.
Good luck! Remember to rate the solutions!
Aug 10, 2009 | HP Officejet 6500 Wireless All-in-One...
SHARP AL-2040CS offline after reboot
Official Sharp driver had set "use printer offline" setting in the printer properties context menu. After unselecting the "use printer offline", printer is printing again, even after reboot...
Jun 17, 2009 | Sharp AL-1540CS All-In-One Laser Printer
I was trying to print using a PIXMA iP1300 but it doesn't allow printing withe a message box appearing "printer is offline".can you help me please
Printer offline : make online in printer properties.Printer offline when start to print : head problem. Replace head.
Jun 12, 2009 | Canon PIXMA iP1300 Printer
Printer won't print says it's offline
hi friend
this is very common problem for f300 series PSC
just delete the printer from printers and faxes and reboot the machine it will install printer again
there is funny thing abt this series it is saying offline when powered on and connected but when you disconnect iit will say "offline-use printer offline"
please try my solution and rate it
thanks
Apr 04, 2009 | HP Deskjet F340 All-In-One Printer
Nothing happens when i tried to print from my computer the status is offline what is wrong
same thing, woring one minute, next minute, offline. cords plugged in , no reason i have found but it happens all of the time
Sep 02, 2008 | HP DeskJet F380 All-In-One Printer
Offline problem...won't print
Unplug it and then re plug it in; I suggest USB connection over anything else; don't worry about self install if you already have done so in the past. In the print > hit properties on the icon for bubblejet > go to the ports tab > scroll all thw way to the bottom and click the "USB" checkbox. and you should be good.
Aug 27, 2007 | Canon BJC 2100 InkJet Printer
457 people viewed this question
jasbo
jasbo
