Question about Dryers
WED8300SWD no heat F22
I have a Whirlpool Duet Sport dryer about 6 years old that works but has no heat. The problem started because of too much lint. I have since replaced the heating element and both fuses on the side of the element and the thermistor and the thermal fuse. Still no heat.
  • Dryers Master
  • 16,238 Answers
You have done a nice job replacing all the things that it might be. Now you need to check continuity through all those things and from the source. Please make sure that it is unplugged when you do this.
Posted on Nov 25, 2013
Testimonial: "I have had a friend over that checked with an Ohm meter and said that said that everything has continuity"
ronpar
  • 27 Answers
SOURCE: Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Posted on Jun 29, 2008
protek480
  • 1714 Answers
SOURCE: whirlpool leb6000pq1 not heating
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The elecment has a contact in
the 'timer' circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
restricted.
Posted on Jul 12, 2009
aasc
  • 1606 Answers
SOURCE: Whirlpool duet electric wil not heat
Remove 1 wire from the element . Your 220 V comes from ...110 motor , 110 control board . Check which wire is not getting 110 V , trace it and see which it comes from . That will tell you which one is defective .
Posted on Aug 01, 2009
  • 103 Answers
SOURCE: i have a kenmore he4 no. 110.85871400. i have no
Check thermistor with ohm meter, make sure you unplug unit first, make sure wires are removed from thermistor or you will read ohms thru the wiring. If thermistor checks ok, the you have a relay board problem. replace power board.
Posted on Oct 01, 2009
dmftrucker
  • 1922 Answers
SOURCE: whirlpool GEW9200L not heating up, i have replaced
not being sarcastic, but, your sure you have 240 volts present at the unit? then check door switch heat section control of switch may be bad
Posted on Oct 09, 2009
Are there reset button on the motor
Whirlpool duet sport F21 error code fix - YouTube
? 4:39
https://www.youtube.com/watch?v=qQTvBSnEWsI
Feb 22, 2010 - Uploaded by heli400
Also note TROUBLE SHOOTING MANUAL IS TAPED TO THE ...I have replace 6 detergent ben hose 1 motor the membrane on thebuttons .... I've owned the washer for 6 years and I never knewthere was a filter underneath!
Whirlpool & Kenmore Dryer Repair #02 - Won't Start or Run ...
? 7:29
https://www.youtube.com/watch?v=SPRqKVE8JfY
Oct 21, 2011 - Uploaded by canyonman1963
I have a Whirlpool Duet MOD GEW9250PWI It's not making any noise, ... only" I've unplugged it and plugged it back hoping it would reset it. ... The service man I use stated it was the motorgoing bad, the smell of ... i checked the door switch, it was fine too i believe. so thermal fuse ... There still is not start up.
Nov 28, 2015 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool duet electronic gas dryer noy heating up
You need to excess the back and unplug and put vacum hose through vent hose to dryer and use a wet/vac it has to be clogged.Is the dryer lighting up,you also may want to get a applance tech. thats gas certifed.to check it out
Jul 17, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool dryer duet sport MOD WED8300SW error message
I have a whirlpool duet sport electric dryer with an error code of F 26.
Mar 02, 2010 | Dryers
Brand new Gas whirlpool duet sport drier will not heat up. Gas line hooked up correctly HELP
Good day,
If it's new, and your sure there is gas in the line to the dryer, then you are entitled to a service call under warranty.
Whirlpool warranties it's dryers for one year from date of purchase.
Call your selling dealer. New one's won't work sometimes.
Dec 31, 2009 | Whirlpool Dryers
Trips breaker: Whirlpool Duet Sport front load dryer
could be a faulty stat or element,get an engineer to test the dyer, he will check insulation on the element, could try replacing the element that just might sort it
Sep 21, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
We have had our Whirlpool Duet Electric Dryer (front loading) for about 2 months. It is showing an error code of F22. I have no idea what this code means nor how to fix it.
the f22 code is a failed thermistor. you can try to change this yourself but if the unit is less then a year old then it will be covered by warranty.
the part is only about 30 bucks so if you can get one and find it behind the lint screen duct then you could change it and fix the problem.
Jan 06, 2009 | Dryers
Whirlpoo; wfw9200 F22, F28, A17 A27 error codes
f22 is a door lock error and f28 is a commication error you still have warranty thorugh whirpool. you're going to need pro. help
Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
3 1/2 year old Whirlpool Duet Dryer stopped heating up
it could be several things but the element could should be the last part i would check first if you are still using fuses change them both if that doesnt work call for service call a good service man stay away from major companies they are expensive i know i worked for most of them
Nov 22, 2007 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
121 people viewed this question
Top Dryers Experts
