Question about Electrolux EI28BS56IS (278 cu ft) Bottom Freezer Commercial French Door Refrigerator
Ice Melting towards the front of the ice hopper
I've got an Electrolux EI28BS56IS1 bottom feeder fridge that has had all the problems with the ice maker. Finally got it working, except it won't dispense anything but cubed ice. Then, in the last couple of months, I've got water leaking from the ice maker. It appears that the ice towards the front of the ice hopper is melting when it is fuller. Took the dispenser mechanism apart and made sure the flapper was seating properly and was clean. Fridge temp is set to 1 degree. Anybody have an idea as to why the ice is melting in the front of the hopper? The ice seems to not melt if it is mainly in the back of the hopper and not full.
  • 960 Answers
Check that the fan motor wiring has not been disturbed. If the freezer fan is not working, the fridge will generally start cooling but due to poor air circulation , it will stay colder at the back but will get warmer at the front hence causing the ice to melt. The usual temp for a food compartment is around 4 degrees. The freezer should be -18 degrees celcius.
Posted on Nov 25, 2013
  • 949 Answers
SOURCE: WATER DRIPPING IN DISPENSER TRAY DUE TO ICE
Hi Don,
Typically this occurs when the dispenser door does not close all the way.
The dispenser door is located in the freezer door in the chute that the ice dispenses down.
With the freezer door open shine a light up from the outside and look down into the door from the inside. If you see light around the door flapper, you will need to replace the dispenser door, if there is a large gap between the dispenser door and the chute you will need to replace the mechanism that controls the door.
Posted on Apr 18, 2010
Sea Breeze
  • 4654 Answers
SOURCE: i have an electrolux double door freezer on the
That is simply your dual water control valve found on the back of most refrigerators. If I had your model number I would be able to point out the part number and location. Here is what happens. The water valve begins to slowly leak water that comes to the ice maker when not needed. It moves slow enough that it begins to freeze solid inside the fill tube to ice maker and when the ice maker calls for water there is a big chunk of ice in the way and the water goes everywhere but where it should. Here is a short clip with lots of info, Please Rate and Thanks, Sea Breeze
Posted on Apr 28, 2011
  • 2006 Answers
SOURCE: Electrolux EW28BS71IS French Door Fridge no water and no ice
First check that you have good water pressure to the water valve. If you do, then the problem is in your refrigerator. And the most likely fault is the solenoid controled water valve which is a one in two out valve. Follow the water line from you house input and the first place it connects is that valve.
Posted on Jan 10, 2012
fudge_david
SOURCE: Ice maker not working
my icemaker has a wire overfill sensor which shuts off the icemaker if there is too much ice in the basket. If this wire gets pushed up it will stop making ice until level lowers OR manually lowered.
Posted on Feb 10, 2012
  • 884 Answers
SOURCE: Water and Ice Cube Dispenser not working
Water supply problem most likely. Check inlet solenoid and filter
Posted on May 15, 2012
Why does my daewoo fridge freezer works intermittently ?
You either have a faulty thermostat, a loose connection or most likely a build up of ice inside the freezer. I had the same problem. Almost replaced fridge. Took all the food out one day, took out the racks and disassembled bottom and rear and found a two foot log block of ice inside air return. Removed ice everything works perfectly.
Jul 22, 2014 | Daewoo Freezers
Electrolux will not stop making ice.
Sounds like the ice level switch is either jammed on or is faulty.
Look for a flap of some kind that rests on the ice when it's made. Should be located at the back of the hopper.
Jan 07, 2014 | Refrigerators
I have a GE Profile fridge, top freezer. Ice buildup keeps blocking thew evaporator fan. I've defrosted 2x, checked evap drain for blockage. But ice buildup reoccurs after 2-3 days. Turning up the
You have a defrost problem. Locate your defrost timer while the unit is iced up and turn it until you hear a defined click. At this point open the freezer and listen for ice cracking. If Ice starts cracking then it's your defrost timer bad. If ice doesn't crack, then you have a defrost component bad ( heater and Bi-Metal) Ohm out your heating element and replace if there is no continuity. You can usually find defrost timer either under the front of the box, in the fridge around the light or thermostat or sometimes in the back at the bottom. The dial on the timer can only be turned one way with a large flat head. You will hear the difference in the way the clicks sound for the defined click. Good luck.
Mar 09, 2013 | Refrigerators
I have an Electrolux EW28BS71IS and I have water dripping from the ice maker. When I take the ice maker tray out it has water sitting in the bottom of it. I can't tell if it might be overfilling the...
i have an elecolux ice maker leaks water into the bottom trays from the back of the fridge and water always drips from the front dispenser. the ice freezes in a solid block can anyone help me please. ew23bc71is3 is the model double door freezer on the bottom tks.
Mar 31, 2011 | Refrigerators
My whirlpool gold side by side refrigerator forms a big peice of ice at the very bottom then the ice ends up melting and goes all over the floor whats wrong?
the drain in the back of freezer is blocked
dismantle front of evaporator and deice drain
maybe so hot water over this should fix problem
whendrain is clear water should run donwn hole and collect in evaporator tray under fridge
you may need to mop up after you finish
Nov 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
After replacing the water filter on teh feeder pipe to teh fridge/freezer the ice maker has not re filled with water. It was full of ice and in the on position when the water filter was replaced. The...
If it is an inline filter make sure the directional arrow is pointing towards the ice maker. If it is a bowl type filter make sure the gasket is in place and is not twisted or not seated in groove properly. You may need to "cycle" the ice maker manually. Take the front cover off and carefully rotate the large gear in the direction of the arrow if there is one. If not, try rotating in one direction first, if it won't move go the other way until it starts turning on its own. This should cause the cube mold to fill with water and continue automatically on its own.
Aug 30, 2009 | Refrigerators
Not making ice
FROM WHAT I UNDERSTAND IS THE FRIDGE IS MAKING ICE BUT JUST NOT MAKING VERY OFTEN.THE PROBLEM COULD LIE WITH THE ICE MAKER AS YOU SAY THE ICE IC CLOGGING UP THAT COULD MEAN THAT THE ELEMENT IS NOT SEMI MELTING IT FOR IT TO DROP INTO THE HOPPER.BEST YOU HAVE A TECH SERVICE AND REPAIR THE ICE MAKER.
GOOD LUCK.
MOHAMED
Aug 24, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Fridge freezer
there is a fan inside freezer behind back panel. if pipework behind panel is covered with ice, it will prevent air circulation and the fridge is affected first
take back panel off and check for ice build-up and that the fan is working
Jun 23, 2008 | Electrolux ERN2820 Bottom Freezer...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Electrolux EI28BS56IS (278 cu ft) Bottom Freezer Commercial French Door Refrigerator Logo
169 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
