Question about Precor 956i Experience Series Treadmill (Used)
Precor c954i will not power up at all
Does not power up
3 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: precor c954i can speed up but cant reduce the speed
Dear Sir:
Please adjust the speed sensor see the diagram attached.
After RUN the software calibration for easy diagnostic and troubleshooting
See my personal TIPS FOR Help.
sincerely. God bless you
ernesto cuadra
managua, nicaragua.
Posted on Mar 31, 2012
ercupa190
  • 12223 Answers
SOURCE: My precor c954i displays message STOP KEY and will not run? How come?
1) adjust the reed swithc, clean , and tigh the wire connectors very well
2) run the software calibration for diagnostic and troubleshooting.
God bless you
Posted on Jun 20, 2012
My treadmill precor 954i showing stuck key. So what solution for this problem???
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
This is normally caused by a stuck key on your keypad. To resolve this issue, you must replace the keypad.
The following link may help, but you will need your serial number to find the correct item.
Repair Parts for Precor C954i Treadmills 120VAC 240VAC SPORTSMITH net
Nov 13, 2015 | Precor Exercise & Fitness
Diagrams
You can find the diagram for this model by using your model and serial number at the following link.
Jul 31, 2014 | Precor Exercise & Fitness
Why does my precor C954i keep shutting off
It must have been crossing its excess weight limit..
Jun 26, 2014 | Precor C954i Commercial Treadmill
Precor c954i error 16
Precor Error 16, AC Input Voltage Too Low Probable Cause 1. AC input voltage is incorrect.
2. Treadmill operating on undersized AC wiring and/or is drawing high current.
Corrective Action
  1. Verify AC feed into the building's circuit breaker is correct and connected to the proper transformer tap.
  2. The AC wiring must be sized to handle 20 amps of current over the loop length of the AC wiring. Voltage drop across the AC input wiring is a result of the length of the wire run multiplied by the amount of current being demanded by the treadmill. The longer the run and the higher the current the large the wire must be.Verify the unit is connected to an isolated and dedicated 20 amp circuit.
Precor Error 16
Sep 08, 2012 | Precor C954i Commercial Treadmill
God bless you
Jun 19, 2012 | Precor C954i Commercial Treadmill
Precor c954i can speed up but cant reduce the speed
Dear Sir:
ernesto cuadra
managua, nicaragua.
Mar 30, 2012 | Precor C954i Commercial Treadmill
What does error 29 mean on a precor C954i?
Precor Error 29, Excessive AC Input Current Probable Cause 1. The running belt and/or deck are badly worn.
2. Bad lower PCA.
3. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  1. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions and compare values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  2. Test unit with a known good lower PCA. Replace lower PCA if necessary.
  3. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 29
Apr 06, 2011 | Precor C954i Commercial Treadmill
How to I take my precor treadmill apart
Use a phillips head screwdriver to loosen the bracket attached.
Jan 26, 2011 | Precor C954i Commercial Treadmill
Precor 956i Experience Series Treadmill (Used) Logo
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
