Question about Procom MN100HPA Heater
Heater procom sn400tyla
Has a high pitch whine in all settings.
2 Suggested Answers
SOURCE: Procom Model SN400TYLA Thermocoupler bad, can't find part
try 18778865989
Posted on Oct 28, 2008
My heater has developed a high pitched whine on the hi or lo heat settings. It doesn't have it on fan only.
Sounds like a pressure regulator problem, to much pressure will cause this.
Nov 28, 2015 | Heating & Cooling
High Pitched Whine
A high pitched whine like that indicates a bad bearing. Water pump, power steering pump, accessory belt slipping, alternator bearing, or in the worst case scenerio, Transmission pump.
Dec 12, 2013 | 2001 GMC Yukon XL
High pitched whine
The most common cause would be a defective power steering pump.
Aug 29, 2012 | Cars & Trucks
High pitch whine when tv started then it lowers in pitch
That could be either the color wheel or one of the fans. try listening to which area of the set its coming from.
Apr 04, 2012 | Televison & Video
High pitch whine when ac/heater fan is on
I have had this when a gum nut or piece of leaf lands in the fan. I got luck and by removing the vents I could access the fan area. That may not happen in many cars but it is worth a shot.
On the Cortina TF I cut a hole in the air chamber in the engine area and got access to the fans and the resistor block.
Dec 29, 2011 | 2002 Chrysler Sebring
2000 Suburban: High-Pitched electronic whine near rear of surburb...
That "whine" is the fuel pump inside the tank. This usually gets louder at or below 1/4 tank. Expect the fuel pump to go out soon.
May 16, 2010 | 2000 Chevrolet Suburban
High pitched whine/sometimes TV won't turn on
The power supply on this model will whine when it is shorted or overloaded - the set would have to be brought in to determine exact cause.
Oct 23, 2009 | Televison & Video
Screen Whine
Hi, constant high pitched whine from most monitors have something to do with the horizontal frequency which is partly affected by the screen resolution as set in your computer display properties. Try lowering down your resolution or go into safe mode. if the whine disappears, it may be that the monitor is not fully capable of displaying too high a resolution. If the whine continues even at safe mode or lower screen res, then you would need to consult a qualified technician to check for defective components in the horizontal circuitry of your monitor. I wouldn't recommend that you take look due to the presence of extremely high voltage in that area. Hope this be of some help. pls post again how things turn up. kind regards.
May 20, 2007 | Hansol Multitech 920p 19" CRT Monitor
Open Questions:
See all Procom MN100HPA Heater Questions
Procom MN100HPA Heater Logo
70 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
john h
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
