Question about Refrigerators
Freezer defroster not working
LGUI2149LPO
    Champion:
    Habit-Forming:
  • 275 Answers
They use a defrost heater element to defrost the evaporator in the freezer, it has probably failed, tricky to change but not impossible, watch your fingers the evap is very sharp.
Posted on Nov 29, 2013
Its working but freezer proper work but refrigerator is not cooling
As struck freezer fan by working due to over frosting behind the freezer where FFan is located. Check defroster cycling is working properly. .Keep temp 5 degree and check thermostat, defrost timer and heater working properly.
Now defrost manually or unplug fridge. And after defrost, plug it again.
Feb 03, 2011 | Refrigerators
Freezer is working refrigerator is not.
The freezer is not defrosting. Look at the back wall of the freezer section and see if it is frosted. Locate the defrost timer and advance it till it clicks once. This should advance the freezer to the defrost cycle. Check to see if the defrost heater is on. If the defrost heater is glowing behind the freezer rear panel the you know you have to replace the defrost timer. If the heater is not glowing then you have to check if the defrost heater or defrost timer is in default.
Dec 27, 2009 | Amana ABB1927DE Bottom Freezer...
Freezer not freezing
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge not staying cool, freezer still freezing
Try defrosting freezer, sometimes when the defrost thermostat fails it causes ice too build up behind the walls of the freezer then it restricts the air flow to the refer side. If it works after defrosting then you probably need to get a new defrost thermostat.
Mar 14, 2009 | Maytag MBB1956GES Bottom Freezer...
Freezer won't work in garage in cold weather
Modern fridge/freezers are built to automatically defrost themselves. To do this they require that the room temperature is well above freezing to allow the defrost to take place. If you site the freezer in too cold an environment it is unable to defrost itself and will eventually stop working. It sounds strange but if it is too cold the freezer cannot work. The solution is to buy and fridge/freezer that does not automatically defrost itself if you want it to work in a cold environment.
Dec 06, 2008 | Refrigerators
Freezer not defrosting
Hello pumpguy2
Welcome
You said, you have a Kenmore bottom Freezer Model 596.73503201. It works fine but the freezer has stopped defrosting. Any suggestions?
It is supposed to be auto or self defrosting.
What do you mean you are getting ice forming in the freezer?
Waiting for your response and more detailed explanation.
Huuum
Oct 01, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator on the fritz
The defroster is not working. Ice build up prevents cold air from the freezer chest from blowing into the lower part.
The way the defroster works is this: There is a defrost timer, probably found under the refrigerator at the front, that turns on the defroster three times per day or so. That turns on a heater nested among the freezer coils. It keeps heating until the defrost thermostat gets warm; then it quits defrosting.
I think your defrost timer doesn't turn. You can turn it with a screw driver till you hear a click. Now your ice compartment should be defrosting. With ice buildup it may need lots and lots of defrosting. You might not get cooling back into the lower part for awhile, till the ice buildup melts.
By the preceding, you should know if the defrost timer needs replacing.
If you should need to manually defrost the freezer coils, they are, I think, under the floor of the freezer. To defrost them, I'm told, a hair drier works better than boiling water. The defrost thermostat is in there too, a one inch unit with two wires. It should have no continuity warm, closed circuit frozen. If it has open circuit frozen, that would be your problem.
Jun 14, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Freezer stopped working
ok,is the freezer fan working?is there frost buildup in the freezer?it sound like you have a defrost problem whick means your defrost timer,defrost heater or defrost sensor has failed,you need to check all the defrost parts to pin point the problem,let me know what you find-mike
May 22, 2008 | Traulsen Reach in Freezer - G12010
Bottom freezer not working
Check for frost build up behind back panel. Defrost system consist of defrost timer or adaptive control board, defrost heater, defrost thermostat. check them here
Jan 23, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Traulsen freezer URS48DT
Turn cold control to Max. This keeps your compressor running for this troubleshooting exercise. Find and manually advance the defrost timer with a screwdriver or something similar. This will shut the compressor down and bring the defrost heater on. If this happens then you will know that your timer is bad.
If it is not that, the next thing to look at is the defrost heater itself or the thermal overload on your defrost heater. This keeps your defroster from overheating.
Jan 20, 2008 | Traulsen 7 cu. ft. / 198 liter Commercial...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
