Question about Sony MegaStorage CDP-CX455 400-Disc CD Changer
Unit turns on but does not respond to commands.
When unit is turned-on, it starts humming as if it's trying to change disks. After a few seconds, it quits humming but it will not respond to any commands from the remote or from the buttons in the unit. The unit will not turn off. The only way to shut if off is to unplug it.
    Genius:
  • Sony Master
  • 1,054 Answers
Take the cover off and locate the humming noise...is there a belt loose?
Posted on Nov 27, 2013
4 Suggested Answers
  • 99 Answers
SOURCE: Player shows ejects symbol and shuts off after about 45 seconds
the timing will be out of line, thats whats putting in shut-down mode. dis-engage the tape carriage from the running cogs and manually put it in eject mode, re-align the main cogs to their pointers. there should be one on the cogs and on the chassis to help you re-align then re-engage the carriage to its cog.
Posted on Aug 23, 2008
  • 5603 Answers
SOURCE: When I turn on my unit the display is stuck with REMOTE ON
Move the remote to another room to test. It is possible a button on the remote is stuck on.
Beyond that , it probably needs to go in for service.
Posted on May 16, 2010
  • 77 Answers
SOURCE: when I changed cds, the carosel starting turning and won't stop or respond to any other commands. I turned off, and then back on and it just keeps turning.
It sounds like it's a position sensor issue, either the player is not detecting the cd's in the carousel or it's not detecting which position it's in. Try looking for a sensor and cleaning it with some isopropyl alcohol and a Q-Tip.
Posted on Nov 28, 2012
RCA Stav-3880 turn stereo on goes to full volumn
Take the batteries out of the remote control, then apply a piece of black tape over the IR sensor, Unplug the power, wait a few minutes, now power the unit back up, does the unit still have the same volume high symptom? If so, remove the tape and see if the unit responds to any other commands(other than volume) from the front panel. If it responds to the panel controls, the processor is most likely good. very seldom is the IR transistor bad, if it is no input command will work.
Feb 15, 2014 | RCA Optimus/Stav-3880 Rcvr Parts - Board -...
Printer Stopped Responding
See if you can order a new power supply unit for it. The service manual is here: http://servicerepairmanuals.net/printers/samsung-scx-4725fn-digital-laser-mfp-service-manual/ I dont know if you want to go this far into it though.
Jan 19, 2014 | Samsung SCX-4725FN All-In-One Laser...
Turn dishwasher on . the water loads in and then goes into wash cycle, it does it's wash cycle then drains and will not load clean water for rinse cycle it just hums a and then quits, then tries again and...
Tim Derbowka, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Tim Derbowka), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool GU2300XTS 24 in Builtin...
Hello... I have a Goodman CKL49 a/c unit on the exterior of my house. I have checked everything I can think of and isolated the issue to the fan motor not turning on. The unit will recieve the signal from...
Hello, try using a small object to push the fan with power applied to it, if this gets the fan going tnen the capacitor must be replaced. If the fan does not start up then the motor is shot and must be replaced.
Sep 02, 2011 | Goodman CKL49AR49 Air Conditioner
Dear Expert, When I went to turn on my Roper dryer it made a humming sound for a few seconds then quit, without out the dryer ever starting. I then had my wife depress the start know while I held the...
check and see if there is any thing in the dryer vent if not.open the door hold the door switch in like the door is shut.have your wife push the start switch in and turn the drum counterclock wise if it starts then the motor has gone bad if it hums still its still the motor.if it does start stop the dryer and try restarting several times sometimes they get a dead spot and it may work for years or may die tomorrow but these are a couple of things to try good luck
Dec 19, 2010 | Dryers
I have a danby premiere model DPAC10071 & the dehumifier now wont fill external tank. every 2-3 minutes it makes a noise kind of like a fog horn way off in the distance(as if its trying to run again,...
it sounds like your compressor is failing to start ... that usually means a bad starting capacitor ... if thats the case it will hum loudly for a few seconds periodically .. thats the compressor trying to start but it cant if the capacitor is bad .. it will stop humming when it gets too hot .. a thermal breaker will turn off the power until it cools back down .. dont let this continue since it will eventually damage the unit ... replace the capacitor .. the capacitor is usually mounted on or near the compressor .. it often has two sections .. one for the fan motor and one for the compressor ... since they are both in one case you have to change them both ,...
Aug 15, 2010 | Danby Heating & Cooling
Unit in roof, switch on and it hums and throws the safety switch s/n 26641/12/2, thanks
Turn power off to unit first. Then Try going up on roof, and with a stick or similar, through vent slots, spin fan blade a few times, and then try to start again. Seen quite a few stuck in dead spot at motor, and this will sometimes get it off the dead spot if fan(motor) hasn't been run in a while. If it has been running, and just recently started doing this, Capacitor is probably gone but need to be careful working with it, so get back to me if spinning fan blade didn't do it. Would be helpful to have model and make of unit.
Jan 28, 2010 | Heating & Cooling
I have a pioneer elite vsx 36tx receiver that quit working. When I turn it on it just hums. It seems like a power supply but not sure.
I have the same receiver.
Do you mean there is an audible hum from the unit, or that speaker output(s) hum?
Let's figure out what DOES work...
Do you get the audible relay click a few seconds after power up?
Does it tune FM?
Can you get the On Screen Display? Settings all ok?
What preceded this? RSVP.
Jan 19, 2010 | Pioneer VSX-36TX
Runs for a few seconds and then quite
It could be a fuel pump issue, do you hear the fuel pump run when you turn the ignition to run position? Just turn the key to on (turn the radio off and buckle the seat belt so you can hear better) you should be able to hear the fuel pump. It will be a hum from the rear of the car, the pump should run for 3-5 seconds then shut off.
Dec 04, 2009 | 1989 Ford Escort
Sony MegaStorage CDP-CX455 400-Disc CD Changer Logo
180 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
