Siemens xlm 1400
How do i remove the motor. I have taken the two screws from the back but cant access the rest
SOURCE: SIEMENS XLM 1600 (WXLM166AGB) MACHINE
If water is being dispensed from both sides of the detergent tray, dismantle washing machine and remove top plate of the detergent tray and clean thoroughly. Water overflows from both sides during the rinse cycle to add softener to the rinse. On our washing machine it was blocked. During the service it was changed but can be washed out to solve problem.
Posted on Sep 15, 2008
SOURCE: siemens xlm 1600 leaving scum
Had the same problem with our Siemens XLm1600. The problem is that you are using washing LIQUID.
Change to a powder (particularly a biological one) and you'll be ok...
Posted on Jul 14, 2009
  • 2006 Answers
SOURCE: spin cycle will not work
If the spin cycle is not working, it could be several things. How is it not working? If it won't do anything, i.e. doesn't turn, then I would suspect the transmission since the spin cycle is the high side of the transmission. If it spins but does not take the water out of the unit, then I would suspect, either the pump or the timer.
Good luck and have a great day!
Posted on Jun 09, 2011
Daniel S
  • 4323 Answers
SOURCE: siemans xlm 1400 washing machine
Hi
First make sure that nothing is blocking the drain pump assembly located inside the bottom of the unit, after this test the lid switch assembly, you jump it to test it. If the lid switch is also fine then the control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Sep 04, 2011
SOURCE: Siemens XLM 1400 Powder drawer stuck shut and can't open
Try unplugging it for little and then see if that will reset it
Posted on Dec 02, 2012
Siemens xlm 1400 will not rinse clothes, it makes noise but the drum will not rotate eventhough it will turn by hand.
your motors drive brushes need replaced
so look to use the model number in EBAY
http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.Xxlm+1400+brushes.TRS0&_nkw=xlm+1400+brushes&_sacat=0
i used the search string
'xlm 1400 brushes'
and they are quite easy to replace..
it may do a whole wash cycle and count down etc just wont spin or move the drum with heavy water laden clothes
goes eeeeeeeheheeheh but no drum rotate
so
you can drain the machine only
lay the machine down with the soap drawer away from the ground
then it wont leak
two screws and one power clip removes the brushes
from the main motor {the one with the belt that drives the drum}
their are two brushes one each side
so 4 screws
and replace both ..
so...
good times
let us know the size of the brushes left
they should be like new 2.5" - 3" long
if they are less then 1.5" replace them
this is the issue
the main advice is not to use it just now
till you check the motor brushes
as this type of fault can further damage the motor
so .. dont use it till you check / replace the brushes as the intermittent contacting will damage the motors stator {the bit the brushes make contact with}
Aug 19, 2014 | Siemens Washing Machines
Dec 02, 2012 | Washing Machines
Spin cycle will not work on siemens xlm 1400 and filter has been cleaned what to do
Jun 09, 2011 | Washing Machines
How do i get to the mobo on a fujitsu siemens lifebook S7020
remove rhe 2 screws which have arrows pointing to them either side of battery and screws underneath battery, remove top cover with speaker grills and power button, remove 2 screws at top of keyboard, remove keyboard, if you want more access, remove rest of covers, screws, dvd-rw and screws beneath dvd-rw gently prise casing apart, remove screws from mobo, remove mobo.
Jun 01, 2011 | Fujitsu Siemens LifeBook S7020 Notebook
The spin on the washing machine is not working.It turns but very slowly Machine is A Siemens WM16S38368 2 years old
it may be your agitator
Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator.
Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
5
Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
6
Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Jan 31, 2011 | Siemens Washing Machines
SIEMENS XLM 1600 WON'T GO INTO SPIN CYCLE
Dear customer,
                     When the spin cycle doesnt occur the most recommended steps are
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission.
  You can click on the highlighted words to get details abt the checking procedure..
Plz rate this solution.. thank you..
Apr 09, 2009 | Siemens Washing Machines
Access motor
Your dryer and motor can accessed a couple different ways depending on the make and model:
1. Can be the Top (remove 2 screws near filter-pull) can slide a putty knife and screw driver and pop the top off.
2. Also, the Door must be taken off to access the motor (Screws on inside of door)
3. Bottom - panel comes off by sliding a putty knife or screw driver and dis-engaging.
After intially opening the dryer cabinet; you will most likely need to remove the front door by removing 2 screws located at the inside top corners (1/4'). ** Be sure to turn off power to unit before opening and servicing.
Whats the problem? Humming noise? Not tumbling/turning? How old? What make?
Jan 27, 2009 | Dryers
Siemens xlm 1600 leaving scum type marks on washing
May 10, 2008 | Washing Machines
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
