I am unable to edit documents that I have scanned. I have tried to download the OCR driver but I am still having a problem. Please help
Model MFC-420cn Scanner problem How can I edit items that I have scanned
    President:
  • 1,865 Answers
If you are scanning text as an image, the image cannot be editred, because the computer doesn't know the image is text.
You have to scan with OCR to edit text.
You can use PaperPort to add text to scanned images
Posted on May 08, 2009
The lexmark x2650 doesn't have the OCR software in it. I try to scan a document and edit it but can't because no OCR software included
To scan documents for editing and saving as PDF file, you will need to install the Lexmark OCR scan software on your computer. The Lexmark scan software (no downloadable version) is only available on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center for assistance.
To install the OCR scan software from the printer installation CD:
  1. Insert CD into the CD-ROM drive. If the installation screen open, click Cancel.
  2. Double-click on My Computer / Computer.
  3. Right-click on Lexmark XXXX CD and select Open.
  4. Double-click on OCR.
  5. Double-click on Setup.exe to install the OCR software. Your operating system will then determine the language in which it is installed.
Mar 05, 2012 | Lexmark X2650 All-In-One InkJet Printer
I have a scanned PDF document that I want to highlight and previously when the text wasn't recongnized it would ask to convert. At one point I checked the "do not ask again" box and now I am...
Basically Acrobat comes with a feature called as OCR (Optical Character Recognition) which helps acrobat in recognizing the text being used in a particular scanned document.
Just for the information, Acrobat 7 used to come with OCR accuracy of approximately 85% which has increased to 95% accuracy in the latest version of Acrobat (Acrobat X)
Now, in Acrobat 7, what you need to do is try running the OCR again on this document by following the steps mentioned below:
  • Open the document in Acrobat 7
  • Go to Document menu at the top
  • Click OCR text Recognition option under that menu
  • Then Recognize Text using OCR under that
  • This will open recognize text dialog box
  • Make sure All Pages option is selected in the new dialog box
  • Then click the edit button available in the same dialog box
  • This should open recognize text setting dialog box
  • Select Clearscan option in PDF Output Style drop down
  • Click Ok and then Ok again which should start the OCR on the open document
  • After OCR successfully completes try highlighting the text and see if you can do it
If you are still unable to do it, I would suggest you to download the trial version of Acrobat X from adobe.com which is a fully functional version which you can use for 30 days. After downloading this trial try opening the same document there and try running the OCR again and perform the highlighting of text again in Acrobat X itself.
If it still does not work please reply back with the results of the above mentioned steps and we can try performing some other workarounds to make the text recognizable.
Jun 01, 2011 | Computers & Internet
UNABLE TO MAKE CORRECTIONS TO DOCUMENT
Scanners put a graphic image on your computer that is a "picture" as far as the computer is concerned and therefore, you cannot edit text because it is seen as pixels and not characters. In order to make a scanned document editable, you'll need to use the OCR function in your software (Optical Character Recognition). This is assuming your printer came with OCR software, if not, you'll need to purchase an OCR software package in order to convert images into editable documents. You should be able to find such packages for less than $50.00. Check your documentation (and help files) and look for OCR in the index or search the help files for OCR to see if such software came with your printer software package.
Jan 30, 2010 | HP Photosmart C4240 All-In-One InkJet...
Scan a Document and Need to edit in Word 2007
Most of the time a scanner by default, will scan a document in a tif or other image file format. That means that the scanned image is actually very similar to a photograph. In order to edit the text, you first have to convert the image using something that's called OCR software. OCR is a process that the software uses to look at a scanned document image and determine what characters are on the page. It's not always very accurate but that depends on the quality of the scan and on the OCR software being used. You must have received some sort of scanning software with the scanner. Hopefully it containes some sort of OCR software. Some scanners will save you this extra image manipulation by having a setting that allows you to scan directly to a word document. Usually in that configuration, the OCR software automatically knows to convert the scanned document image in order to automate the process. But either way, you first have to install the manufacturer's software. Hope this helps. Please remember to rate my answer. Thanks.
Feb 26, 2009 | Visioneer OneTouch 5800 Flatbed Scanner
Unable to scan text doc to Word
hi i thing your software is corumpt and you nead to reinstall it. when you buy your printer you have the cd whit it. but if you don't find it you cant download the torrent of ocr
bye and good look
Dec 04, 2008 | Dell A940 All-In-One InkJet Printer
OCR Directory
Try downloading from lexmark here:Official Lexmark Drivers and Software
Or use a different OCR, put the worsd OCR freeware download, on google to get a choice of free OCR software.
Nov 16, 2008 | Lexmark X1270 All-In-One InkJet Printer
OCR application error with the Dell ALL in ONE
OCR is a software provided by Dell to convert a scanned document to editable text(word) document. If you scan without OCR software, printer will scan it as a Picture and you can not edit it.
Now here is your answer.
When you install Printer CD, it also install OCR software (Abbyy Fine reader) along with it.
You might have uninstalled the printer drivers and reinstalled them by downloading it from Dell support site.
I must tell you that Downloaded drivers from Dell site DOES NOT contain OCR software.
Solution:
1. You can download free trial version(15 days) from Abbyy.com
Click here to download
2. If any of your friend or relative have printer listed below then you can use the same CD to install the OCR software.
List: Dell 924, Dell 926, Dell 928, Dell 944, Dell 946, Dell 948, Dell 964, Dell 966, Dell 968.
location on Disc:
D:\OCR\setup.exe
3. You can scan using MS Paint.
Click on Start > All Programms > Acccessories > Paint
Click on "File" on Top left corner.
Click on "From scanners and cameras"
Click on "Scan"
It should be able to scan.
4. If you want to use Dell All In One Center.
You can disable OCR option for scanning and it will scan as an image.
Open Dell All in one center.
Click on Advanced scan options Under scan,
Uncheck "Use OCR software".
Click OK and try to scan again using Dell All In One center or using the printer operator panel.
Please revert for any further assistance.
Nov 05, 2008 | Dell 924 All-in-One InkJet Printer
Lost installation disk for my Lexmark x1240 all in one printer. I'm trying to scan a text document to edit but tells me I need to download/install OCR software in the OCR folder on that disc. Possible to...
go to this site http://downloads.lexmark.com/perl/downloads/downloads.cgi
put in your country etc.......
choose the x1240 in the driver box.......then search
choose windows vistamag-glass_10x10.gif from the operating dropdown box.......
click on download now and then install the new driver.....
hope that helped
Oct 19, 2008 | Computers & Internet
OCR
To scan a document for editing purposes, you will need OCR (Optical Character Recognition) software. OCR software is not included with your model.
OCR software interprets the scanned document for editing purposes. The Epson driver alone only scans documents as image files and is not capable of this interpretation.
Some reputable OCR software programs on the market are:
Omni Page Pro
ABBYY FineReader Pro
Presto! OCR 4.0
Please understand that Epson has NOT tested our products with these programs. They do not know if these programs are TWAIN compliant and will import directly from our scanners. I recommend that you contact these companies for full compatibility information if you are interested.
Jun 01, 2008 | Epson Stylus CX9400 Photo Printer
Editing a scanned document
A scanned document is an image file. As for an image doesn't allow tekst editing like an application such as Word does, you'll need OCR software.(Optical Character Recognition). This software is intelligent enought to read character instead of pixels.
Here's an overview of OCR Software:
[OCR Software at Download.com]
I hope this information helps you out, Please rate my solution.
Greetings,
DarkNeogen.
Jan 25, 2008 | Canon MX300 Office All-In-One Printer
294 people viewed this question
jasbo
jasbo
