FGI on screen (Technics SC EH600)
Hello, my home stereo stop after only a fex minutes and I can read FGI (or FG1 ?) on the screen before it turns itself off. Does anyone know what to ?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 924 Answers
I'm not sure what you are referring to when you say FGI, but if the unit turns off soon after it comes on, your unit probably has DC Offset, which means you have a damaged amplifier. For more information, please visit my website at audioserviceclinic.com. Thank you.
Posted on Nov 30, 2013
4 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: no sound from turntable bought for our hi fi system
Most if not all turntables would need to be connected to a PHONO INput which is high impedance with a high gain pre-amplifier stage. It will not work when connected to an AUX, CD or any line level inputs. Alternately, if your amp does not have any Phono Inputs, you can feed the turntable output to a preamp which can then be connected to any any line level inputs. An example may be found here or here. Additionally, there are some turntables with a built-in preamp.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jan 16, 2008
tech48
  • 624 Answers
SOURCE: Error code F61 on Technics SC-DV150
The F61 error is an amplifier failure.This error can be caused by a blown channel or even a failure in the power supply which causes the unit to detect an amplifier failure because the power supply is not supplying the proper voltage to the amplifier. On more rare occasions this can be caused by broken solder connections in the amplifier and/or power supply. Without having the receiver in front of me to troubleshoot it is impossible to tell you exactly what the cause is.
It can be fixed, but it will require some decent electronic skills. If you do not have a multimeter, soldering equipment, and an understanding of electronic components it would be best to let a service center look at it for you. If you do have these tools and would like to try and fix it yourself, let me know and I may be able to guide you thru the troubleshooting process.
Dave
Posted on Nov 26, 2008
  • 8 Answers
SOURCE: Technics SC-DV290
Hi mkoles111,
I have a copy of what you need which I downloaded recently. It is in pdf format and is about 2.2mb. Let me know if you still need it and I will forward to you.
Regards
topgunner
Posted on Sep 05, 2008
When I turn on my Technics DV290 stereo it shows FG1 what does that mean.
Codes are not listed, you would need the troubleshooting manual, which they do not give the public access to.
Jul 09, 2017 | Technics Audio Players & Recorders
Technics sc eh600
Check the integrity of your speaker wire, make sure they are 'phased' (-+) properly, also check all other connections, it sounds like the protection ...
Nov 25, 2013 | Audio Players & Recorders
Hello there, I have a problem with my Technics SC-DV290 System. The problem i have is that when i go to turn it on it buzzes and it cuts out after a second or two and there is no display on the stereo...
ok. there is a MAJOR problem with the power wiring. i suggest not turning it on again until either you have fixed it or a trained professional has.
Jan 24, 2011 | Technics SC-DV290 System
Technics SA-DV290 Amp. Sound cuts out as volume is increased
hello it sound like the output ic may be in trouble you may have just dry joint on the ic which just resolder it . or there could be a capacitor leaking or they may have swelled up in which you will have to replace. it's best to do some visual checks first i'e look for any burnt parts any capacitor with bulging tops
regards
shaun
Apr 04, 2010 | Technics SC-DV290 System
Technics manual sleh600
Technics SL-EH600 is CD changer, which is part of SC-EH600 syste, so download:
SC-EH600 Manual, scroll to pages 18-21 for SL-EH600.
Feb 24, 2009 | Technics SCEH790 CD Shelf System
My stereo turns off by itself and the indication F61 appears
1st case dry solder connection in power board and amp bpard ,resolder and unit will be working o.k
Oct 28, 2007 | Technics SC-EH780 CD Shelf System
78 people viewed this question
 Grubhead
Grubhead
