Question about Electrolux Ovens
I have an electrolux 100m electric double oven wall unit, the top oven will not work but the bottom will. the broiling unit was replaced with no results.
SOURCE: Maytag "Magic Chef" electric double wall oven
check the high limit swtich. You need to remove the back of unit to find it. replaced it part# is:w10175596
Posted on May 19, 2008
  • 29 Answers
SOURCE: Dacor ECS230 Epicure Electric Double Oven
You probably tripped a safety thermostat in the back of each oven. If you turn off the breaker and find a way to pull the units out you could probably remove the rear panel and reset the thermostat by pushing in a button on the back of the open thermo. Some thermo's aren't resettable though so you'd have to buy a replacement.
Posted on Sep 22, 2008
barkencoa
  • 3463 Answers
SOURCE: HOTPOINT DOUBLE OVEN mODEL uy46 BOTTOM OVEN NOT WORKING CANNOT CL
While it is flashing auto ,you will not get the oven to heat up.
You must press the timer buttons in the correcf sequence to cancel auto.Refer to user hand book.
If you suceed with this, and the oven still does not get hot, then the element has probably failed.
Posted on Nov 23, 2008
barkencoa
  • 3463 Answers
SOURCE: bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Posted on Dec 17, 2008
barkencoa
  • 3463 Answers
SOURCE: Electrolux double oven does not get hot
If it is a fan assisisted oven and the fan is still working, then you need a new oven element fitting.
Plz rate my solution.
Thanks.
Posted on Jan 11, 2009
Clean between the glass on double wall oven
Unscrew the handle and screws at the bottom. Carefully separate the outer panel from the frame
Apr 09, 2014 | Frigidaire FPET2785KF Professional Series...
Replaced EOU43002X element, clock/timer now dead
Make sure there is power to the timer. Should be a fuse somewhere.
Mar 19, 2014 | Electrolux Ovens
Why has both top elements stop working at the same time
Hello kimberlymaso - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
Sep 25, 2012 | Frigidaire 30 in. Electric Gallery Series...
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
BOUGHT A HOME IN UNION NJ WITH THE GE DOUBLE WALL OVEN TOP PART DOES NOT WORK BOTTOM PART BURNS THE FOOD NEED REPAIR PLS CALL ME AT 908-391-8942
The heating element in top unit may be loose or burned out. Push the element toward the back and see if it engages. If it is already engaged, you'll need to replace it. It is simple to remove it.Just give a firm tug and it should come right out. To replace with a new element, simply push it in firmly.
With the bottom unit, are controls set for bake? If they are set for "broil" you are using direct heat and it will cook foods more quickly.Also, is bottom unit a convection oven? If so, foods will cook in 1/4 to 1/2 the time for a conventional oven, so you'll have to adjust your temperature down about 25-50 degrees and shorten your cooking time.
Nov 01, 2010 | GE Built-In 24" Double Electric Wall Oven
Upper oven elements don't heat
Hello- 'Successfully' sounds like you were forewarned....  During the 'self-clean' cycle a circuit or connection to the upper elements burned out while attempting to turn stuff inside the oven to ash. Since this is a wall oven my recommendation is for service from a good tech in your area. You may have lucked out with a fried connector, but many times control board is damaged beyond repair and must be replaced. Only on-site diagnostics will confirm, and this is a very heavy unit for most owners to safely service.  - Remember- Don't use 'self clean'!! Scrape and clean with soapy water and cloth. Turn on oven to 450deg. for 30 min. Much safer. Less costly.       Please acknowledge this post if the info is helpful- Have more if needed.  Thanks-  Ed
Mar 23, 2010 | Jenn-Air JJW8230D Electric Double Oven
Jan 02, 2008 | Maytag CWE5800A Electric Double Oven
Ovens Logo
14 people viewed this question
Top Electrolux Ovens Experts
ashburton
John Tripp
John Tripp
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
