Question about GE Ovens
JKP19 INSTALLATION NEED INSTALL INSTRUCTIONS
Jkp38gl installation instructions
The user manual is here, but is a bit light on installation.
http://www.geappliances.com/service_and_support/literature/
Sep 02, 2014 | GE Built-In 24" Double Electric Wall Oven
U1721 oven neff how to install it
use link http://www.neffcustomerservice.co.uk/bottom left click on 'instruction manual download' this will open new window...type U1721 in search box and click on any entry with II at the end this will download the installation instructions as a PDF file.Hope this helps
Sep 17, 2011 | Neff U1721 Double circotherm Electric Oven
We just bought a Kenmore Elite Oven, model 4809, at a Sears Outlet Store. I've looked all over your website and cannot find dimensions or installation instructions. I looked at the online manual for the...
I just purchased the same model and have been searching on-line for the exact same information. Not sure if you still need it but the Sears Outlet website lists the opening dimensions for the Kenmore Elite Oven 4809 as Width 28-1/2 in. min., 29 in. max. Depth 23-1/2 in. Height 29-1/16 in.
May 01, 2011 | Kenmore Ovens
Looking for a manuel or operating instructions for a frigidaire fef365bwf range. Thanks
First of all, here is a direct link to the ONLINE USER'S MANUAL for that model:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316257123en.pdf
And here is a Wiring Diagram:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316255347.pdf
And here are the installation instructions:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316259206en.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, the follow the onscreen instructions to install the software on your computer.
Thank you very much and good luck.
Apr 25, 2011 | Ovens
CAN I INSTALL A DOUBLE WALL OVEN ON THE FLOOR?
You will have to check with the installation instructions to be sure but as a rule of thumb the answer is no. The reason being is that most wall ovens vent the heat out the bottom, if it is too close to the floor the heat will damage the floor and can be deflected back up to the fan inlet and cause the oven to overheat and can cause damage.
If you have the complete model number from the tag just inside the door I can find the installation instructions for you.
May 18, 2010 | KitchenAid Ovens
I need to know which kind of plug is used on this oven so that the electricians can install the right kind of receptacle. Maytag cwe5800acs 24 Double electric wall oven
Your oven needs to be hard wired to a junction box. No plugs on a oven that pulls 30 or more amps 220v Read your install book that came with the oven.
Dec 01, 2009 | Maytag CWE5800A Electric Double Oven
Jenn-Air range SVE47600W control panel is partially non-functional. Bake temperature control, off, oven light work. Clock does not display, oven clean and broil do not function. It may need a new panel...
We have this part in stock and can send it out to you first thing Monday morning, if you like. We will include installation instructions for you. You can call us from 7AM until 9PM CST Monday through Saturday. We look forward to working with you!!
Oct 15, 2009 | Ovens
Looking for installation instructions for a Neff B1691 oven
Neff have some downloadable installation instructions at www.neff.co.uk select neff owners, then customer service, this opens a new window which has instruction manuals as an option, select this and then enter an E number for the model ( i tried B1664) a similar single oven and this brought up a pdf file. At the end p67 it gives cable sizes and types and connection details which should give you what you need.
Please remember to rate this solution.
Dec 08, 2008 | Neff B1691 Single circotherm super...
Installation of lg over the range microwave oven
Installing an LG over-the-range microwave is an excellent way to save space in your kitchen. These types of microwaves are ideal for smaller kitchen areas. Although the retailer where you purchase your over-the-range microwave will likely offer installation service, rest assured that you can install the microwave on your own.
How to Install an LG Over the Range Microwave eHow
Oct 11, 2017 | Ovens
Ovens Logo
55 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
