Question about IBM x3400 Server
IBM Server x3400 7975 our Mainboard crashed. How to access Data on Raid ? Does it work with a replaces Mainboard ?
Running IBM Server x3400 7975 our Mainboard crashed - button power on problem - we assume it s because of the capitor. But how to access the Files on RAID now ? Is it enough to replace the Mainboard (no warranty) as i am not sure if the mainboard is part of the RAID encryption algorythms
    Champion:
  • 221 Answers
What operating system does it use?
The problem is whether you're using hardware RAID or software RAID.
Hardware RAID will likely require another motherboard to read. Software RAID can be read in any other machine that can run the operating system.
Posted on Dec 11, 2013
  • 17 Answers
SOURCE: Upgrade IBM Xseries 346 Server
You can add drives to the array through the scsi management software, then you can extend any dynamic partitions that don't have the OS on them. I don't think you can extend the array if it contains the OS. You may need to use the disk management utility in windows to make the partitions 'dynamic disks' before you can extend the data partitions
Posted on Nov 06, 2008
  • 13 Answers
SOURCE: server doesnt boot
First create a floppy disk with your RAID driver for W2K3 Server. Next boot the server with the W2K3 Server CD, and hit F6 when prompted, and S to add the specific driver for your RAID and using the floppy to get the driver installed.
Next boot to the recovery console of W2K3 Server. If it finds your hard disk, it will even ask for your Administrator's Password to continue. If this works, then you are probably home free.
Get to the command line of the W2K3 Server Repair console and perform some directory searches to see if the data is there and intact. You can also perform a CHKDSK from that console.
Once you have made sure your data is there and intact, type these two commands: FIXMBR and FIXBOOT
This should solve the problem and when you EXIT out of the console, it should reboot. Remove the CD and it "should" re-boot from the hard disk.
If you still have problems, let me know with how far you got with the steps above. I have another solution but need to know your RAID controller's model (ServeRAID 5i, 6i, etc).
-Chip
Posted on Nov 26, 2008
tjt3
  • 44 Answers
SOURCE: Raid configuration
When your system boots up you should see an option to access your raid controller if not or if your system doesn't see the controller at all you will have to download the utility software from IBM, but you need to be careful any change you make in the configuration of the disks will delete all data on your drives. This is non-recoverable loss. The utility has help and is fairly easy to understand.
Posted on Mar 24, 2009
cropp
  • 377 Answers
SOURCE: IBM e server
hi dear
you can try this sie for raid driver
http://www.yournewdriver.com/IBM_ServeRAID_Controller_4448.htm
oke
cropp
Posted on Apr 12, 2009
paand
  • 147 Answers
SOURCE: raid 1
there must be some key on the startup to enter into the raid menu. And in that raid menu you can create raid .
Posted on Jun 23, 2009
IBM Server not detecting hard drives
You know i find this all very suspicious. For one thing a ups is designed to take the hit so it will get fried and your computer will be fine. Suspicious to me but not an answer to your question so i will try this. The new raid card was installed (might be off on this part, haven't kept up with this) were the hard drives and the raid assembly matched back up. IE raid 1, 2, 3 etc. Do believe they are up to raid 7 now. So if hard drives were not put back in the original position and and raid card setup for the original raid array you might have this problem. Hope this helps, but it's been a long time since i worked with raid arrays.
Feb 11, 2014 | IBM System x3250 M3 4252 - Server -...
Can not setup RAID 1 on an IBM X3200 M3 Server
you can access the raid controller using the BIOS and system devices>>> refresh>>> then select the controller then create your raid...
don't know why they move out from the POST the controller its really stupid''' Sorry..
Feb 04, 2012 | IBM System x3200 M3 7328 Server tower ...
Bios corrupted and controller monitor initialisation failed on IBM X3400 server type 7975 what we should do
You need to figure out which BIOS is corrupted. If its the RAID controller BIOS your card may be bad if its the Motherboard BIOS you need to download a BIOS image & re flash it. If your card is dead it is IMPORTANT you need to get an EXACT replacement to be able to retain your data on your RAID.
Aug 28, 2011 | IBM x3400 Server
Fetal error controller monitor failed x3400 ibm server
Welcome to fixya
Open the server and take out the raid controller . Now clean the slot as well as the raid controller . Now replug the raid controller check if it works
If you get same error now , then its time to replace the raid controller
Thanks
Oct 13, 2010 | IBM x3400 Server
Raid configuration
Mar 24, 2009 | IBM eServer xSeries x226
Xseries 346 wont boot
You don't say whether or not your os is on the RAID 5 partition. Assuming that it is (for performance reasons, this is not recommended) then you should check to see if you have the option of configuring a separate raid configuration on your raid card (e.g. do you have a card with more then one RAID channel?) If this is so, I would create a separate RAID 1 array and install the OS just on that. Then you can mount the RAID 5 array with your data intact. Once you're up and running, you can remove the old OS partition, as it's no longer needed.
Apr 02, 2008 | IBM xSeries 346 Server
Server doesnt boot
-Chip
Raid w/ hard drive defunct
Well lets make some assumptions
1. You have a Raid 5 System
2. You only have 3 drives in the Raid ARRAY
3. Only 1 drive has failed
To fix the problem you should only need to Replace the Failed Drive
Then start the raid management software or bios
Rebuild the array
If you have more than 1 drive failed in a RAID 5, and still must recover the data it is possible. But very expensive. Still fixable however.
Sep 23, 2007 | IBM xSeries 226 Server
IBM x3400 Server Logo
171 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
