2000 ford mustang,3.8 engine running very rich
  • 124 Answers
SOURCE: 2000 ford taurus bank 1 and bank 2 running rich
it sounds like the O2 sensors need replaced. bank 1 is the left side and bank 2 the right
Posted on Mar 23, 2009
  • 121 Answers
SOURCE: Its an 2000 Ford Mustang with an engine code
take it to your local autozone and have them do acel test on it. they can tell you what system is not working properly
Posted on Feb 23, 2010
ZJLimited
  • 17970 Answers
SOURCE: Where is the fuse located for the secondary air pump for the 2000 Ford Mustang 3.8
Hi there:I suggest to check on the Power Distribution Box, that is located in the engine compartment.The power distribution box contains high-current fuses that protect your vehicle's main electrical systems from overloads.
DTC P0171 - System Too Lean (Bank 1)This DTC is very similar to P0174, and in fact your vehicle may show both codes at the same time.
A code P0171 may mean that one or more of the following has happened:
  • The MAF (Mass Air Flow) Sensor is dirty or faulty
    Note: The use of "oiled" air filters may cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry.
  • There could be a vacuum leak downstream of the MAF sensor
  • Possible cracked vacuum or PCV line/connection
  • Faulty or stuck open PCV valve
  • Failed or faulty oxygen sensor (bank 1, sensor 1)
  • Sticking/plugged or failed fuel injector
  • Low fuel pressure (possible plugged/dirty fuel filter!)
  • Exhaust leak between engine and first oxygen sensor
Possible solutions, a lot of times, cleaning the MAF sensor and finding/fixing vacuum leaks fix the problem. If you're on a tight budget, start there, but that may not be the fix for certain. So, possible solutions include:
  • Clean the MAF sensor. Consult your service manual for it's location if you need help. I find it's best to take it off and spray it with electronics cleaner or brake cleaner. Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling
  • Inspect all vacuum and PCV hoses, replace/repair as required
  • Inspect all hoses and connections in the air intake system
  • Inspect and/or test the intake manifold gaskets for leakage
  • Check for a dirty fuel filter and proper fuel pressure
  • Ideally you'll want to monitor short and long term fuel trims using an advanced scan tool
  • If you have access, you may want to run a smoke test
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Posted on Aug 22, 2012
  • 44613 Answers
SOURCE: 2000 ford contour number 1 and 4 cylinders running
Have the fault codes read. Replace faulty items. Use only
genuine items as replacement as non-genuine are not always compatible with the OEM fitted CPU units. This results in the fault codes not cancelling out.
Posted on May 18, 2013
SOURCE: built my motor in my 1989 ford mustang 5.0 motor runs good but runs rich not sure where all vaccums go
need to get diagrams
Posted on Dec 29, 2013
94 ford mustang 3.8 engine why is no. 5 cylendre running too rich
How do you know #5 is running rich? error codes tell you that? I doubt it. But if you are sure, check the connections and the wire all the way back to the Ecu. my wild guess, the control is shorted to a positive supply and therefore the injector thinks it is supposed to supply wide open fuel. Or you have a bad ecu that is telling it the same thing.
Mar 21, 2015 | 1994 Ford Mustang
2001 mustang gt running rich no check engiine light. backfiring and popping cranks and idles good until engine warms up
Begin with Scanning & Checking parameters....Best to begin with a 'stone cold' engine.
Feb 28, 2014 | 2001 Ford Mustang GT
1989 mustang 5.0 running good then bad missing and really rich
tell me parts you replaced sound like low compression or intake vacuum leak.replace all vacuum hoses, do a engine vacuum test and check compression see if engine has vacuum leak at intake manifold or worn out valves.
Oct 22, 2012 | 1989 Ford Mustang
2001 mustang, 3.8L, engine turns over but will not start. what are the most probable causes.
#1 fuel pump. #2 bad fuse. #3 bad igntion coil[s]. You should be able to hear the fuel pump turn on when you first turn the key on [ not to start]. then check for blown fuse.
Jan 10, 2011 | 2001 Ford Mustang
Mustang gt code po175 how to fix it
P0175 : That means your car is running rich in Bank2.
Could be your 02 sensor or your MAF sensor.
Dec 24, 2010 | 1996 Ford Mustang
2000 ford mustang code 453 and missfire cyl 5 where is the cyl
a haynes manual from a parts place will show you--or chec the condition of each plug wire-if one looks bad or falls apart--probly need to get all new wires /plugs
Dec 18, 2010 | 2000 Ford Mustang
Feb 22, 2010 | 2000 Ford Mustang
Ford mustang - year 2000 - 3.8 liter. The coil pack is out?
I replaced the coil pack to no avail. I also purchase a code reader while at the auto parts store. This device told me cylinder 3 was misfiring (P0303). I found that the spark plug wire had shorted out on the manifold sensor tubes. Replaced that wire and done.
I highly recommend keeping a code reader in your car tool kit. very useful.
Aug 30, 2009 | 2000 Ford Mustang
Engine surges, and almost dies with throttle advance
get a remote starter button at kragen and connect it to your battery and solenoid. try to hold your rpm to approx. 2000 rpm and at the same time choke the carb. with a rag just before the motor wants to die, pull the rag away fast, do not let the motor die!!! this will **** any debri from the carb. jets.remember to maintain 2000-2500 rpm while doing this...maybe more than once.g.l.
May 19, 2009 | 1965 Ford Mustang
Runs rough
How long have you had this problem? It could just be a bad tank of gas. Other things to check:
1. fuel pump and filter
Could be running on only 5 cylinders due to
2. spark plugs/wires
3. plugged fuel injector
Any problems with electrical? Like lights dimming at same time as running rough?
4. could be bad alternator putting excessive load on engine.
Nov 08, 2008 | 2000 Ford Mustang
Computers & Internet Logo
149 people viewed this question
David Payne
David Payne
