Question about Gateway Computers & Internet
My gateway laptop is stuck on "setup is starting services'' ive tried evrything but still cant manage to get past this screen
My laptop is stuck on setup is starting services screen..ive tried rebooting and all, still cant manage to get past this screen
    Top Expert:
  • Gateway Master
  • 22,734 Answers
I would press F8 just before it boots to get into safe mode. From there the issue should be apparent.
Posted on Nov 25, 2013
Niraj Limbu
  • 183 Answers
SOURCE: Gateway ML6732 Crashed ...NEED help
Seems you have OS (first guess) problem so if you have recovery disk then insert it in DVD/CD driver and reboot your laptop.
And follow the instructions appeared on sreen and when you reach installation mode choose repair one if you wanna repair OS otherwise choose fresh Installation.
once you are done you should be good to go and if you have Hardware problems then your system will show the bugs on screen during installation period.
oh! if you have any external drives (Thumb drive, Ipod) plugged in then remove before you start above procedure because due to external drives also it happens if you dont have any plugged in external drives then follow the above procedure.
Thank you and post back if any thing changes.
Posted on Jan 02, 2009
mrd00d
  • 36 Answers
SOURCE: my IBM t30 wont boot up
Use Knoppix to save your data if you need to, otherwise it sounds like you may need to reinstall the OS.
ftp://ftp.uni-kl.de/pub/linux/knoppix/KNOPPIX_V5.1.0CD-2006-12-30-DE.iso (to download Knoppix 5)
You could try using the recovery console, as previously mentioned as well. If you don't need to save data, just blow it all away and reinstall XP.
RESOLUTION loadTOCNode(1, 'resolution'); If it be the connector cable problem then replace the 40-wire cable with an 80-wire UDMA cable.
If it's a BIOS settings problem then load the 'Fail-Safe' default settings, and then reactivate the most frequently used options such as USB Support.
If it's a damaged file system case then:-
1.Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type chkdsk /r , and then press ENTER.
6.At the command prompt, type exit , and then press ENTER to restart your computer.
This takes a bit longer, but the system should boot back into Windows.
Posted on Dec 21, 2007
dumbtrucker
  • 102 Answers
SOURCE: acer aspire 6930 stuck on blue screen wont load wont recover
If it's still under warranty call Acer, it sounds like a bad hard drive to me.
Posted on Mar 23, 2009
md_ehsan_1
  • 255 Answers
SOURCE: my gateway 7330 will not reboot.white letters and black screen er
format your system and re install Windows,
this is master boot problem.
Posted on Jun 30, 2009
  • 107 Answers
SOURCE: Cant log in to Toshiba A300-1J1
What I would suggest is logging on in safe mode and trying to restore it to an earlier date using system restore. likely the profile is corrupted. By doing a restore back about 4 to 7 days , or before this started happening, will likely fix your issue. If not you will have to purchase the restore cd from toshiba or restoring it from a recovery partition if it has one.
Posted on Jul 04, 2009
How do I get unstuck from Aptio Setup Utility?
About 5,420 results (0.43 seconds) Search Results
    How to Solve Problems With Aptio Setup Utility - Tom's Guide
    www.tomsguide.com/answers/id.../solve-problem-aptio-setup-utility.html
    Dec 6, 2015 - When I switched on my laptop it shows Aptio setup utility. How do I solve this? ... My Asus is stuck in this mode. The instructions to this seems ...
    ASUS Ultrabook Stuck on/in Aptio Utility Setup - Tom's Guide
    www.tomsguide.com/.../id.../asus-ultrabook-stuck-aptio-utility-setup.htm...
    Nov 14, 2015 - I have an asus si30401u ultrabook that refuses to exit aptio setup utility ive attempted the the fix at ...
    Computer stuck on Aptio setup utility screen. - Microsoft Community
    answers.microsoft.com/...stuck...aptio-setup-utility.../50be23d9-ea0c-483...
    May 17, 2014 - My asus laptop is stuck on the aptio setup utility screen how do I get it back to the start screen.
    Stuck in Aptio Setup Utility - Windows 8 and 8.1 - Geeks to Go!
Jan 05, 2016 | Computers & Internet
Gateway nv52 laptop cays corrupt registry stuck in recover mode
start computer and lunch startup repeir. you see windows is loding files and you see blue screen read and click next computer will start now
May 31, 2013 | Gateway Computers & Internet
How do I get my sylvania smartbook to get past the infotmic screen when starting up. It is stuck there and will not load any further, I'm not sure what's wrong with it.
either the bios is corrupt ,or the set up has been edited improperly, or the windows program has been corupted, 1st try rebooting the computer ,at the startup enter to the setup screen, check the settings, write them down, make shure to have the boot sequence set to 1st boot to A drv , 2nd CD rom 3rd external usb or internet, last must be the hard drive, that way then reset to factory settings, from that screen will popup ,do you wish to save settings, enter yes, then reboot, with oem install or backup rescue disk in the computer!
Jan 28, 2013 | Computers & Internet
My gateway laptop won't reboot after system recovery
I would put in a Windows disc and see if that prompts windows to start and/or reinstall. Actually, can you send me the recovery disc via download? I am trying to fix my old laptop and cannot find the discs. lilly.murphy@yahoo.com Thanks much!
Nov 30, 2012 | Gateway NV55S04u PC Notebook
I Have A Gateway NV55c That Will Not Boot!
After much time and frustration you will end up reloading the operating system, the reason is it is corrupted, why this happens is not always the same, but the fresh copy of the operating system is the cure. You will need the recovery disks do this, you were either given them with the system or you were prompted to make them when the computer was new. If you don't have the recovery disk set then call the parts dept of the computer maker for ordering instructions, they run about $25
Feb 15, 2012 | Computers & Internet
Bios Password Blockd
You have to use F10 to get into setup to restore defaults. Default is no password. When you change all the setup you wanted and save all the changes then you leave setup to restart the system. If you then get blue screen, you do the ctrl-alt-del to get task manager. Which can have new task config, you click ok. Don't put in any password again in setup or task manager. Learn setup and task manager software?
Dec 31, 2011 | Computers & Internet
Computers & Internet Logo
116 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
