Question about LG 42LH30 42 in. LCD TV
I turn on the tv and only half of the screen can be seen
Some times I have to tap the back of the tv and have full screen but a minute or two came back to half screen
    Top Expert:
  • LG Master
  • 74,136 Answers
A clear proof to some loose soldered point at its circuit board, or a loose contact with some cables. You should check and find which one causes the fault.
Posted on Nov 26, 2013
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: when i turn on the tv, the bottom half of the screen is black. after a few minutes, i have a full picture.
set uses two boards to drive the picture, one for top and other for bottom half---sounds like one is bad in this set.
Posted on Mar 31, 2012
Tablet only shows half of screen when turned on
Try to fully power the unit off, full shutdown. Then restart. If the battery can be removed, do that also after shutdown.
Mar 01, 2017 | Televison & Video
My TV set went black on the upper half of the screen. Is there a means of getting full screen back without taking it to a repair shop?
that could be cause of loose or broken solder on the vertical circuit esp on vertical output ic.. you can easily fix that resoldering the loose and broken solder esp on the vertical putput ic.. thanks
Oct 11, 2014 | Televison & Video
One half black verticle screen
Manufacturer Philips Part Number 932224850682 Description LCD DISPLAThis part is no longer available
Aug 20, 2009 | Philips 42PFL5603D - 42 IN. LCD HDTV
Funny half screen problem
Maybe you got dried capacitors near the vertical IC or the IC himself are damaged you need to be atech for make the rapair because is dangerousli make it
Jun 02, 2009 | Sanyo DS31520 31" TV
No picture, sound ok
I have a similar issue. Sometimes the entire screen goes black and sometimes only one-half - either the top or bottom half goes black. The only solution we have found is to gently tap the TV (usually the front side) and the picture will come back for awhile. It almost seems heat related as it only goes out after the first 10 minutes of use. There must be a fix to this.
Aug 25, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Sony Trinitron KV-32S40 32" TV problem
This is a simple and common problem. The solder joints on the vertical output IC have cracked loose. I actually did a housecall on the exact same set with the exact same symptoms this morning! A good tech will resolder the pins of the vertical output IC and all other major solder joints on the main board and the set will play fine.
Sep 30, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
36" CRT Toshiba has that vertical issue mentioned on here a bit
Your problem is most likely caused by a cold solder joint in the vertical circuit. Normally this is easy to find and correct. The problem will only get worse over time, but not likely for more damage to occur.
Sep 17, 2006 | Toshiba 36A41 36" TV
Static on screen and then turns itself off then on
My first aproach will be to see if the tv reacts to tap on the sides if you see a reaccion when you do it most likely you have a loose conection and need to call someone to find it and resoldered it.Dont do it yourself if you dont know how.
Sep 11, 2006 | Proscan PS27125 27" TV
Vertical Green/Purple Lines on lower half of screen
I would contact RCA if the repair center dosent know how to troubleshoot this set. But I bet its an eeprom or ground issue. Contact RCA here at 580-634-0151 or At https://www.rca.com/secure/service/contactrca/1,,,00.html Good Luck
Jun 15, 2006 | RCA Scenium HD65W20 65" Rear Projection...
LG 42LH30 42 in. LCD TV Logo
116 people viewed this question
Computer Repairing
Computer Repairing
