Question about Dryers
Fan won't turn on - Dryers
    Genius:
  • 1,617 Answers
Make sure you're wall switch is on.
Posted on Nov 26, 2013
Why my A/C condenser fan won t stop running, dodge ram 2008
To clarify, the compressor and fan will run in defrost mode. The compressor and fan runs to dry out the air blowing onto the windshield.
Now if the condenser fan runs in "heat" you may have a problem with the fan relay or the main controller.
Sep 25, 2014 | 2008 Dodge Ram Pickup 1500
Why won`t the fan of my venmar range hood turn off?
Sounds like you may need to replace the fan switch. The fact that it wont turn off and that it only works on low speed supports that switch is broken.
Apr 24, 2014 | Venmar Kitchen Ranges
Attic fan won't turn off
faulty thermostat switch
Jul 15, 2017 | Broan-NuTone Dryers
We have a kenmore ultra wave microwave and the fan has stopped working and now the microwave won't operate. Any suggestions?
see this causes and fix it .God bless you
Exhaust Fan Motor If the exhaust fan does not run the fan motor might be bad. Remove the fan motor from the microwave oven and see if the blades can be turned by hand. They should turn very freely, if they're stiff the fan motor will need to be replaced. The fan motor can also burn out. To test this use an Ohm meter. The motor should have continuity. If it does
Thermostat If the microwave exhaust fan is not working the thermostat might be defective. The thermostat senses the air temperature and turns on the fan as needed, if it's defective it won't turn on the fan. Watch our video on testing thermostats.
Main Control Board If the microwave exhaust fan is not working check the exhaust fan motor and wiring. If they are good the main control board might be defective.
Oct 02, 2012 | Microwave Ovens
2008 impala got in this evening and ac won't turn
Someone will need to check the fuse for the blower, then the blower motor and the resistor.
Aug 09, 2012 | Cars & Trucks
Cooling fans won,t come on
1 fan is for cooling the motor and the other fan comes on when the ac is turned on or its very warm outside it 2 stage
Nov 08, 2017 | Cars & Trucks
Rad fan won't turn on when the car is at operating
The first thing I would check would be the temperature sensor that sends a signal to the relay to turn the fan on. Of course make sure you have plenty of water in the radiator or the sensor won't work at all. I have seen anti-freeze come through the sensor and corrode the wires shorting them out. So it could be broken wires, unplugged wires or a bad sensor. I am not sure exactly where the sensor is at on the Pacifica but your local parts store could show you. It is usually in the intake or cylinder head.
Sep 06, 2011 | 2004 Chrysler Pacifica
1995 chevy lumina sensor went out and fan wont turn
How did you determine that the sensor failed. Did the check engine light come on? When you say that the fan won't turn, do you mean that it won't turn on and run or that you can't physically turn it by hand. To determine this, disconnect the electrical connector to the fan and try to turn it by hand. It should turn easily. If it doesn't then it must be replaced. If it does then reconnect the electrical connector to the fan and try to operate it by disconnecting the temperature sensor lead and placing a jumper wire between the terminals of the harness. turn the AC control to AC/MAX and turn the ignition key to on. If the fan runs then the problem is the sensor. If it doesn't then check the fan control relay and any related fuses. WARNING : Use extreme caution when testing the fan circuit. Never attempt to turn the fan with the electrical connector in place. The fan can operate at any time even if the engine is off.
May 14, 2011 | 1995 Chevrolet Lumina
The heater/ac fan only works on speed settings 4 & 5
you might check your switch sounds like to me that your two lower speed sides of the switch maybe burnwed out.
Dec 19, 2009 | 2002 Chevrolet TrailBlazer
Dryers Logo
12 people viewed this question
Top Dryers Experts
