Question about HP DeskJet 5550 InkJet Printer
No color printing
I have a deskjet 5550 and my sister had the printer before me and said that it printed in color for her. I installed a new color ink cartridge and it still won't work. I look through all the printer properties and I still cannot find anything to allow color printing. When I went to the features for the printer under my properties menu it says "Color: No" but I cannot figure out how to change it. It seems like such a simple problem but I cannot figure it out. Thank You.
Hi Jane17 - I had this same problem when I inherited a printer I had used in my office. I called Tech Support and they told me I had to have the installation disk that came with the printer when it was bought in order to get color printing. I was lucky the disk was still in my office and I was able to find it. I reinstalled the printer with that disk and the color properties were enabled with no problem. Perhaps your sister has the original disk for installation? If not, you can go to HP.com and follow the site tools to your printer. You can install online, but it takes some time. I hope this helps you a little if you haven't corrected the problem as yet. Feel free to let me know if this worked for you, and good luck.
Jo
[email protected]
Posted on Nov 10, 2007
SOURCE:
HP Deskjet 5550 quit printing red color. Installed new color cartridge HP57. Quit printing red again after 5 pages. Is it a printer problem or cartridge problem?
Have you check your color cartridge if they are properly installed.
Make sure your are not using a refill cartridge.
Replace your tri-color cartridge with original an HP tri-color cartridge.
Aug 26, 2010 | HP DeskJet 5550 InkJet Printer
My deskjet 5550 printer stopped printing in color it only print black ink i have replaced the color cartridge still only prints in blank only; i have tried calibrate printer and clean cartridge options;...
If the Cartridge and printer alignment is successfull and you are still not able to print in color, mostly the Color print is disabled in your pc
Click on START Button
Click on CONTROL PANEL
Open Printers and Faxes folder
Highlight the Printer icon for Deskjet
Right click on the printer icon and choose Printing Preferences
Under Printing preferences, you will find Printing mode - It must be on BLACK or GREY SCALE, Change to COLOR/ ALL
try printing.
Jul 03, 2010 | HP DeskJet 5550 InkJet Printer
Deskjet 5550; Windows 7; Microsoft Office 2007; not printing
That is strange
Try changing the default to a different printer (Microsoft XPS Document Writer) see if it prints to it...
Then (If that works) try switching the 5550 back to default.
If that don't do it, uninstall thee printer, reboot and reinstall the printer.
Mar 12, 2010 | HP DeskJet 5550 InkJet Printer
Hp 5550 deskjet not printing
This is typical cartridge problem.Which cartridge changed?This printer can print with the only one cartridge inside it, whatever which.Try this: Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
If this not help your printer has problem in carriage unit and need repair.
Nov 04, 2009 | HP DeskJet 5550 InkJet Printer
Hp5550 not printing
The first thing you need to do is make sure you have the correct driver so that you can re-install your printer. Then you need to go to your Start Menu and select Printers and Faxes. Delete any printers that you don't use or no longer have, plus any instances of the Deskjet 5550. Go into your Start Menu and select All Programs. Look for the Deskjet 5550 and put your mouse on it. Look for the Uninstall link then select it. Once it has finished uninstalling the program restart your computer. Insert the CD that came with your printer and follow the instructions. Your printer should now be re-installed and working. I hope this helps you solve your problem. Good luck!
Carol.
Apr 03, 2009 | HP DeskJet 5550 InkJet Printer
Hp deskjet 5550-prints a ''hp deskjet 5550 Series'' page
Hi all of you
your problem sound as you have hanged Button, try clean it and refit it.
thanks,
Hamedo
Nov 19, 2008 | HP DeskJet 5550 InkJet Printer
HP deskjet 5550 printer not printing.
could be low on ink or toner. dont you just love that? itll print out a test page which is a waste of ink but wont print out anything else.
Nov 17, 2008 | HP DeskJet 5550 InkJet Printer
Help
1st page prints perfect but the 2nd page comes out with very light and skipped printing.
Oct 22, 2007 | HP DeskJet 5550 InkJet Printer
HP deskjet 5550 sometimes prints and icon reads Toolbox not available because printdriver is not installed
thats easy! HP has a bad habit of screwing drivers up! List here what operating system you have, and the exact,with any letters behind the 5550, model number here and I'll get the drivers. I have almost every drivers for windows for that particular printer
Jun 13, 2007 | HP DeskJet 5550 InkJet Printer
HP DeskJet 5550 InkJet Printer Logo
65 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
