Question about Optoma MovieTime DV10 Multimedia Projector
Flashing temp lamp light fan
My DV10 has stopped working. When I plug it in, the Lamp and Temp lights blink faintly but no fan, no power up procedure, nothing. I tried plugging into a different wall to ensure it was not a socket problem. I tried a different power cord to rule that out as well. I even tried replacing the lamp to no avail. This unit has been rarely used with about 30 hours on the bulb, but was bought back in 2006. Any idea what it could be?
    New Friend:
Power cut
Posted on Nov 25, 2013
  • Dr Cool
    Dr Cool Nov 25, 2013
    "Power Cut"?
SOURCE: No Power
wow i have the same problem and no one has a fix love it
Posted on Sep 22, 2008
marsrover
  • 682 Answers
SOURCE: projector has no power
close lamp compartement door firmly because door switch can disconnect power from projector if not closed firmly.
SOURCE: ive had my optoma ep721 projector probably for likle 2 months and
1 of 2 things happened here. Either the power supply is spent or your lamp ballast is busted. In either case it would have to be opened and repaired professionally. may cost upwards of a new projector, so look around for a decent shop and have them test it. If you dont mind me asking, if you decide to get rid of it would you mind selling me the lamp cheaply. Doesnt matter if its burn out, just need the glass from the bulb if its not broken. Hope i helped.
Posted on Apr 25, 2009
  • 5 Answers
SOURCE: Optoma 719, can't get lamp and fan to turn on.
There is a stuffed 10v 3300uf capacitor on the power board. You need to replace it.
Bellow you can check in the picture where the capacitor is located.
Notice that in this picture I have already took the bad capacitor out and replaced with two small cords to reach the bottom and test the new capacitor.
To reach this place is not fast, several layers of plastic and metal must be removed, but is not a hard task to take the capacitor out and replace it for another.
It works just great! Now it is back on track with awesome image.
Posted on Oct 03, 2009
projdoc
  • 2237 Answers
SOURCE: We have an Optima EP
if you hear a high-pitched whir, you have a ballast problem. if you don't hear it, you have a colorwheel problem.
Posted on Nov 16, 2009
Why won't my Optoma DV10 projector won't turn on?
On an Optoma DV10 if its not the lamp timer, then it might be a cooling fan that needs replacing. Take out the old one, and look-up its part number online. If you don't feel confident taking it apart, have a qualified person do this.
May 23, 2014 | Optoma MovieTime DV10 DLP Projector
Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Goodluck..
Feb 25, 2008 | Hitachi CP-X250 Multimedia Projector
Temp light flashes and then shuts down
hi,
possiblely it is the problem of fan, try to check the radiator fan port.
later use the machine, shut off it, until the lamp fully cool.
regards
Jack
WHOLESALER AND RETAILER FOR BELOW PRODUCTS:
projector color wheel, lens and bulb, remote, lamp power, mother board. all brand and most of model.
computer mother board, memory, harddisk,
HP server, switch, and router.
Nov 21, 2011 | Optoma MovieTime DV10 Multimedia Projector
The temp light and lamp light are flashing it does not turn on.
there probably some problem on it maybe the airvents is blocked hence it overheat or the exhaust fan if there is is not working.
Feb 02, 2011 | Optoma MovieTime DV10 Multimedia Projector
Projector won't turn on and LED Temp/Lamp flashes! has new lamp
I wish you had received a relevant answer to your question, as I'm experiencing exactly the same thing here. Not sure is this site notifies people when they get responses, but did you ever figure out what the problem was?
Apr 08, 2010 | Optoma MovieTime DV10 Multimedia Projector
TV and Vedio-Projection televisions
what i would do is crack into the tv and watch the individual parts being careful not to unplug anything while you take the back panel off.....turn it on and see what happens. let me know what happens
Sep 30, 2008 | Televison & Video
Need answers
The fan may have went bad. If it's out of warranty you may open it up and try and blow some dust out of the fan to see it that may do the trick if not it may need to be replaced. Westexaudioelectronics.com
Oct 04, 2007 | Televison & Video
Tv keeps turning off?
cutta, you will most often hear a click on boot then the fans start up and lamp will then fire. The picture will start to show up....at what point does it shut off? and do you hear a click when the tv is turning off? Is it the complete tv shutting down, fans and everything that turns off? Do you see any lights on the the front panel "POWER", "STATUS" or "LAMP", what are they doing? If you see a Power, Status or Lamp light after it shuts off the below are what they mean if there is an issue. POWER - STATUS - LAMP - CONDITION/ISSUE: Off - Yellow - Off - Temp. high/dirty filter/excess room temp Off - Off - Yellow - 4000 hrs. Lamp usage warning Off - Off - Blink Yellow - Lamp Cover open Off - Blink Yellow - Off - Air Filter Cover open Off - Off - Red - Lamp failure (failed to turn On or broken) Off - Blink Red - Off - Fan Has Stopped Off - Red - Off - Circuit failure (short) or DVI cable disconnected If you want to check for the last "Error Code", after you first turn the TV on, by pressing the front panel ?DEVICE? and ?MENU? buttons at the same time and holding them for 5 seconds, it activates the Error Code Mode. The ?Power LED Light? blinks/flashes (1/2 sec delay) and then flashes again denoting a two digit Error Code indicating no problem or an error has occured since the last Initalization. i.e. "Power light" blinks 3 times (1/2 second delay) and then blinks 4 times then 1 sec delay and repeats a few times. This would mean "Error 34 - Lamp abnormality". See below for error codes..... Error Code - Description or issue 12 - No Error detected, check Power Supply 32 - Lamp Cover is open 33 - Air Filter Cover is open 34 - Lamp abnormality 36 - Light Engine (DMD or LAMP Fan stopped) 37 - Exhaust or Lamp Ballast Fan stopped 38 - Lamp temperature high 39 - DMD temperature high 41 - Short is detected 44 - DVI cable between FMT & Engine disconnected. Sorry for the long answer but it was an open ended question.
Jul 11, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Optoma MovieTime DV10 Multimedia Projector Logo
204 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
