Question about KitchenAid KSM5PS Heavy Duty Stand Mixer
Grain mill stops turning
While the grain mill is attached the mixer will stop grinding the wheat. It sounds like a clutch is disengaging or something.
    Novelist:
  • KitchenAid Expert
  • 185 Answers
It is more than likely that there is a stripped drive gear inside the mixer, either the attachment hub gear or the pinion gear has stripped and you hear the gears grinding up the nylon parts of the gear. soon it will stop altogether because the wear will be so great that it will no longer engage at all. You need to open the mixer and replace the gears that are worn.
Posted on Sep 21, 2012
    Master:
  • 492 Answers
Will it grind any wheat? I had a similar problem with the wheat overwelming the drive system and had to use smaller amounts of wheat to keep the system grinding. Do you have the feeder attached? I couldn't just load it up but had to feed a little at a time. Hope it helps. Favorable comments are apprieciated.
Posted on May 08, 2009
Seized planetary gear pin?
Page two of the KitchenAid service manual will walk you through how to remove the pin. Here is a link to that service manual:
http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Apr 03, 2013 | KitchenAid KP50PS Professional 5 Series...
Front attachment won't turn
It sounds like one of the gears inside the head has failed. You will need to remove the head and take it apart to work out which one. It should be relatively easy to get hold of the part you need once you have identified it. Please post your model number for us to point you to the right parts list.
Jan 13, 2010 | KitchenAid K45SS Classic Stand Mixer
My 6qt Kitchenaid stand mixer started making a grinding noise and beater bar keeps stopping. When I put it gently with my finger, it begins turning, only to stop again and make that grinding noise. It is...
They seem to have a plastic gear built in as protection for overloading (prob). When the machine counters to much resistance that gear will strip its teeth causing the machine to not be able to turn, that it what seems to be the grinding problem. If it is not the plastic gear then it another gear that is "stripped(of its "teeth") I hope your problem is not a severe, but if your mixer is "locked up" then at least you found the problem.
Jan 12, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Pin comes out/mixer attachements grind on bowl.
See what stops it going forward. If it's a rubber pad you can replace or repair it. As far as the pin is concerned. Is the hole worn out or the pin? Measure the pin size and see what diameter it is If you can send me a picture co7196@yahoo .com and we'll come up with a satisfactory resolve. Ned
Sep 21, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Mixer stops working
It sounds like the attachments aren't aligning correctly. I had the same problem with a Kitchen Aid. The unit should be replaced as soon as possible so you don't end up paying for repairs.
May 02, 2009 | Kenwood KM800 Major Classic Stand Mixer
Are attachments for a KitchenAid K5 compatible with the K55?
That would be incorrect. If the attachment is for a hobart kitchenaid mixer then it will fit all models of kitchenaid mixers including the brand new pro series because the attachment port and drive gear has not been changes since 1925 or 6 when it was first introduce by the Hobart company.
Apr 01, 2009 | KitchenAid K5SS Heavy Duty Commercial...
The pasta/meat grinder attachment stops turning
Its a 325 watt mixer. If you grind or mix dough often you may consider getting something stronger or turn it off every ten minutes or so and let it cool down. We burned a 325 and got the 575 watt "600" series and no problems ever since. I know these things are expensive. The 325 is more mixer than grinder. The attachements fit ANY size mixer but some are not recommended for use in all mixers.
If its quiting see my posts on "doesn't run at sitr" and "Removing the motor cover" To get inside and clean those contacts.
Feb 08, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Dough Hook Stops moveing under heavy load
Does the mixer work in any other speeds?Are you mixing pizza dough and in what speed?I service these mixers alot--i work for hobart.It sounds to me like you have a sheared key on one of the shafts.The mixer doesnt have a clutch.
Feb 21, 2008 | Hobart H600 Stand Mixer
KitchenAid KSM5PS Heavy Duty Stand Mixer Logo
113 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
