Question about Whirlpool AWOE8748 Front Load Washer
Whirlpool AW0D 6120 WITH NO POWER
No power no lights on control panel. I have checked fuse,plug and power to machine which is all ok.
4 Suggested Answers
donnastr
  • 10 Answers
SOURCE: Whirlpool washing machine power button won't turn the machine on
defective timmer
Posted on Oct 08, 2008
tzweeb
  • 318 Answers
SOURCE: push start button on control panel - machine does not start
only 2 things can cause this.
1 the control is set to lock out mode. just hold the lock button for 5 seconds and it should go back to normal mode.
or 2 the controls user interface has an internal failure. its the part that has the switches and tells the computer what to do. either way call whirlpool and see if its still covered by their warranty.
of yeah and the 3rd thing is you have no power to unit. make sure the outlet is good by trying something else in the same outlet, like a light or hairdryer.
Posted on Jan 06, 2009
marka19
  • 1430 Answers
SOURCE: Whirlpool Duet washer stuck in "control locked"
Press and hold the end of cycle button for 15 seconds this should clear it.
Control locked
Posted on Nov 26, 2010
GE Harmony Washer and Dryer will not turn on after power surge
The control panels on both machines may have fuses that need replacing after surge or a component on the panels have blown due to surge.
Nov 13, 2013 | Whirlpool Washing Machines
No indicator lights Whirlpool wdt710paym dishwasher
If it doesn't run and you have no indicator lights, check the circuit breaker for that outlet. If it is ok, test the output voltage at the plug-in for the machine (115Vac). If it is "live" then check inside the control panel (turn off the breaker first) for a fuse that appears blown. If no fuse problem, CAREFULLY (with breaker back on) see if the main switch is getting power. If it is getting power, the control board is shot...replace it!
Dec 28, 2012 | Whirlpool Gold 24 in. Built-In Dishwasher...
No power or lights in the front panel
Check the fuse / circuit breaker inside washing machine. There may be a extra control circuit fuse normally on the control PCB.
May 28, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Machine fills but does not do anything else. Fuse is ok
If the fuse is OK, check the power cord or the outlet.If it's still OK, then the problem persist on the main motor, you can replace the capacitor to fix this problems.
If still won't work, there's something happen with the control panel, maybe it burned because of waters.
Oct 24, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
No Power at Control Panel
sounds like a fuse issue. check the fuses.
May 24, 2009 | Whirlpool GHW9400 Duet Washer
Wont start
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool dishwasher stopped working...
It sounds like the thermal fuse in the control console has blown.
Turn power off to unit.
Remove the outer door panel and then the console.
Remove the black plastic cover from over the circuit board if it has one.
You should see the thermal fuse clipped to the circuit board housing.
If you have an ohm meter, check for continuity across it, it should read closed.
If you don't have a meter, unplug the wires from it and and hook them together.
Turn power back on to unit, hold door switches down and cancel cycle. The washer should drain the water.
If this doesn't work, check your door switches to make sure they are closing properly.
Nov 17, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool AWOE8748 Front Load Washer Logo
52 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
