Question about Panasonic DMR-EZ37VS
F60 ERROR ON PANASONIC DMR-EZ47V
NOTHING WORKS JUST F60 ERROR ON DISPLAY
SOURCE: Instruction Manual for Panasonic DMR-EZ47V
http://service.us.panasonic.com/OPERMANPDF/DMREZ47V-MUL.PDF
Heres is the manual link.
Posted on Dec 28, 2008
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Posted on Jan 31, 2009
SOURCE: F60 Error message on DMR-ES40V unit
Unplug the unit.
Plug back in and wait till you see 000000.
Press and hold the power button in at least ten seconds or until the clock shows up.
This worked to fix mine.
Posted on Jul 22, 2009
SOURCE: DMR-es40v f60 error
Problem for Panasonic DMR-ES40V DVD-Video Recorder with Built-in... Maching displays F60 as soon as it's turned on and
Posted on Jan 03, 2010
SOURCE: Panasonic DMR-ES46V shows F60 Error
I have same problem with es40v - f60 error with no response to troubleshooting protocol. This machine also was used very little & also has a history of turning itself on. Panasonic used to make high quality products. A shame that their products are no longer trustworthy. I can understand that machines break - i'm very frustrated to learn replacement parts are not available. Guess i need to re- think brand loyalty.
Posted on Feb 12, 2010
Code F60 on DMR-Ez47V
Unfortunately, the F60 error means that the video processing board (digital PCB board with the HDMI port on it) has a failure. Often this happens when the capacitors on the board fail. Replacing the board or the failed components on the board is usually necessary. Some of the components may be available here: https://www.encompassparts.com/model/MSCDMREZ47V/_/_/Panasonic/DMREZ47V/DVD_RECORDER .
First you can try to reset the unit. Unplug it. Then plug it in after a few minutes. Then when you see the string of 0's, press and hold the power button. Then try to power up the unit normally. Alternatively, press and hold Stop and Hold while you power on the DMR-EZ47V.
I hope this helps. Unfortunately, I am not sure which part number applies to the part you need from the PC Boards available from the site above.
Dec 13, 2015 | Panasonic DMR-EZ47V DVD Recorder/VCR
What error code is f 60? is it repairable?
F60 error is associated with a failure of one of the main circuit boards inside the unit.
Unfortunately it may not be economic to repair unless you could source a failed unit of Ebay and are confident in electronics work.
One thing you should try is a factory reset which although unlikely to resolve the error will do no harm and there is always an offchance that it will help.
To do this;
1) Flip down the front panel to reveal the channel buttons at the front of the unit itself.
2) With the recorder on press and hold the channel up and down buttons at the same time until it says "Bye" on the display.
3) Wait 10 seconds before powering up and try the unit to see if it has helped.
Please do leave a vote for the solution. Thanks.
Aug 19, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EZ47V DVD Recorder / VCR Combo RC1 errior message how do I fix this problem
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ47VK
http://www.retrevo.com/support/Panasonic-DMR-EZ47-DVD-Players-manual/id/2811ag420/t/2/
To get into Service Mode, first put the machine in STANDBY mode, then press the buttons ChUp OPEN/CLOSE and REC all at the same time on the front panel (Ch Up is hidden inside the AV3 input flap). Eventually the front panel display will show "SERV" (after its "HELLO" messages). Anyway, pressing [6] then [5] on the Remote Control tells me that I have an Error Code of "04" which is a Digital PCB or Communication Error (whereas an Error code of "02" means a "Defect of RAM drive"). (To exit from Service Mode, press [0] then [0] which should get you back to "SERV" and then POWER-OFF the machine).
Hopefully, your manual will display your error codes.
Perhaps the remote control is not set to the same control code as your DMR-ES40V. Codes may be set to 1, 2, or 3 on the remote by holding down the enter button and one of those number buttons for several seconds at the same time. The factory default is code 1. Try 1 first. If that doesn't work try 2. If that doesn't work try 3. If one of those codes doesn't work you may have a bad remote or a bad sensor on your machine. On DMR-ES35V models the sensor is located just to the right of center behind the black window
Jun 23, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
I am getting a U99 error code. The only function
The "U99" error code signifies a "general communications failure."
It is not associated with one specific problem.
It can be related to the version of firmware your DVD recorder is currently using and it has been associated with the TV Guide on screen guide.
If your unit displays U99, turn the power off-unplug the
unit for 5 minutes, and reconnect the power.
If U99 reoccurs, please contact the Global Service Center Network for assistance.
Feb 26, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic dmr-ez47v won't recover from u61 code faul. Unit keeps ejecting tray and switching off.
no solution sorry, I have same problem. any one else with same prob?. Thought panasonic was a good make, 18 months old and now knackered.
Dec 01, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
DMR-es40v f60 error
Nov 13, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Panasonic DMR-EZ47V U99 errors
I see. On this issue you may need to double check the technical specifications of the product.
Here's the link, it may give all the details you need.
Nov 03, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
PANASONIC DMR-ES46VS Front Panel buttons quite working
I have a Panasonic DMR-EZ47V. All of the panel buttons plus the remote will no longer work. I get a display showing F60. Unit is not very old.
Nov 06, 2007 | Panasonic DMR-ES46VS DVD Recorder/VCR
Sep 02, 2007 | Panasonic DMR-ES46VS DVD Recorder/VCR
Panasonic DMR-EZ37VS Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
