Question about Whirlpool MT4070SK 700 Watts Microwave Oven
When you push door button to open door it will not open
I have a Panasonic Microwave Model NN-SD277. How do you access the workings of the door opener button? It is broken so the door won't open.
You have to remove the outer cover, the plastic lift levers are behind the door open button / lever. Caution!, panasonic discontinued a lot of those and getting a replacement part can be hard at times. Dont waste your time trying to glue it. After watching people try to glue or epoxy those cheap plastic parts for so many years. I have to warn folks to not waste your time trying. .It will not hold!!!! Look online and try to find a replacement part somewhere. It will be one of two parts. the door open button you push, or the door open lever that the front button pushes against. If you unplug the unit and remove the outer cover simply look behind the front control panel and when you push the button to open the door you will see where it is supposed to lift to open the door. The broke part is your problem, may be a piece laying in the bottom.
Aug 14, 2017 | Panasonic Microwave Ovens
The door no longer pops open when the latch button is pushed. How do I fix this?
One of the door latch arms or the latching mechanism inside the oven have broken. you may have to buy a complete door lock / latching assembly . Might not be worth it. Check with your nearest parts supplier.
Apr 09, 2015 | Emerson Microwave Ovens
Can not open the door in microwave the release button springs seem to not working can that be fixed. Have opened the release button but cannot see the problem
Do not pry the door open since there is an easier remedy which will lead you in the direction that you need to fix your problem. Take the cover off after you disconnect the power to it. Once you have taken the cover off (only a few screws) you will be able to see the two latches that hold the door closed and the link that opens both of them. You can just lift both latches at the same time and it will open. After you have done that take a good look and press in on the open door button and you will see where you have the problem of the door hanging. That button should push a linkage that pushes up on both latches at once to open the door. It is spring loaded so that it comes back down so that when you close the door it will hold the door close.You need to take the cover off the microwave so that you can pull both of the latches that hold the door closed up. When you push the button in it engages a linkage that pushes both taches up at the same time to open the door. It is springloaded and will come back down during normal operation to hold the door closed when you close it again. That area is where your problem is. By looking at what happens when you press the open door button you should be able to readily see where the problem lies in that linkage
Feb 12, 2011 | Sharp R-1610 Microwave Oven
Broken door opener button
sounds like the door latch hook is broken you will have to seek a repair man for this
Feb 12, 2010 | Whirlpool GT4185SK Microwave Oven
Door won't open. push button doesn't work
It may be a broken door open lever or a worn door open button or both.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 06, 2009 | GE Microwave Ovens
Can't open microwave door
It sounds like the push to open lever is cracked or broken. You have to remove the 'wrapper' to open the door manually from the inside to check the 'door keys' or door hooks to make sure that they are in tact. Then, check the door opening lever between the 'push to open button' and the lower door key.
Sep 11, 2009 | Microwave Ovens
Sharp Microwave model R-1850A door won't open
buy a boddle of WD-40 and try spray some in the raded spots.Im not a big specialist in microwaves.hope it helps
May 10, 2009 | Sharp R-930AK Convection/Microwave Oven
THE DOOR DOES NOT OPEN
Take a look at the button you push to open the door.
You will need to remove the panel the door button is on and get to the back side.
This is very easy to do after you remove the cabinet.
The button you push to open the door is held in place with four tabs. If one of them tabs break it jams the button.
Feb 18, 2009 | Neff H7871 Convection/Microwave Oven
Microwave door won't open when I push the button!
check door open mechanism, any broken change the mechanical parts,
Oct 27, 2007 | DCS CMO-24-SS Convection/Microwave Oven
Whirlpool MT4070SK 700 Watts Microwave Oven Logo
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
