Java control panelwill not run (no display) - Computers & Internet
    Habit-Forming:
  • 106 Answers
Uninstall all java updates and utilities then go to www.java.com and reinstall
Posted on Nov 25, 2013
Java will not load onto the computer how do i fix this problem
What others are saying:
By Brien Posey in 10 Things, August 1, 2013, 10:33 AM PST 1: Verify the error I have seen a couple of situations in which an installation error was displayed even though Java installed correctly. Therefore, I recommend beginning the troubleshooting process by verifying that Java really isn't working. The easiest way to do this is to go to this special test page, which will tell you conclusively whether Java is working.
  • 2: Remove version conflicts If the installation appears to succeed, but Java is not working, check to see whether the Java Control Panel exists within the Windows Control Panel. If the Java Control Panel is missing, the problem is often related to a conflict with JavaFX or legacy Java code. In these situations, you should use the Windows Control Panel to remove any instances of Java. After doing so, use theMicrosoft uninstaller to clean up any Java fragments. Then, try installing Java again.
    3: Use the offline installer The Web installer for Java tends to be a little bit buggy. That being the case, the offline installer package will sometimes succeed where the Web installer fails. You can download the offline installer for Windows.
    4: Try the 32-bit version If you're having trouble installing a 64-bit version of Java, try using the 32-bit version instead. Although 64-bit Java would seem to be the logical choice for use on a 64-bit operating system, the 32-bit version seems to have fewer issues.
    5: Install with administrative privileges If you run into problems installing Java on Windows 7 or Windows 8, try installing Java as an administrator. To do so, download the offline installer and save it to an empty folder on your hard disk. Then, right-click on the executable file and choose the Run As Administrator command from the shortcut menu.
    6: Temporarily disable User Account Control Some people have reported that the User Account Control feature gets in the way of installing Java. If you suspect that the User Account Control feature is causing your problem, you can temporarily disable it until after the installation is complete. The method for doing so depends on the version of Windows you're using. In Windows 8, the option to change the User Account Control settings is found in the Control Panel under System And Security ' Action Center.
    7: Set Internet Explorer's security to the default level If Internet Explorer is configured to use a higher-than-default security level or if it is running a custom security level, there is a possibility that Java may be blocked. You can set Internet Explorer to the default security level by opening your browser and selecting the Internet Options command from the Tools menu. When the Internet Options dialog box appears, click on the Security tab and click the Default Level button. Click OK to save your changes.
    8: Temporarily disable your antivirus scanning There have been some reports of antivirus software preventing Java from being installed. If you want to see whether your antivirus is causing your problem, I recommend downloading the offline installer, updating your antivirus software, and then performing a full system scan. This will help make sure that there are no infections on your system before you disable the antivirus software.
    Once you're confident that your system is free of malware, you can temporarily disable the antivirus scanning process. The method of doing so will depend on the antivirus product you are using, but often it is possible to right-click on the antivirus software's taskbar icon and choose a pause option from a shortcut menu. When you have finished attempting your Java installation, don't forget to re-enable antivirus scanning.
    9: Check for a corrupt user profile According to Microsoft, a corrupt user profile can cause problems with Java installations. Try creating a new user and assign that user local administrative permissions. Then, log in using the new user account and try installing Java.
    10: Use the System Configuration tool Since problems with Java installations are often related to other software that is running on the system, you may be able to fix the problem by temporarily disabling other startup items. The easiest way to do that is to open a Run prompt and enter the MSCONFIG command. This launches the Windows System Configuration utility, which allows you to choose the startup items that you want to disable without requiring any permanent changes to the operating system.
    Other tricks? Have you found some other workarounds or fixes for dealing with Java install headaches? Share your suggestions with fellow TechRepublic members.
  • I have had the same issue on certain machines.
  • For me uninstalling and clearing the Cache before getting a new version worked most often.
  • Only use the Java site for download
  • use the ten suggestions above
  • Java can be a pain
  • good luck
  • Jul 03, 2014 | Dell Dimension E310 PC Desktop
    How can i corredt this error ??
    report to mojang and play the pe version for a while. or you can delete your minecraft file and download it again
    May 23, 2014 | Kaltner.net Minecraft Mobile Admin
    When starting the harmony harmony remote software (rel. 7.7.0) I always get the error "Fatal exception caught executing JVM Runtime. Error starting JVM Runtime" and the software does not start....
    Hi. This does sound like a Java error. Since the Harmony software is a Java application, you need to have the Java run-time installed on your computer in order for it to work. I suggest visiting http://www.Java.com to install the latest version of Java on your computer. It's completely free.
    Once you have Java installed, you can download and install the Harmony software again. This can be done at http://Logitech.com/myharmony.
    Hope this helps.
    Aug 15, 2011 | Logitech Harmony One LCD Touchscreen...
    PrintMaster 2011 Platinum <3.0.70> encountered
    Hello, I had the same issue, I found this article http://support.encore.com/technicalsupport/kb.aspx?kb_id=1250&product_id=2643 It pretty much says that your regional setting is not set to English United States. Changing that will resolve the issue. Under Control Panel > Regional Settings.
    Dec 17, 2010 | Broderbund PrintMaster Platinum
    I keep getting a notificatiom asking what connection i want (dial up or bluetooth). when i try to adjust my toolbar (access my toolbar settings everywhere) i am told i am offline when i am clearly...
    Clear the Internet Explorer (IE) Browser Cache
    The following steps detail the process of clearing the cache in IE version 6. If you are using a different version, your steps
    might vary slightly.
    Follow these steps to clear the cache:
    1. Open IE browser.
    2. Select Tools > Internet Options. The Internet Options window is displayed.
    3. Make sure that you are in the General tab.
    4. In the Temporary Internet files section, click Delete Files. The Delete Files window is displayed.
    5. Check the Delete all offline content box.
    6. Click the OK button.
    7. In the Internet Options window, click the OK button.
    Clear the Java Cache
    The following steps explain how to delete the cache for Sun Java version 1.5 or higher on a Windows XP machine.
    Clear the Cache for Sun Java Versions 1.5 and Higher. Follow these steps to delete the Java cache:
    1. Select Start > Settings > Control Panel.
    2. Select Java. The Java Control Panel window is displayed.
    3. In the Temporary Internet Files section, click the Settings button. The Temporary Files Settings window is displayed.
    4. Click the Delete Files button. The Delete Temporary Files window is displayed.
    5. Make sure that the Applications and Applets box is checked.
    7. In the Temporary Files Settings window, click the OK button.
    8. In the Java Control Panel window, click the OK button.
    Restart the Browser
    Nov 27, 2010 | HP Computers & Internet
    McAfee 2010 will not work with my current version of Java
    If McAfee 2010 is running fine. Uninstall java from the control panel and reinstall java from java.com. Java will then tell you if the software has loaded correctly.
    Nov 07, 2009 | Mcafee Total Protection: Windows
    I cant use my java games.jar format in star s5233.
    plzzzzzzz hlp me out. how 2 install it??
    when i use 2 transfer jar files from pc to mobile. but when i m trying 2 run dat games. it displays unsupported file types. but Java games are there in phone specifications . plzz post a solutiuon . thank u.
    Jul 11, 2009 | Samsung Cell Phones
    Source code in java that display bio data
    program that display first name and second name
    Jun 18, 2009 | Sun Java Programming Language (cdj-275)
    I want to execute java command through php
    1. Copy JavaBridge.jar to the current directory.
    Add JavaBridge.jar to your Java application. Edit the manifest MANIFEST.MF
    2. Recompile your Java application.
    3. Run your Java application. This time your application doesn't display anything and doesn't return.
    4. Create a PHP test script.
    5. Open a new command shell and run your test script.
    6. Your PHP script has called the method hello(), which should display a message dialog.
    7. Note that the above code doesn't create a application-modal dialog. The communication can be traced by starting your application with the options: java -Dphp.java.bridge.default_log_file= -Dphp.java.bridge.default_log_level=4 -jar HelloWorld.jar
    for more read INSTALL.STANDALONE documentation
    How to execute Java Programs using console command prompt
    May 22, 2017 | The PHP Group PHP
    Computers & Internet Logo
    18 people viewed this question
    David Payne
    David Payne
