Question about Craftsman Saws
How to use 932371 fence guide system - Craftsman Saws
Suggest one of the best wireless dog fence brands?
According to me, one of the best wireless dog fence brands is perimeter technologies wireless dog fence. It has a variety of products for the pet owners, there are in-ground dog fences and wireless dog fence system also. It also has wi-fi enabled system which is truly one of his kind. In this package, you will get a receiving collar, transmitter and a charger.
Nov 03, 2017 | Dogs
Write about the PetSafe stay+play wireless dog fence?
According to me, one of the best wireless dog fence is a PetSafe stay+play wireless fence. If you prefer outdoor camping, travelling then this portable dog fence system is perfect for you. You can take this dog fence anywhere without doing set up for the whole day.
Nov 03, 2017 | Saws
How long does it take to charge battery in solar fence charger?
    1. A solar powered electric fence energizer usually contains a battery for energy storage. The solar panel collects the energy from the sun and charges the battery. Lead acid batteries, which are used in solar fence chargers, typically last around 3 years, or around 1,000 days of charging.
      About Fence Chargers - Zareba Systems
      www.zarebasystems.com/learning-center/all-about/fence-chargers
    Feedback
  1. About Fence Chargers - Zareba Systems
    A solar powered electric fence energizer usually contains a battery for energy storage. The solar panel collects the energy from the sun and charges the battery. Lead acid batteries, which are used in solar fence chargers, typically last around 3 years, or around 1,000 days of charging.‎What can I do to prevent ... - ‎What factors should I consider ...
    [PDF]Fence Controller Installation - Zareba Systems
Jan 01, 2016 | Cars & Trucks
Need a rip fence
Howdy, Here is the ordering page link with the rip fence (called edge guide, part number 2610997206 by Bosch) from Bosch:
https://www.boschtoolsservice.com/Search/QuickPartsOrder.aspx
I would recommend looking in a pawn shop or ebay as the rip fence is nearly 100 dollars as a replacement part.
Hope this helps a bit:)
Regards, Farmerbear
Sep 08, 2010 | Bosch 4000 - 07 Electric Table Saws
New table saw, timber runninig off away from guide, saw blade running its own line,do i need to reset the guide.
The guide is called a fence. The fence should be positioned to the right of the blade. When using the fence, the largest part of the board goes between the blade and fence. Fences are typically have some relief toward the end, so you don't get the blade cutting on it's way down, and then cutting again on it's way up.
Apr 22, 2010 | Craftsman 10" Table Saw
Blade isn't cutting well. It smokes and the wood rides up as it is cutting. The saw is 14 yrs old but blade has only been used a few times. I think it needs alignment. Can I do that myself?
You should be able to adjust the fence but every model is different so I probably cannot tell you exactly how. My Biesemeyer fence has 2 set screws on front guide of the fence for parallel adjustment to the blade (this fence is a single piece fence). I had a Sears contractor saw that had 2 bolts on the top of the fence that needed to be loosened, the fence moved parallel, and the bolts tightened again (the Sears fence was a bolt together fence). Whatever fence you have I would think the adjustment would be on the front part of the fence. I would remove the fence (the fence only, not the guides) from your table saw and take a close look at it for any adjustment screws (the Biesemeyer set screws are somewhat hidden) . If the fence bolts together you will probably need to loosen the bolts to do the alignment. There is a quick check you can make to verify the problem is the fence not being parallel to the blade because your problem could also be caused by a bent saw blade arbor (the saw blade would wobble as it turns)
ø Lock your fence down and measure from the front of the blade to the fence and from the back of the blade to the fence. These measurements should be within 1/32” (ideally is should be zero).
ø If the fence passes the test above, you can see if your saw blade shaft is bent by sliding the fence very near the blade, locking the fence down, and rotation the blade by hand (unplug the saw first). If the blade rubs on the fence as it rotates then you could have a bent arbor, a bad arbor bearing, or a bent blade.
Oct 03, 2009 | Craftsman 10" Table Saw
Fence is out of alignment and I am not sure how to repair it?
There is a couple of screws holding the fence perpindicular to the front guide. loosen slightly, square up fence and retighten screws.
Jun 11, 2009 | Craftsman 10" Table Saw
All trays are reading a4 instead of 8.5x11 how do I set to read
Their are 2 fences in each tray, (fences are the long guides that touch the paper to keep it in the middle of the tray) there a probably a slight gap between the paper and the fences. Unlock the fences and move them Snuggly (it that a word?) against the paper and lock them again, close the drawer and the display should change. What model and brand copier is this?
Apr 03, 2009 | Canon imageRUNNER 5000 Copier
Can I mount a Delta 36-T30 T2 30-Inch Fence and Rail System on my
I just installed a Delta T2 fence on my 10" Craftsman Table Saw. It's 27" deep. The bushing either could be relocated or you could use spacers on the front, back, or both on the saw to get the required distance. Also, you'll have to drill new holes, however, I used one of the existing holes in the front and back of my saw as well.
Mar 11, 2009 | Delta 36 T30 T2 30 Inch Fence And Rail...
Blade Alignment?
By splitter I take it you mean fence. If this is correct there could be a couple things that I would look for. UNPLUG saw and check the blade at 0 for being inline, make sure flanges are on correctly and finally what I would look at is the adjustable table bringing the fence toward the blade. Loosen lever and move it to the first slot where the guide would go align the front of fence and lock lever then check the back of the fence to make sure it is straight. If not you would have to adjust the back rail to align it. What I made to do this is 2 of the rails from the guide slide into the slot and on the back of the saw are 2 10MM bolts that need to be loosened and the rear slide moved one way or the other after loosening the lever push the fence tight to whatever you use as a guide and snug the bolts move the fence away and then bring back rechecking alignment sometimes you might have to try a couple times but it should work. Tighten the bolts and again recheck If not let me know and I will find a manual for you to download
Feb 20, 2009 | Dewalt DW744S 10" Portable Table Saw with...
Saws Logo
450 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
