Question about Whirlpool Duet GHW9150P Front Load Washer
My bosch axxis WFL 2060UC pump is making horrible nice when pumping water out it looks like I need a new pump how complicated is replacing it
    Genius:
  • Whirlpool Master
  • 1,474 Answers
It is not too hard ,quite easy in a bosch, I find utube video demonstate this very well or Espares.co.uk website, Make sure no coin in it first as could be cause.....
Posted on Nov 26, 2013
4 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Whirlpool washer Duet model ghw9100lw
Okay, it sounds like you could very well have something lodged in the pump impeller. You can check the pump and clean the reservoir to see if there actually IS something there, and to see if clearing it will enable the washer to drain. The following link explains how:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
Follow these instructions, you may get away without having to order any replacement parts. If you can hear the pump running, there may be a chance that the pump still may be operational. However, if something has been lodged in the impeller for a while, the pump may be damaged to the point where it no longer pumps like it should. The only cure for this is to replace the pump. The next link gives you step-by-step tips on how to do it:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
Many of the steps are similar, but I try to be thorough. To answer your question, yes, this can be accomplished by the average do-it-yourselfer. You can find a replacement pump at searspartsdirect.com. Type in your model number as "GHW9100LW0" and the pump can be found under the "Pump and Motor" heading as item number 10 (part #8181684). The pump is sold as a complete assembly. I noticed that the pump is currently listed as being on backorder. It may take a couple of weeks for it to ship. If you need the pump sooner, repairclinic.com also carries it, but charges more for it. If decide to go this option, use the part number provided by Sears.
I'm still a little miffed by your symptoms. Normally, a drainage problem has an error code associated with it. Did the washer flash any codes on the front panel display? If so, you need to provide that information as well. If you require further assistance, please let me know. I hope this helps you.
Posted on Aug 27, 2008
SOURCE: Had a pump to go out on my duet washer. replaced
THIS IS A BREEZE TO FIX COUPLE SCREWS AND CLAMPS IS ALL THERE IS TO REMOVE AND REPLACE IT.I DID AND I AM 66 AND A WOMAN..LOL
Posted on Oct 29, 2009
  • 74 Answers
SOURCE: when washer is pumping water out it makes a loud
sounds like something in the pump
Posted on Nov 18, 2010
Bosch Axxis washer leaks underneath
take top off at back and check valve ,it should be at the top . Also check front rubber boot for rips, this is a big problem in all brands.
Nov 21, 2013 | Bosch Axxis WFL 2060 Front Load Washer
Bosch WFL 2872 washing machine that is leaking during wash/rinse cycle. Looks like it is due to rubber manifold between drum and pump - how difficult a repair is this?
Bosch WFL 2872 washing machine that is leaking This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
or it could be the seal
Oct 09, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 won't spin or drain. Still full of water
Have you checked for any blockages, in the drain pipe? If that doesn't help you might have a bad pump, here's the part:
http://www.appliancepartspros.com/modelsearch_model.aspx?model_id=232480&pkw_=pump
Mar 05, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Replaced the sump pump, now the machine will not
There will almost certainly be something stuck in the pump again. Possibly the same thing that happened to the last one.
May 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Terrible noise when draining
Possibly more hair pins in the pump or possible the pump is faulty check that the propellor is not loose if so a new pump is needed.
Apr 06, 2010 | Bosch Axxis WFL 2060 Front Load Washer
How can I detach the pump hose and replace it?
to remove outlet hose where it exits machine it just twists and pulls is held in with an o,ring if you mean internal hose this is more complicated you need to remove front panel to gain access,once you have done this removal is self evident.
Jan 20, 2010 | Bosch Axxis WFL 2060 Front Load Washer
My Bosch Axxis WFL pump drain blocked. I had a
Hi there, i have prepared two links. The first one is the original manual you requested and the second link refers to the quick reference guide.
Click here for the first link to your original manual.
Click here for the quick reference guide.
Feb 25, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis Washer WFL2060 leaking when filling
yes.you are right.somethin might have cracked.
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Dec 12, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch WFL 2060 Washer pump issue
If the pump is working then you will not need a new board..
Remove the pump from the m/c, connect live and neutral supply to the pump, it should run.
If it does then your problem could be an internal blockage in the m/c.
Hope this helps
Dec 02, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
71 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
