Question about Samsung Microwave Ovens
Stripped screws on my expensive Samsung oven door
SMH1622B 1.6 cu. ft. Over-the-Range Microwave (Black) how do I remove the cover
there should be screws around the back and at the front corners at the bottom then it should pull off
Mar 03, 2013 | Samsung SMH7178STD Microwave Oven
Samsung microwave oven model smh9207st shows 5e
Try heating up touchpad with blowdryer , if that doesnt work replace touchpad.... On the smh9207st remove plastic cover from the back of the door . Remove 4 screws and 1 screw at the top of the door . Unplug two connectors Gently. ... Peel off front touchpad . Install is reverse of removal . Be safe .....part was $45 @ repairclinic.com
Jan 21, 2012 | Samsung Microwave Ovens
How do i remove the cover to change the light bulb inside?
The bulb is positioned at the top of the oven, accessible only from the outside. You'll need to pull off the top and bottom trim strips, remove the bottom trim strip locators, remove 2 fixing screws from the left edge of the oven (with door open), and the 2 fixing screws from behind the top trim strip. The oven should then just slide out. You only need to pull it out 6 inches or so to gain access to the bulb cover. You'll need a T20 driver to remove the cover, then the bulb unscrews as it has an SES fitting. Bob
Nov 20, 2010 | Neff H7871 Convection/Microwave Oven
Replace light bulb on the Neff H7871 combined oven and microwave.
Mar 17, 2010 | Neff H7871 Convection/Microwave Oven
The opening door handel broke off.
This is a generic response to your comment
Look at the inside of the door, you will probably find a plastic strip which can be pried out. Underneath the strip, you will find the screws that hold the door together. The screws may be "torx" head.
Take pics of your door with your cell phone as you work and remember, most doors are spring loaded. Watgch your fingers.
Once the door is split open, replacing the handle should be a simple matter.
I hope this helps you
a
Sep 22, 2009 | Jenn-Air JMV8208A Microwave Oven
Need to dissemble microwave oven door GE model JVM 1631 BB 002 to remove spider.
Remove the inner strip around the door called the choke. If there are no screws visable it just snaps in place and does break if you are not very careful. This will give you access to the screws holding the outer frame piece and handle on. keep in mind, any repairs done to the door will necessitate a RFe leakage inspection. Boil some water on the front burners and cook the little guy and leave the door alone.
Eric
Jun 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Repalce Door handle on GE Profile model number SCA1000DBB03
There're some half a dozen or so small screws securing that frame to the door face. These screws must be removed. Then, the frame can be pried out by releasing the plastic snappers (with a flat screwdriver) while in the same time gently helping the frame to detach from these snappers' hold and the door face. It's a tidious, somewhat annoying task. The snappers may and will even likely break in the process, but aren't needed for the frame to be resecured to the door face after the handle is replaced. Note that the broken ends of the handle must be held with a pair of pliers or a flat screwdriver needs to be inserted bewteen each of them and the hole, or the ends will turn with the screws. This is because the metal screws' grip of the plastic handle broken ends is very strong and will otherwise won't get separated.Once the above is accomplished, reassembling the door is a brease.
P.S.: The dual end latch may interfere somewhat with the job and can be removed for the prtocess to be undertaken without it disturbing. It's easy to remove and replace that latch, including its spring.
Nov 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Profile Microwave and the handle is broken....
I have the same issue. The Handle broke off my GE Microwave Oven (Model JVM1190SY 001). GE does not sell the handle seperately from what I can tell. I just ordered a new door. It's rediculously expensive. I tried to replace the handle with a nice drawer pull but couldn't find a size pull to match and I broke the plastic cover trying to get access to the screws for the handle, which is why I decided to buy the new door. Hopefully installation is not that difficult. This oven was manufactured in 2001, seems the handles have a 7 year life span.
May 28, 2008 | GE JVM1190SY/WY/AY/BY Microwave Oven
Handle
when door is open on the edge you wil find a plastic strip .remove carefuly with flat screw driver .when removed youwill find the screws holding the handle undo screws and replace .dont 4get to replace plastic strip
Apr 23, 2007 | GE JVM1440 Microwave Oven
Microwave Ovens Logo
21 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Devabhakthuni...
Devabhakthuni...
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
