Question about Rockford Fosgate Punch 801S Car Audio Amplifier
Will my car handle a rockford fosgat 801s power load?
Will i need a capacitor? 2004 pontiac vibe. Also I want to run 4 12's at 300 watt rms wired at 2ohm. Wire from channel 1 to sub one them directly to sub 2. channel 2 to to sub three then straight to sub 4.
  • 655 Answers
Hello dreww1005,
If your alternator and battery are in good condition, you probably don't need a capacitor. At maximum output, the 801S will need to draw a little over 30 amps at 12.8V. The specifications call for 8-gauge power and ground wiring and a 40A primary fuse. The Vibe's electrical system should be able to handle it OK.
Hope this helps.
Posted on May 08, 2009
1991 toyota tercel std... Is the stock battery n alternator enough for three rockford fosgate p300.2 amps? Wondering if I just need capacitor or heavy duty battery and or high power alternator? Thanks
Those amps draw 300 watts RMS at best. So a 900 watts total load will be fine on the stock charging system. All three amps will never be drawing max power for a significant amount of time anyway. Just make sure you run 4 gauge of thicker power wire to the amps to minimize power loss. Use the same size ground also.
Good Luck
Dec 04, 2013 | Car Audio & Video
What kind of amp can adequately power P112 S8 subs
you shouldnt run it at 8 ohm it shows what ohms it can handle . to run it at 1 ohm you would need 2 subs to do this. and no i wouldnt run an 8 ohm sub on the amp.
Aug 23, 2012 | Rockford Fosgate Punch Stage P112 S8 Car...
I have a Punch 800a2 amp and tommorrow im getting the Polk Audio db1222. so my question is do i need a different amp or should this be sufficiant. 12" 2 Ohm db Series Subwoofer Power Handling: Peak:...
Not sure if you are getting two subs or single?
Anyways, amp is rated at 800 watts and probably under rated so it will push sub. Remember that you don't need to worry about max power, rather focus on RMS power rating.
Jan 13, 2011 | Rockford Fosgate Punch 800a2 Car Audio...
What is the output of the 451s rms power
Dynamic Power Rating (measured at 14.4V):
  • Bridged Into A 4-Ohm Load: 450 watts x 1
  • Per Channel Into A 2-Ohm Load: 225 watts x 2
  • Per Channel Into A 4-Ohm Load: 115 watts x 2
Apr 14, 2010 | Rockford Fosgate Punch 401S Car Audio...
I have one 12inch 1000 watt mtx sub what size amp should i buy
Hello taona80,
If the 1,000 watts is RMS, I'd recommend an amp in the 750-1,000 watt RMS range, perhaps like the Alpine MRP-M1000 or Rockford-Fosgate T1000bd. If the 1,000 watts is peak power, the subs continuous (RMS) power handling is much lower, probably 300-400 watts. In that case, I'd recommend the Alpine MRP-M500 or Rockford-Fosgate T500-1bd.
Nov 09, 2009 | Nitro BMW-482 Car Audio Amplifier
I installed a sony 600watt amp and it works but old rockford fosgate 200 hit harder how do i make my amp louder and evenly spread throughout my car
Hello jmanbutt99,
The old Rockford-Fosgate was probably producing the rated power. The Sony is most likely overrated. But, it's supposed to be stable on each individual channel down to 2 ohms and will deliver 65 watts RMS into that load. So to get the most from it, your best bet would be a pair of 4 ohm speakers paralleled to each channel. A relatively efficient speaker like the Kicker 07DS600's shown here should provide pretty good sound.
http://www.crutchfield.com/p_20607DS60/Kicker-07DS600.html?tp=105
These will work with as little as 6 watts RMS and can handle up to 50 watts RMS so the Sony should power them really well. They're 4 ohm so a pair in parallel will present a 2 ohm load.
Hope this helps
Oct 30, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Rockford Punch HE2 wiring question.
if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
Feb 05, 2009 | Rockford Fosgate HE2 RFP4212 Car Subwoofer
Old rockford fosgate power 1001bd
The 1001BD will produce it's rated power (1000 watts RMS into 2 ohms).
Nov 25, 2007 | Rockford Fosgate Power 1001BD Car Audio...
Rockford Fosgate 501bd question
that amp should work fine with those speakers,just make sure that they(speakers)are wired for 2 ohms.at 500-600watts coming from amp, you should be getting 250-300 watts per speaker,just dont crank your gain too high on the amp.
Aug 29, 2007 | Rockford Fosgate Power 501BD Car Audio...
Rockford Fosgate Punch 801S Car Audio Amplifier Logo
245 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
