Question about Lincoln Electric Plasma Cutter, Pro - Cut 25
Have to hit back of nozzle to work
We set up the cutter as per instructions, but have to hit back of the nozzle with something for the arc to strike. We this problem and replaced the entire stinger end, but are having the exact same problem.
2 Suggested Answers
  • 173 Answers
SOURCE: My Lincoln SA 200 welder will not rev up when I strike an arc.
check the solenoid make sure its opperating ..you will have to check the whole system.. starting with oil pressure switch making sure it is letting 12v go thrue. and also making sure pc board is grounded . and then checking resistance of the idle solenoid .....also the rhostat has a wire that goes to the pc board and as u strike a arc it idles the welder up
Posted on Sep 14, 2012
Hello my name is Darrell I just recently bought a Lincoln 125 hd wire welder at home Depot unboxed and set up as per instructions wire feed is fine but will not strike an arc can you he
Good evening Darrell, check that all your connections are correct and tight,and that the polarity is proper.do you have the right amperage from your fuse box. Good luck Jeff
Aug 27, 2017 | Lincoln Welding Tools
1600mx wont run in forward over load light comes on
Most common reason is that there is paper would around the cutters, imposing an additional load on the machine. You will need to access the cutter assembly (disconnect all power) and manually remove all of the paper that has impinged between the cutters.
If you have run any labels or paper with gummed strips through the cutters, you may wish to consider throwing this one away and buying new. (In all fairness, it "can" be cleaned, but it is going to be a real dickens of a job to do).
If you decide to keep your shredder and clean the cutter assembly, remember to oil it on a regular basis per the instruction manual.
As for me, I use Fellows shredder oil
Fellowes Shredder Oil 12 oz Bottle with Extension Nozzle 35250
and oil my machine every time I dump the cuttings. I run a bead of oil in a serpentine pattern over a sheet of paper and then just shred it. (If you have never oiled the cutters, it may be too late to do so now. Something you need to do on an on-going basis).
Jan 23, 2015 | Royal 150MX Cross-Cut Shredder
Will not arc
Sounds like the voltage is not going to the tip. I would suggest taking this in for repair.
Dec 07, 2013 | Hobart Airforce 250ci Plasma Cutter 12...
Machine turns on, air compressor runs but will not strike an arc
sounds like the voltage is not getting to the tip. I would suggest taking this in for repair.
Pilot arc is highely spreaded
change the cutting nozzle
Mar 23, 2012 | Hobart Welding Tools
Spectrum 2050 plasma cutter will not arc
Possible failure of the trigger switch and or the cable back to the unit. Use an ophmmeter to check that the trigger and cable are good,
Then with the ohmmeter check the continuityu of the cable to the electrodes,
Connectors are always suspect.
These are starting ponts to check.
Mar 04, 2010 | Miller 903777012 SPECTRUM 2050 PLASMA...
No full arc
the spark that you see when you touch work peice is high frequency,recheck connections like good ground (tight and clean)on the unit and work peice.no ground no fire.
Jun 03, 2009 | Welding Tools
Wont arc
If you have water in the system, bad tip or ground it wont spark properly
Domo
Sep 19, 2008 | Century Portable Plasma Cutter 25 Amp
Plasma Cutters support
In this process, an inert gas (in some units, compressed air) is blown at high speed out of a nozzle; at the same time an electrical arc is formed through that gas from the nozzle to the surface being cut, turning some of that gas to plasma. The plasma is sufficiently hot to melt the metal being cut and moves sufficiently fast to blow molten metal away from the
Aug 27, 2008 | MILLER 192049 SWIRL RING PLASMA CUTTER
Open Questions:
See all Lincoln Electric Plasma Cutter, Pro - Cut 25 Questions
Lincoln Electric Plasma Cutter, Pro - Cut 25 Logo
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
