Question about KitchenAid KDRP407HSS Dual Fuel (Electric and Gas) Kitchen Range
How to replace control module kdrp407hss4 - KitchenAid KDRP407HSS Dual Fuel (Electric and Gas) Kitchen Range
How to replace Dash light on temper control passenger side
Dismantling and mantling.
  1. Remove the I/P accessory trim plate. Refer to Instrument Panel Accessory Trim Plate Replacement (Refer To List 1) or Instrument Panel Cluster Trim Plate Bezel Replacement (Refer To List 2).
  2. Remove the HVAC control module screws.
  3. Depress the HVAC control module tabs (3) and remove the HVAC control module (2) from the I/P (4).
  4. Disconnect the electrical connectors (1) from the HVAC control module (2).
fix the module..... what ever.
and put it back
then see the last step.
Refer to Control Module References for programming and setup information.
then states
If the HVAC control module is replaced, an automatic re-calibration of all the actuators will occur. No additional procedures are necessary.
Jun 30, 2014 | 2006 Isuzu Ascender
P2107 code for at truck f 350 5.4
throttle actuator control module processor ----causes faulty throttle actuator control module check repair or replace -----throttle actuator control module harness has open[broken line] or shorted test repair or replace------throttle actuator control module circuit has poor or damaged electrical connection check clean ,repair or replace as necessary
May 14, 2014 | Cars & Trucks
Error code 105
Info for Error code 105
105. (01101001) Phase 2 to 6 - Comms Error Time Out
These faults are reported when the Display Module detects an error in
the communications between the Display Module and the Motor
Control Module.
Note: If the product is an IW, the wrong Motor Control Module may
have been fitted. Replace with a compatible part.
Phase 2 to 4 and Phase 6
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module.
Tertiary Source: Rotor Position Sensor (Phase 5 and 6).
Action: Replace Rotor Position Sensor. If this corrects
the fault, refit the original Display Module or
Phase 5
Primary Source: Pump
Action: Measure resistance of pump. If resistance is
less than 33 ohms, replace pump.
Secondary Source: Display Module.
Tertiary Source: Motor Control Module.
Quaternary Source: Rotor Position Sensor.
Sep 26, 2013 | Fisher and Paykel Washing Machines
Error 105
Try to get a Rotor position sensor as they are cheaper.
105. (01101001) Comms Error Time Out
These faults are reported when the Display Module detects an error in the communications
between the Display Module and the Motor Control Module.
Action: Replace Rotor position Sensor. If this corrects the fault refit the
original Display Module and/or Motor Control Module.
Feb 21, 2013 | Fisher and Paykel Aquasmart wl80t65c
Tech sheet missing need help with codes
Your Error code is 94
81. - 95
. (0101xxxx) Phase 2 to 3 - Display/ Motor Control
Module. See Fault Code 106
106. (01101010) Phase 2 to 3 and 5 - Display to Motor
Control Module Communications Errors
(Phase 6 IW Also)
Control Module.
Phase 2 to 3
Action: Replace Motor Control Module. If the new
Motor Control Module corrects the fault, refit the
original Display Module.
Phase 5
Feb 21, 2013 | Fisher and Paykel Washing Machines
Fisher Paykel Smartdrive MW058K error code 106
106. (01101010) Display Module to Motor Control Module Communications Error
Jul 23, 2012 | Fisher and Paykel Fisher & Paykel Washer
Fisher and paykel GW509 won't power up, pump not blocked, plug loose?
62. (00111110) Phase 5 - Pump Over Current
The Motor Controller module has detected an excessive pump current.
Primary Source: Pump.
Action:
Replace Pump.
Secondary Source: Motor Controller module.
Action:
Replace Motor Controller module.
107. (01101011) Phase 2 to 6 - Motor Controller module Reset Error
The Display Module has detected that the Motor Controller module has reset when
it should not have. This can be due to a Motor Controller module supply
disturbance or microprocessor failure.
Primary source: Motor Controller module.
Action: Replace Motor Controller module.
Red, Blue, Yellow go on the motor
Brown , White go on the pump.
Apr 13, 2012 | Fisher and Paykel Fisher & Paykel Washer
What is code 89?
81. - 95. (0101xxxx) Phase 2 to 3 - Display/ Motor Controller.
See fault code 106
104. (01101000) Phase 2 to 6 See fault code 106
106. (01101010) Phase 2 to 3 - Display to Motor Controller module
Communications Errors (Phase 6 IW also)
These faults are reported when the Display module detects an error in the
communications between the Display module and the Motor Controller module.
Primary Source: Display module.
Action:
Replace Display module.
Action:
Replace Motor Controller module. If the new Motor Controller module corrects the fault, refit the original Display module.
Feb 18, 2012 | Fisher and Paykel GWL11 Top Load Washer
Aquqsmart Error 105
Jan 26, 2012 | Fisher and Paykel Washing Machines
Fix code 104
104. (01101000) See Fault Code 106
Jan 24, 2012 | Fisher and Paykel GWL11 Top Load Washer
KitchenAid KDRP407HSS Dual Fuel (Electric and Gas) Kitchen Range Logo
48 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
