Ferroli optimax plus 35 Central heating keeps losing pressure
Every day or every other day I come home to find the heating has not come on as the pressure is too low in the system - sometimes this happens in the mornings too. no signs of water or radiators leaking and has been getting steadily worse over the last 6-8 weeks
  • 90 Answers
There is in your sistem an expansion basin where it must to be air inside .when the basin loose the air it heapend what you say.with a pump air (like for the whell car)you put back the air on 1,2 atm pressure
Posted on Dec 28, 2013
rockitman187
  • 2559 Answers
SOURCE: ferroli optimax 31c
Here is a link to the manual.It shows fault codes.
http://www.ferroli.co.uk/Product_Documentation/Domestic/Optimax_HE_31_C_Manual.pdf
Please rate this solution.
Posted on Jan 17, 2009
SOURCE: problem with heating on ferroli optimax 31c
d2 is the code symbol for delay after central heating. and is not a fault code.. however if this is coming on then stopping the operation of the boiler then it usually points to a sticking diverter valve.
Posted on Jun 28, 2009
  • 9 Answers
SOURCE: I have just tried to run my ferroli optimax 31c
D2 is not a fault what that means is delay and 2 refers to CH which means the boiler has gone into standby mode. you need to check that your CH circut is open, there is a filter on the return valve into boiler make sure this is not blocked. If this is blocked the water is just going though the boiler by-pass so then the boiler thinks its up to temp. hope this helps
Posted on May 04, 2010
SOURCE: hi i have a ferroli optimax 31c , hot water works
diverter valve problem will require replacing
Posted on Oct 02, 2010
SOURCE: ferroli optimax he 31c. brand
it is either your pump is not running or blocked [ debris from installation ect ] or your diverter valve is stuck partially open allowing a little water to pass into the heating system [ usually first rads on system ] it runs for a short while and cuts out because your overheat stat is kicking in because of poor circulation [ it is only running around the primarys in the boiler where it quickly reaches the over heat limit ] temp tends to rise approx 1 deg per second a clear indication of circulation problems.
solution GET RID OF THE FERROLI
Posted on Jan 09, 2011
Hello! I've got a Ferroli Optimax HE Plus 31c boiler with the F37 fault flashing.
Try bleeding the air out of the rads then represure system
Sep 17, 2016 | Heating & Cooling
Fault code f35 on ferroli optimax he plus 38 c
You simply need to get an electrician to check the power supply to your property, with a frequency meter if it tests OK then you will probably need to replace the board on the boiler, it has to be said that the incoming mains frequency is set by the supply system and generally cannot alter but some local conditions can have an undesirable effect, any good electrician will have a frequency meter on his van and will take only a few minutes to test.
Air Conditioning Coral Springs
Mar 03, 2015 | Heating & Cooling
Ferroli boiler optimax he 38 c.Powers up ok,no hot water,no error code.Think its an ignition problem.Heating flame not showing?????
Is there an error code? If not the flow sensor for the hot water could be faulty. Also if you've had a power cut depending which model of Optimax HE you have, you sometimes have to tell the boiler it's a Combi, as they have a generic Pcb fitted which is also used on the system only boilers.
Sep 26, 2013 | HQRP Universal A/C Remote Control...
Hi i have a ferroli optimax 31c , hot water works but my heating dont ,it comes on the the heat temp raises to its highiest then cuts of saying A3 AND D2 can you help please
hi had same problem engineer came out and the diverter valve was cloged up sorted it and recomended a system flush plus install a magnet clean whitch picks up debri be 4 it gets 2 the boiler.
Sep 26, 2010 | Quasar HQ2051TH Air Conditioner
Optimax 25c ferroli, central heating!!!!!!!!!!!help!!!!!
there should be a perm on setting on the system so instead of running it on timed mode switch it to on there is also a boost wich usually give 1 hour of heating
Mar 21, 2009 | Honeywell Programmable Thermostat Heater
Ferroli optimax 31c
Jan 16, 2009 | Heating & Cooling
Heating & Cooling Logo
78 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
