Question about HP iPAQ hw6515 Pocket PC
View of internet page is incomplete
The main function that I use is connecting to the internet to check my e-mail while travelling.  This means that I go to the webmail site of my internet provider, and look at my e-mail from the server-I download it all later when I am back to my computer.  This worked fine until I changed my interent provider.  I now use (this is in Italy) .  I have no problem with this process from a computer, but when using the HP IPAQ, the spaces with the icons where I have to fill in the user name, passwrod and click enter, simply do not appear on the internet page.  I have tried to visualize the page in a differrnt manner- default, column or desktop, but the section is still not visible.  I also made sure cokies were turned on and I changed the size of the tex, but still nothing.  So, the HP IPAQ has suddenly become useless for this important task.  Any ideas?? Thanks!
  • 39 Answers
Re: view of internet page is incomplete
Perform a soft reset of the device. Make sure it is a soft reset, as a hard one would lose all data.
I believe there should be a reset button on the back. Check your manual to be sure.
That would take care of the opera crash.
As far as the site is concerned, there is not much we can do. It is Java based, and if you dont have java support installed on the Pocket PC, you would not be able to use the site properly.
Contact the company and see if they have an alternate low-fi address you can use. Or if they can give you the server info to setup the actual account on the PocketPC without using IE.
If not, then you might want to consider changing companies.
Posted on Oct 15, 2007
  • 120 Answers
Ok so your ipaq uses Pocket Internet explorer.  Pocket IE is based off ie 5 if I remember correctly, so it's a bit outdated.
This is what I would try first.  Simply try to move over to using Pocket Opera instead of IE.  Yes it's technically a fix of the errors your having, but it's a work around that you should try for sure.  Opera is well updated and adds a ton of features that Pocket IE doesn't have, and it displays pages in larger screens than IE can usually.
you can download it here...
Download the .cab if you are browing from the phone, download the .msi if you are downloading on a computer and installing through usb cable sync.
Now our other option is to try changing the user agents in Pocket IE to trick pages into thinking your using IE 6.  Try using pocket opera first, I have to personally use opera on my phone for a few sites, it's just an issue I have to deal with.
Please reply back and let me know if this works, if not we can go from there and try the user agent changing.
I hope this has explained your question in detail. If I've helped you please don't forget to rate me.
Posted on Oct 10, 2007
0 characters
3 Points
I can not figure out how to connect my device to the internet Wi-Fi, I want to go on internet explorer and it won't connect
To send and receive e-mail with Inbox and view Web sites with Pocket Internet Explorer, set up a remote connection using a modem card or an Ethernet/LAN card.
To connect to the Internet with a modem card, you need a phone line, a dial-up Internet Service Provider, and an optional Single-slot or Dual-slot PC Card Expansion Pack or CompactFlash (CF) Card Expansion Pack.
*Insert your modem card
*From the Start menu, tap Settings
*Tap the Connections tab->Connections Icon-->Internet Settings-->Modify-->New
*Enter a name for the connection, select the modem type, and select the correct baud rate for that modem.
I have shared the basic steps..which I refereed using the reference guide for the model that you have specified from this website.This you can easily get my typing "reference guide for Compaq iPAQ H3850 Pocket PC" in Google...and the first link lets you download the PDF..Follow the steps carefully and connect to the internet.To check for the internet speed you can use which gives you accurate speed results.
Oct 28, 2013 | Compaq iPAQ H3850 Pocket PC
Text size is small when veiwing internet
This is very simple but not everyone known this.
To rezise the page or fonts on your LG KU990 (Viewty)
To set the sound higher or lower when you've a call.
To set your volume lower or higher with the media player
or FM radio.
You the LG KU990 (Viewty) has a 5.0 mega pixel camera.
You now how you can use the zoom function on this phone?
Well the same function you can use it for the other apps and
programs in your phone. The Jog wheel have more functions
then only zoom in and zoom out.
Check it and try it with diferents apps.
like the iternet browser/ Mp3 player/ Media player and the FM radio.
I hope this will make you and many others happier and have much
more fun with the use of LG KU990 (Viewty).
Best regards;
Henk ®Muskita. ©2009.
Mar 08, 2009 | LG KU990 Viewty
How to connect to internet via a notebook's wireless for HTC G1?
If you are looking for your laptop to do web via the phone, this is what you are looking for...
IF you are trying to do Terminal Services or mail clients or non web TCP/IP, there should be some apps coming out soon for general IP stuff...
Jan 03, 2009 | HTC G1
Hp pocket pc.Travel companion,turns on,but can't view anything
I don't know how long you've had that unit. So the question is have you done any updates on it since you've had it.
An update most likely will fix most problems.
Follow this link to get to your devices' support page. It would be a good idea to bookmark it and register so they can send you any needed update alerts for your iPaq.
Dec 02, 2008 | HP iPAQ rx5935 Travel Companion Pocket PC
Do you mean the internet explorer closes on you and you see the home page of the dash?
- Sounds like a corrupted file or issues with IE.
- are you viewing java script pages?
- I would do a master reset just in case. Just make sure to back up your phone first.
May 27, 2008 | T-Mobile Dash Smartphone
Hw6515 pda
Dear Phil,
its mean you have to update the GPRS Service.
there are 2 ways to downlaod the files, GPRS or internet
1. click on the quick gps connetion icon, select setting.
2. select setting, then check the enable update and initial GPRS
3. click on icon and select download, it will connect to date service and download the files.
step 1 and 2 above
3. click icon select download while it on cradle.
also install the quick gps utility on pc, and add the quick qps connection into activesync list. each time you synchronize PDA the file will get updated.
For your second problem ,which is related to File Passward protections , its seems you had create these Worksheets on NTFS File system thatswhy they asked about the passward.
Mar 29, 2008 | HP iPAQ hw6515 Pocket PC
Disconnect Problem
you can turn off your internet or gprs so it wont always automatically connect to the internet.
Mar 08, 2008 | Motorola Mobility Q Smartphone
I do have a onnectivity problem on my o2 xda 2s please help!
I am having a problem with my o2 xda atom running wm5.0
I have a wireless router at home connected to a cable modem. I have set up
the wifi card on the pda. I go to wi-fi utility and I can ping sites on the
internet. No problems there.
Then I start Internet Explorer. I try to go to a web page and I get a
message box saying "The page cannot be found. Check the name and try again".
There is nothing at all wrong with the name, it IE does this for every web
It seems IE doesn't know it is supposed to use the wifi card to connect to
the internet. How do I tell it to do this? Or if that's not the problem, can
someone tell me how to fix this?pls mail the solution to
Dec 25, 2007 | PDAs
Cannot connect to Internet
sound's like the phone is still looking to dial up to the network try removing the dial up connection setting and retry wireless lan settings
Sep 18, 2007 | Orange SPV M2000 Pocket PC
HP iPAQ hw6515 Pocket PC Logo
69 people viewed this question
Top HP PDAs Experts
David Payne
David Payne
Bob S
Level 1 Expert
Are you a HP PDA Expert? Answer questions, earn points and help others
