Question about RTO Atwood DSI-RV Water Heater-6 Gallon
Electronic burner lights then goes out in a few seconds
I am not sure about your particular heater but the thermocouple on a full-size gas water heater is often the cause of a pilot failing. It is relatively inexpensive to change (or mine was). It is a simple metal tube with a wire that is located near the pilot to tell the burner that it is ok to come on because the pilot is lit.
Posted on Nov 27, 2013
  • Daniel Gibbs Nov 27, 2013
Piezo ignition combustion tripped
It sounds like the thermocouple is going out. That's the solid copper line that the pilot heats up telling the gas valve when to open and close. You could try to replace it or pull burner from under heater and using a dollar bill clean the tip and replace. If its not completely out, this should do the trick
Feb 11, 2014 | Water Heaters
!990 Bounder By Fleetwood Water Heater is not lighting the propane
Check the gas line orifice for a spider web. Its possible the gas is not able to get past the web.
Nov 30, 2012 | Atwood Mobile Products Llc Water Heaters...
Water heater goes out
The burner needs to be adjusted
Mar 13, 2017 | Water Heaters
Pilot light lights and stays lit until you turn the temp up. Burner ignites for a few seconds and then everything goes out and you have to wait about an hour to relight it
Sounds like this is the gas regulator giving the the problems, i would call a local plumber to service this . gas and flame is very dangerous.
Mar 27, 2010 | Rheem Water Heaters
How do I light my Rheem water heater if my peizo ignitor switch isn't working
Remove the burner access cover under the control valve. Press the pilot light button (gas control) and hold it down. At the same time, light the pilot. Continue to hold the lighting button for a few seconds until the thermocouple heats up. Release the button. Twist the gas control knob to the ON position, and the burner should fire up after a few seconds. Replace the access cover. Good luck.
Feb 09, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
GE gas water heater lights for only a few seconds. After the burner ignites it quickly goes out along with the pilot light. The pilot cannot be relit for at least 20 minutes. Have replaced the...
Called GE and there is a glass vile under the burner that is defective and cuts off the oxygen.
They are mailing out a replacement to my house & have contracted a plumber to install. waiting 4 days now. They say that the glass vile incinerates and there is not any thing left to it. The burner area is full of black soot. will post again one fixed.
Jan 08, 2010 | General Electric GE SmartWater Household...
Bosch AQ125BNG Burner goes out even though the
Often, this is the result of a restriction of exhaust gases. This type of hot water heater must be adequately vented, (per installation specs). I found this out after taking a number of cold showers. :^( Two years later, and still counting, no more problems. :^)
Jul 11, 2009 | Bosch Water Heaters
RTO Atwood DSI-RV Water Heater-6 Gallon Logo
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Donni Steen
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
