Question about Canon Office Equipment & Supplies
Some printing functionality is not currently available
How to print vertical
Vertical printing is one of the 9 styles of print available. To select a print style:
Hold down the CODE key.
Press the STYLE key once. The display will show the current style.
Still holding down the CODE key, press the STYLE key again. The available style will appear in order as you press the STYLE key.
When the VERTICAL style appears release the CODE key.
Jul 27, 2016 | Brother P-Touch 300 Thermal Printer
Printer functionality not currently available, what do i do
What happens if you switch off both printer and computer for at least long enough to make a cup of tea, then fire it up again, please?
What printer is this, anyway?
Best wishes,
Robbie
Mar 19, 2015 | Office Equipment & Supplies
How do I print 1 page out of several. Cannot find print preview
You can perform this function from the software program you are using. Place the page you want to print on the screen, then go to the print function. Look for something like 'Print current page", or if you have the page number, you can enter it in a 'print pages' box.
The printer will then print what you sent to it.
Feb 23, 2015 | Epson WorkForce WF-2540 All-in-One Inkjet...
I have a Epson wf2540 printer and I want to copy only 1 page out of several how do I do that
This is a software function that is not controlled by the printer. If you need help with the printing function, you can use the F1 key to access help.
Function not selectable current shooting modefunction not selectable current shooting mode
Not all functions are available in all shooting modes. What function are you trying to use in what mode?
Oct 28, 2013 | Canon EOS 600D Rebel T3i Digital Camera
How do I print pictures from my camera on the computer(pictbridge)?
The camera compares its PictBridge functions to the functions of the printer. The camera then displays the supported functions on menus on the LCD screen or in the viewfinder.
PictBridge print options
Once a PictBridge digital camera is connected to a compliant printer, print options appear on the camera LCD. The camera menu system is used to make settings such as print size, layout, media type and date.
You can print a single image displayed on the camera, print two or more images or print all images on the memory card. You can print part of an image by first cropping it within the camera and even create index prints, also known as contact sheets.
Print sizes and PictBridge
Not all PictBridge digital cameras let you select all available prints sizes, such as 13×19? if you have a wide format printer. If the printer has a memory card slot, use it and larger size prints should be available.
Is your device PictBridge compatible?
To find out if a camera or printer is PictBridge compatible, look for the PictBridge logo on the packaging or check the manual for specifications. If still unsure, call the manufacturer!
Jan 13, 2011 | Cameras
I need help with a windows 7 driver for SP-c210SF. does anyone know where I can find a driver that works?
There isn't currently a Windows 7 driver available for this machine. You can attempt using a Vista driver or the driver may be available embedded within the Windows 7 software. Worst case, you can use a generic driver such as the HP Laserjet 4 driver. Using this driver should get you printing but may not allow machine specific functions. It is available from within the Windows 7 software.
Dec 04, 2009 | Ricoh Aficio SP-C210SF Printer
Vista doesn't detect hp laserjet 3030 as usb device
6 - Yes. Your product is supported. Drivers for HP printers are included with the Microsoft Windows Vista Operating System. Additional software will be available soon. HP has a driver solution available for your product. HP is committed to providing the best experience for HP products in the Windows Vista operating environment. Currently, a full-solution driver is not available for your product. However, we do have an alternative driver solution that you can conveniently find in Microsoft Windows Vista. This driver will enable your product's basic functions to work and can be used until the full driver solution is available. Full-solutions will be available as early as January 2007. HP expects to complete the certification process for applicable software by July 2007. Solutions will be posted as they become available. Click here to recieve e-mail updates from HP when a solution is available. HP aspires to provide the most up-to-date information on HP drivers and software. Please check back soon for updates.
NOTE: If your printer currently uses either a PCL5, PCL6 or PostScript XP driver you may download the current XP driver from HP to provide printing functionality. Windows Vista printing is very similar to Windows XP and most print drivers supported in XP environment for LaserJet printers may also work in the Windows Vista operating system.
Jan 04, 2009 | HP LaserJet 3030 All-In-One Printer
Ram disk
Stangowner, In this case, the print job is too large for the available printer memory. Your choices are one of the following: Press to clear the message, cancel the current print job, and conduct the next print job, if any. · Press Cancel to cancel the current print job. · Press Menu to open the Stored Print and delete the current job. To avoid this error in the future, do the following: · Reduce the number of print pages such as splitting the print data. · Increase free memory space by deleting unnecessary data in the RAM disk. As for the RAM disk: When you send a job to the printer, you can specify in the driver that you want the printer to hold the job in memory. When you are ready to print the job, you must go to the printer and use the operator panel menus to identify which job in the memory you want to print. You can use this function to print a confidential job (Secure Print), or verify one copy before printing additional copies (Proof Print). NOTE: The printer holds the job until you delete it by using the operator panel or you turn off the printer. (This is the RAM disk) NOTE: Print and Hold functions require a minimum of 320 MB available printer memory. Also, you need to configure the RAM disk settings on either the OPERATOR PANEL OR THE PRINTER DRIVER. NOTE: Depending on the documents, its job may be too big for the available memory. In this case, an error occurs. Take this link and print it out. It will help you later when you get "other" error messages. http://support.dell.com/support/edocs/systems/3100cn/en/UG/section19.html And here's a link for more "operational" situations. http://support.dell.com/support/edocs/systems/3100cn/en/UG/section16.html#1087088 ZT3000 "Beta tester of "0"s and "1's"
Aug 21, 2007 | Dell 3100cn Laser Printer
299 people viewed this question
old marine
old marine
