Question about Brother Sewing Machines
Brother Innovis 1e isn't stitching properly when the feed dogs are down
When the feed dogs are down for free motion quilting or embroidery the machine skips stitches all the time and often breaks the thread.Help please!!
  • Brother Master
  • 7,365 Answers
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
5. If the above suggestions don't help then the machine needs to be checked
For a timing problem.
Posted on Nov 26, 2013
4 Suggested Answers
  • 201 Answers
SOURCE: Skipped stitches & looping on the bottom of Quilt
Try a different needle. Use a quilting or topstitch or even a metallic needle - one that has a larger scarf than normal. The scarf is the groove at the back of the needle where the thread goes while the stitch is being formed. Quilting threads often need more "room" there. I have been told that the Inspira quilting needles are good because they have a thread groove on the front and the back of the needle. Not tried them personally but might be worthwhile for you to consider.
For the looping, you could fiddle with your tensions a little either loosening the bobbin tension or tightening the top, or both. Only ever do this in very small increments. But the good news is that even the "professional" quilters do not have perfect quilt backs - just have a look at them at quilt shows!
Pam M.
Posted on May 03, 2009
RichSew
  • 184 Answers
SOURCE: Can't free motion quilt on Juki-T98QE
You need to be using a free motion foot or a darning foot, the regular presser foot is not for free motion.
Posted on Jun 03, 2010
SOURCE: needle thread breaks while quilting on machine frame
I posted question about top thread breaking when quilting (using walking foot). Finally solved my problem, my solution may help others. Decrease the presser foot tension to nearly 0. Had tried different threads, tension settings, needles. Nothing worked until I adjusted the presser foot tension. Quilting went like a dream, even through seams ect, also worked for attaching binding.
Posted on Feb 15, 2013
I want to free hand machine quilt - but it won't work when I drop the foot
You need an embroidery foot, that doesn't lay on the fabric like a normal foot and allows free motion of the fabric. If you are using one, be sure it is the appropriate foot for your machine and that you have pushed the appropriate button or place on your machine so that the machine will place the foot in the correct position.
Feb 16, 2017 | Sewing Machines
Prelude. How can I adjust a feed dog to go left to right?
Sewing machine feed dogs generally do not move sideways. They move only forward or backward. Embroidery machines will stitch in all directions but only because they use hoops and not feed dogs to move the fabric. If you need the stitch to go a different direction, you can try rotating the fabric. Free motion quilting uses your hands to move the fabric under the needle but the feed dogs are not in use.
Mar 10, 2016 | Sewing Machines
Bobbin thread will not catch unless the foot is down?
Ashleigh--Your machine will work satisfactorily ONLY if the presser foot is down. When the presser foot is up, the tension disk is released, therefore, no tension = a big knot of thread.
To free motion quilt, you should drop the feed dogs. Install a darning foot (this foot is shorter in length so when it is lowered, there is a space between the presser foot and needle plate). The space allows the fabric to be moved easily while stitching.
Some sewists will free motion quilt without a presser foot (if they don't have a darning foot), but that is very dangerous as one can easily sew through a finger. However, even when sewing without a presser foot, the presser foot mechanism needs to be lowered in order to properly form stitches.
How to Free Motion Quilt on Regular Sewing Machine
Feb 25, 2016 | Sewing Machines
How do I avoid breaking a needle on a 26 foot beginning a free motion project after programing the foot choice and lowering the foot?
#26 is an embroidery foot. Why are you using an embroidery foot for free motion quilting? A #24 free motion embroidery foot will work but not the #26. Try using a darning foot that is just a smidgen shorter so there is space between it and the needleplate for you to freely move the fabric. (Adding a Supreme Slider sheet to the work surface of your machine helps make the fabric glide much smoother.) A standard presser foot is made to press the fabric against the feed dogs so the feed dogs will move the fabric. When free motion quilting, you would drop the feed dogs and move the material with your hands.
Depends which model Bernina you have (new or old style presser feet), which will work on your machine. There are also many generic darning/FMQ feet available that will work on your machine.
12 BERNINA presser feet Darning foot 9 (old style)
Quilting foot 29C (new style)
Bernina 530 53 Free Motion Quilting
Top 5 Tips for Successful Free Motion Quilting WeAllSew BERNINA USAs blog...
Seven Steps to Free Motion Quilting
Dec 31, 2015 | Sewing Machines
Which foot do I use for quilting
a quilting foot or buy one with a round hole in it great
Mar 09, 2015 | Sewing Machines
Manual for brother vx757 free please
A manual feed is used primarily in freehand embroidery, quilting, and shoe repair. With manual feed, the stitch length and direction is controlled entirely by the motion of the material being sewn. Frequently some form of hoop or stabilizing material is used with fabric to keep the material under proper tension and aid in moving it around. Most household machines can be set for manual feed by disengaging the drop feed dogs. Most industrial machines can not be used for manual feed without actually removing the feed dogs.
Nov 19, 2013 | Singer 8280 Mechanical Sewing Machine
How to set 2140 for free motion sewing
Which model are you using? Creative 4.5?, On the newer machines it drops automatically once the embroidery attachment is hooked up. On older Creatives v2.x there is a slide lever in front of the presser foot on the front.
Sep 26, 2012 | Sewing Machines
How do I set my pfaff mahine up for free motion quilting
try dropping the feed dogs, & reduce the top thread tension one number at a time till the stitches are normal
Feb 27, 2012 | Sewing Machines
Why when i put the feed cover on i cant move the fabrice at all there is no room between the foot and the cover. i am trying to quilt together my quilts. thank you brenda g
I'm assuming your machine has a little plate you put over the feed dogs rather than a knob which disengages the feed dogs from moving to do free motion embroidery or something.
If this is the case there probably isn't enough room for your quilt sandwich under the foot.
You could try using a free motion embroidery foot rather than the regular foot with the feed dogs up and see if that allows you sufficient movement.
It would look like this:
It may take some practice still to get a smooth stipple if that is the effect you are going for.
You may find some other ideas on quilting websites to get around this problem or in a Yahoo group for quilters. I've only ever quilted in straight stitch using my walking foot so it feeds the quilt smoothly for me, never tried FMQ.
Oct 24, 2011 | Brother XL-5130 Mechanical Sewing Machine
Sewing Machines Logo
66 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
